Hello,
I have read some similar problems and the solutions that were provided either didn’t work or I couldn’t do what was mentioned so I thought it would be better if I started a new thread.
So, I tried to boot from the live usb using the 21.07 gnome version and while the initial options with the drivers and such appeared and after my selection the ‘‘checks’’ it usually does started, in the end it got stuck(Same thing happened with the 21.07 gnome minimal LTS kernet version). After that I tried the 21.07 kde plasma version which did the same thing. Then I went on to previous releases, specifically 20.2 gnome, which I was able to install just fine, but after updating the system it broke and couldn’t boot at all. Is there something I can do to make it work, or even updating from an older version without it breaking?
CPU:AMD Ryzen 7 1700
GPU:NVIDIA GeForce GTX 1060 6GB
By the way, I’m new here and I can’t really do much without details.
inxi output(from gnome 20.2):
Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=b984252e-e8bd-4dd4-a553-d55281b5f8c3 rw quiet splash apparmor=1
Desktop: GNOME 3.38.1 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.38.2
Distro: Manjaro Linux
Type: Desktop Mobo: ASRock model: X370 Taichi serial: <filter>
UEFI [Legacy]: American Megatrends v: P4.40 date: 02/07/2018
RAM: total: 15.63 GiB used: 1.43 GiB (9.1%)
Info: 8-Core model: AMD Ryzen 7 1700 bits: 64 type: MT MCP arch: Zen
family: 17 (23) model-id: 1 stepping: 1 microcode: 8001129
L2 cache: 4096 KiB bogomips: 96024
Speed: 1498 MHz min/max: 1550/3000 MHz boost: enabled Core speeds (MHz):
1: 1697 2: 1779 3: 1338 4: 1277 5: 2565 6: 2578 7: 1279 8: 1279 9: 2563
10: 2866 11: 1278 12: 1278 13: 1278 14: 1278 15: 1278 16: 1278
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate irperf lahf_lm lbrv lm mca mce
nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sha_ni skinit smap smca sme smep ssbd
sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce topoext
tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2
mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: Micro-Star MSI
driver: nvidia v: 455.45.01 alternate: nouveau,nvidia_drm bus ID: 2d:00.0
chip ID: 10de:1c03
Display: x11 server: X.org 1.20.10 compositor: gnome-shell driver: nvidia
resolution: <xdpyinfo missing>
OpenGL: renderer: GeForce GTX 1060 6GB/PCIe/SSE2 v: 4.6.0 NVIDIA 455.45.01
direct render: Yes
Device-1: NVIDIA GP106 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 2d:00.1 chip ID: 10de:10f1
Device-2: AMD Family 17h HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel bus ID: 2f:00.3 chip ID: 1022:1457
Device-3: Microsoft LifeCam VX-2000 type: USB driver: snd-usb-audio,uvcvideo
bus ID: 3-4:4 chip ID: 045e:0761
Sound Server: ALSA v: k5.9.11-3-MANJARO
Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel port: e000 bus ID: 27:00.0 chip ID: 8086:24fb
IF: wlp39s0 state: up mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
port: d000 bus ID: 2a:00.0 chip ID: 8086:1539
IF: enp42s0 state: down mac: <filter>
Local Storage: total: 2.05 TiB used: 8.02 GiB (0.4%)
ID-1: /dev/nvme0n1 vendor: Kingston model: SA2000M81000G size: 931.51 GiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
serial: <filter> rev: S5Z42105 scheme: MBR
ID-2: /dev/sda vendor: Seagate model: ST1000DM010-2EP102 size: 931.51 GiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: CC43 scheme: GPT
ID-3: /dev/sdb vendor: Samsung model: SSD 860 EVO 250GB size: 232.89 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
rev: 1B6Q scheme: GPT
ID-1: / raw size: 931.51 GiB size: 915.89 GiB (98.32%) used: 8.02 GiB (0.9%)
fs: ext4 dev: /dev/nvme0n1p1 label: N/A
uuid: b984252e-e8bd-4dd4-a553-d55281b5f8c3
ID-1: /dev/sda1 size: 16.0 MiB fs: <superuser/root required> label: N/A
uuid: N/A
ID-2: /dev/sda2 size: 701.50 GiB fs: ntfs label: 1TB Storage
uuid: B04863A2486365D6
ID-3: /dev/sdb1 size: 499.0 MiB fs: ntfs
label: \xce\x91\xce\xbd\xce\xac\xce\xba\xcf\x84\xce\xb7\xcf\x83\xce\xb7
uuid: 403AB4703AB46516
ID-4: /dev/sdb2 size: 99.0 MiB fs: vfat label: N/A uuid: DCB5-6A2D
ID-5: /dev/sdb3 size: 16.0 MiB fs: <superuser/root required> label: N/A
uuid: N/A
ID-6: /dev/sdb4 size: 232.29 GiB fs: ntfs label: N/A uuid: 9A60B82E60B812CD
Hub: 1-0:1 info: Full speed (or root) Hub ports: 14 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Device-1: 1-9:2 info: Intel Wireless-AC 3168 Bluetooth type: Bluetooth
driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 8087:0aa7
Hub: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003
Hub: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Device-1: 3-2:2 info: Corsair CORSAIR M55 RGB PRO Gaming Mouse
type: Mouse,HID,Keyboard driver: hid-generic,usbhid interfaces: 4 rev: 2.0
speed: 12 Mb/s chip ID: 1b1c:1b70 serial: <filter>
Device-2: 3-3:3 info: China Resource Semico USB Keyboard
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s chip ID: 1a2c:4b81
Device-3: 3-4:4 info: Microsoft LifeCam VX-2000 type: Video,Audio
chip ID: 045e:0761
Hub: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003
System Temperatures: cpu: 43.0 C mobo: N/A gpu: nvidia temp: 52 C
Processes: 363 Uptime: 4m Init: systemd v: 246 Compilers: gcc: N/A Packages:
pacman: 1156 lib: 312 flatpak: 0 Shell: Zsh v: 5.8
running in: gnome-terminal inxi: 3.1.08
Thank you in advance for your responses!
