Hi there. I have to install Anydesk/Teamviewer on my Manjaro GNOME (Linux 5.8.18-1-MANJARO x86_64 20.2 Nibia), which don’t support Wayland at all.
I can’t switch to Xorg in my login window (I’ve tried to choose GNOME on Xorg in my login screen, but I can log in, it just displays the login screen again after entering the password).
I’ve tried to uncomment WaylandEnable=false in /etc/gdm/custom.conf, but after rebooting I wasn’t able to login - I just saw a blinking dash screen. I had to discard these changes in order to be able to log in. Does anyone know how to disable wayland in other ways?
UPD. I dunno if it matters, but I use video-vesa GPU driver for AMD Radeon Graphics, laptop: Honor MagicBook Pro (HLYL-WFQ9)
Yes, thanks for the explanation. I tried to repeat the steps you said but it didn’t help me, I still can’t login with Xorg. If you want I can attach a video of the problem
Graphics driver not needed is the reason, I did this some time before…
Resolution: —> manjaro-settings-manager → Auto install Open-Source Driver (in Wayland session!)
alternative:
sudo mhwd -r pci $(mhwd -li |grep ‘video-’ | awk ‘{print $1}’)
sudo mhwd -a pci free 0300
