Machine Crashes after graphical glitch
The general synopsis is, I play a game. Machine crashes game (whether its, lutris of steam). All Icons turn into a generic icon and then I get a screen full of colors and it freezes there until i power down.
I am unsure how to do this and sometimes it can be different. In the case of Dragon Age Origins. I ventured to a place on the map said it couldn’t load and then booted me back to the game intro screen where I couldn’t resume or load any games. Then upon exiting dragon age i noted all icons had reverted to some generic folded paper icon.
In another case, was playing star craft and some of the creatures just were the bubble that the graphic should be rendered around and then exiting the game I got that as well.
Some times it just crashes like i posted above, it can be something some what different each time.
Here is Inix below…I am unsure how to even trouble shoot this. Could possibly be my Hard drive too.
  Kernel: 5.10.23-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  root=UUID=b24af504-cd4c-4139-9023-5d8ecdee0d55 rw quiet apparmor=1
  Desktop: GNOME 3.38.4 tk: GTK 3.24.27 wm: gnome-shell dm: GDM 3.38.2.1
  Type: Desktop Mobo: Micro-Star model: X470 GAMING PLUS (MS-7B79) v: 2.0
  serial: <filter> UEFI: American Megatrends v: A.B0 date: 07/04/2019
  RAM: total: 15.64 GiB used: 2 GiB (12.8%)
  Info: 6-Core model: AMD Ryzen 5 1600X bits: 64 type: MT MCP arch: Zen
  family: 17 (23) model-id: 1 stepping: 1 microcode: 8001138 cache: L2: 3 MiB
  bogomips: 86425
  Speed: 1886 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
  1: 1886 2: 1887 3: 1886 4: 1886 5: 1886 6: 1888 7: 1889 8: 1890 9: 1887
  10: 1886 11: 1884 12: 1886
  bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
  fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
  mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
  npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
  perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
  rdrand rdseed rdtscp rep_good sep sev sha_ni skinit smap smca sme smep ssbd
  sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce topoext
  tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave
  xsavec xsaveerptr xsaveopt xsaves
  disabled, RSB filling
  Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
  vendor: Gigabyte driver: amdgpu v: kernel bus-ID: 27:00.0 chip-ID: 1002:67df
  class-ID: 0300
  Display: wayland server: X.org 1.20.10 compositor: gnome-shell driver:
  loaded: amdgpu note: n/a (using device driver) - try sudo/root display-ID: 0
  OpenGL: renderer: Radeon RX 590 Series (POLARIS10 DRM 3.40.0
  5.10.23-1-MANJARO LLVM 11.1.0)
  v: 4.6 Mesa 20.3.4 direct render: Yes
  Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
  vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 27:00.1
  chip-ID: 1002:aaf0 class-ID: 0403
  Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
  driver: snd_hda_intel v: kernel bus-ID: 29:00.3 chip-ID: 1022:1457
  class-ID: 0403
  Device-3: Logic3 Afterglow Universal Wireless Gaming Headset type: USB
  driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-13:2 chip-ID: 0e6f:010d
  class-ID: 0300
  Device-4: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
  bus-ID: 5-2:2 chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
  Sound Server-1: ALSA v: k5.10.23-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.23 running: yes
  vendor: Micro-Star MSI driver: r8169 v: kernel port: f000 bus-ID: 22:00.0
  IF: enp34s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Message: No Bluetooth data was found.
  Message: No LVM data was found.
