Macbook Pro mid 2012 overheating problem
I am using the Macbook Pro mid 2012 currently dual booting with Catlina and Manjaro XFCE.
I noticed as, with earlier Ubuntu that there is an overheating problem. I was wondering is there any known solution for it. I have 16GB ram and enough HD space.
Also I have installed the mbpfan programm…
  Kernel: 5.10.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  root=UUID=5641c3f8-b7e6-4921-a5b0-04e6ca3e69ab ro quiet
  udev.log_priority=3
  Desktop: Xfce 4.14.3 tk: Gtk 3.24.23 info: xfce4-panel wm: xfwm4
  dm: LightDM 1.30.0 Distro: Manjaro Linux
  Type: Laptop System: Apple product: MacBookPro9,1 v: 1.0 serial: <filter>
  Chassis: type: 10 v: Mac-4B7AC7E43945597E serial: <filter>
  Mobo: Apple model: Mac-4B7AC7E43945597E v: MacBookPro9,1 serial: <filter>
  UEFI: Apple v: 233.0.0.0.0 date: 06/10/2020
  ID-1: BAT0 charge: 6.5 Wh condition: 69.0/75.2 Wh (92%) volts: 10.5/10.9
  model: SMP bq20z451 type: Li-ion serial: N/A status: Discharging
  cycles: 509
  Info: Quad Core model: Intel Core i7-3615QM bits: 64 type: MT MCP
  arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
  L2 cache: 6 MiB
  flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 36735
  Speed: 1197 MHz min/max: 1200/3300 MHz Core speeds (MHz): 1: 1197 2: 1197
  3: 1197 4: 1197 5: 1198 6: 1197 7: 1198 8: 1199
  Type: l1tf
  Type: srbds status: Vulnerable: No microcode
  Device-1: Intel 3rd Gen Core processor Graphics vendor: Apple driver: i915
  v: kernel bus ID: 00:02.0 chip ID: 8086:0166
  Device-2: NVIDIA GK107M [GeForce GT 650M Mac Edition] vendor: Apple
  driver: nouveau v: kernel bus ID: 01:00.0 chip ID: 10de:0fd5
  Device-3: Apple FaceTime HD Camera type: USB driver: uvcvideo
  bus ID: 1-1.1:3 chip ID: 05ac:8509 serial: <filter>
  Display: x11 server: X.Org 1.20.10 driver: intel,nouveau
  unloaded: modesetting alternate: fbdev,nv,vesa display ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1440x900 s-dpi: 96 s-size: 381x238mm (15.0x9.4")
  s-diag: 449mm (17.7")
  Monitor-1: LVDS-2 res: 1440x900 hz: 60 dpi: 111
  size: 331x207mm (13.0x8.1") diag: 390mm (15.4")
  OpenGL: renderer: NVE7 v: 4.3 Mesa 20.3.1 direct render: Yes
  Device-1: Intel 7 Series/C216 Family High Definition Audio
  driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1e20
  Device-2: NVIDIA GK107 HDMI Audio vendor: Apple driver: snd_hda_intel
  v: kernel bus ID: 01:00.1 chip ID: 10de:0e1b
  Sound Server: ALSA v: k5.10.2-2-MANJARO
  Device-1: Broadcom NetXtreme BCM57765 Gigabit Ethernet PCIe driver: tg3
  v: kernel port: 2000 bus ID: 02:00.0 chip ID: 14e4:16b4
  IF: enp2s0f0 state: down mac: <filter>
  Device-2: Broadcom BCM4331 802.11a/b/g/n vendor: Apple AirPort Extreme
  driver: bcma-pci-bridge v: N/A modules: bcma port: 2000 bus ID: 03:00.0
  chip ID: 14e4:4331
  IF-ID-1: wlp3s0b1 state: up mac: <filter>
  Local Storage: total: 465.76 GiB used: 10.56 GiB (2.3%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
  model: WDS500G2B0A-00SM50 size: 465.76 GiB block size: physical: 512 B
  logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 00WD
  ID-1: / raw size: 56.73 GiB size: 55.59 GiB (97.99%)
  used: 10.55 GiB (19.0%) fs: ext4 dev: /dev/sda3 maj-min: 8:3
  ID-2: /boot/efi raw size: 200 MiB size: 196.9 MiB (98.45%)
  used: 15.3 MiB (7.8%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  System Temperatures: cpu: 72.0 C mobo: N/A gpu: nouveau temp: 60.0 C
  Processes: 255 Uptime: 1m wakeups: 2 Memory: 15.57 GiB
  used: 1.37 GiB (8.8%) Init: systemd v: 247 Compilers: gcc: 10.2.0
  clang: 11.0.0 Packages: pacman: 1159 lib: 362 Shell: Bash v: 5.1.0
  running in: xfce4-terminal inxi: 3.2.01
Start with:
inxi -Fxxxza --no-host
Sorry, I’ve corrected it above. Thanks for suggesting.
Does it start overheating right away, 30 minutes, an hour? Is the CPU running full speed all of the time?
No. After I would say 30 minutes in. I am only surfing and I am sure it doesn’t take so much CPU usage.
Depends. If you stay on this forum - yes.
If you always have some youtube videos running - no.
I would recommend installing auto-cpufreq , try enabling hardware acceleration on your browser. Then report back…
I didn’t even know it was possible to boot linux to a macbook. Is this also possible with more current macbooks like 2018-2019 models? ( I knew it was possible to dual boot windows but didn’t know about linux)
You can not install Linux on T2 chip MacBooks
Not sure which ones those are but I know the next strife will be to get Linux installed on the new M1 chips.
T2 chip macs are 2016~2020