  Local Storage: total: 1.82 TiB used: 333.77 GiB (17.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM003-9YN162
  rotation: 7200 rpm serial: <filter> rev: CC4D scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD10EZEX-08WN4A0
  rotation: 7200 rpm serial: <filter> rev: 1A02 scheme: MBR
  ID-1: / raw-size: 931.22 GiB size: 915.6 GiB (98.32%)
  used: 333.77 GiB (36.5%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
  uuid: b24af504-cd4c-4139-9023-5d8ecdee0d55
  used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
  uuid: 3A48-0E62
  ID-1: /dev/sdb1 maj-min: 8:17 size: 50 MiB fs: ntfs label: System Reserved
  uuid: 40708AF0708AEC4A
  ID-2: /dev/sdb2 maj-min: 8:18 size: 930.97 GiB fs: ntfs label: N/A
  uuid: 3C928E80928E3E80
  ID-3: /dev/sdb3 maj-min: 8:19 size: 499 MiB fs: ntfs label: N/A
  uuid: FAB61C2DB61BE941
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 14 rev: 2.0
  Device-1: 1-13:2 info: Logic3 Afterglow Universal Wireless Gaming Headset
  type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
  rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 0e6f:010d class-ID: 0300
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s
  Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
  Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Device-1: 5-2:2 info: Logitech Webcam C270 type: Video,Audio
  power: 500mA chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
  Device-2: 5-3:3 info: Microdia USB DEVICE type: Keyboard,Mouse
  power: 100mA chip-ID: 0c45:5104 class-ID: 0301
  Device-3: 5-4:4 info: Razer USA DeathAdder Chroma type: Mouse,HID,Keyboard
  driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
  power: 100mA chip-ID: 1532:0043 class-ID: 0301
  Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 35.4 C mobo: N/A gpu: amdgpu temp: 25.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 792
  Processes: 307 Uptime: 9m wakeups: 0 Init: systemd v: 247 tool: systemctl
  Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1572 lib: 486
  flatpak: 0 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.03
Here are error logs i get at startup - I don’t know how to check errors after crash and reboot…
 [    0.182252] Expanded resource Reserved due to conflict with PCI Bus 0000:00
[    0.285195]  PPR NX GT IA GA PC GA_vAPIC
[    0.299784] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.299873] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.299945] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.300016] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.300108] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.300172] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.300254] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.300306] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.300379] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.300438] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.300497] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    0.300559] [Firmware Bug]: ACPI MWAIT C-state 0x0 not supported by HW (0x0)
[    2.907078] ata5: failed to resume link (SControl 0)
[    3.940411] ata6: failed to resume link (SControl 0)
[   12.663293] systemd-journald[302]: File /var/log/journal/48b43275dff14e489ba215e8e30cb68c/system.journal corrupted or uncleanly shut down, renaming and replacing.
[   14.244895] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
[   14.726678] kvm: disabled by bios
[   14.828474] kvm: disabled by bios
[   14.906495] kvm: disabled by bios
[   15.036384] kvm: disabled by bios
[   15.195278] kvm: disabled by bios
[   15.344278] kvm: disabled by bios
[   15.473716] kvm: disabled by bios
[   15.579224] kvm: disabled by bios
[   15.714405] kvm: disabled by bios
[   15.852742] kvm: disabled by bios
[   16.098049] amdgpu 0000:27:00.0: amdgpu: Trusted Memory Zone (TMZ) feature not supported
[   22.584858] kauditd_printk_skb: 12 callbacks suppressed
[   27.887958] kauditd_printk_skb: 12 callbacks suppressed
[   29.766472] systemd-journald[302]: File /var/log/journal/48b43275dff14e489ba215e8e30cb68c/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
[   35.011445] kauditd_printk_skb: 6 callbacks suppressed
Hello :slight_smile:
First off all i would suggest to upgrade the system, if not done:
sudo pacman -Syu
then there could be a problem with the UEFI. Upgrade it: https://www.msi.com/Motherboard/support/X470-GAMING-PLUS#down-bios
Could be possible, that this is the problem. Did you try an older/another kernel?
Also there is a possibility, that there are some glitches when running wayland with xorg extended. Try run gnome in full xorg enviroment without wayland.
No idea, if you need ACPI (disabling it on laptops could drain more the battery), but it seems there are problem with it. Try to disable it. Add acpi=off to the kernel parameter. (Kernel parameters - ArchWiki)
Thanks for the help megavolt
I update often. So it may be because of a kernal update.
I would prefer to keep up with newer kernels but I could drop back if it continues.
I am unsure how to switch this, I saw one example where some one attempted it and didn’t fix until the reimaged. Do you have tips for this?
Article I am refering too
As for the ACPI I still need to figure that out as well.
Many thanks for your help.
As i remember you can switch to full xorg mode at gdm (login screen) at the bottom right on the screen or right to the password input. There is no need to disable wayland at a config file.
I sadly don’t see that. My machine automatically logs into manjaro and then if i go back to a login screen I do not see that option.
Bit of an update here - just tried playing some sc2 and one game kept freezing up for seconds at a time then one game the screen just suddenly went black and there was a cursor available. Kindof looked like it may have been a vtty but I couldn’t tell. Is there a way to run that event dangers journal ctl after i restart the machine?
