PC (ideapad gaming 3 RTX 3050 ryzen 5 5600H laptop with integrated graphics) I run epic games via lutris, the control game automatically turns on at the average value of the graphics, when increasing to the maximum, some lags are observed, I placed different values of dxvk and much more in the lutris settings, but this does not help, I also suspect that discrete graphics does not work, because rtx and dlss technologies cannot be enabled in the control game settings, I simply cannot turn them on, all applications of the latest updates, what to do?
Anyway, run inxi -Fazy
and check if you use NVDIA proprietary driver or not by mhwd -l -d --pci
You need to install NVDIA proprietary driver by sudo mhwd -a pci nonfree 0300
Reference:
I entered something to check
mhwd -l -d --pci. ✔
Error: invalid option: --pci.
Usage: mhwd [OPTIONS] <config(s)>
--pci list only pci devices and driver configs
--usb list only usb devices and driver configs
-h/--help show help
-v/--version show version of mhwd
-f/--force force reinstallation
-d/--detail show detailed info for -l/-li/-lh
-l/--list list available configs for devices
-la/--listall list all driver configs
-li/--listinstalled list installed driver configs
-lh/--listhardware list hardware information
-i/--install <usb/pci> <config(s)> install driver config(s)
-ic/--installcustom <usb/pci> <path> install custom config(s)
-r/--remove <usb/pci> <config(s)> remove driver config(s)
-a/--auto <usb/pci> <free/nonfree> <classid> auto install configs for classid
--pmcachedir <path> set package manager cache path
--pmconfig <path> set package manager config
--pmroot <path> set package manager root
There’s an extra “.”
You can post the output of inxi
and mhwd
here.
mhwd -l -d --pci ✔
> PCI Device: /devices/pci0000:00/0000:00:01.2/0000:02:00.0 (0200:10ec:8168)
Network controller Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
> AVAILABLE:
ATTACHED: PCI
VERSION: 2016.04.20
INFO: RealTek RTL-8168 Gigabit Ethernet driver
PRIORITY: 0
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0200
VENDORIDS: 1186 10ec
> PCI Device: /devices/pci0000:00/0000:00:01.1/0000:01:00.0 (0302:10de:25a2)
Display controller nVidia Corporation GA107M [GeForce RTX 3050 Mobile]
> INSTALLED:
ATTACHED: PCI
VERSION: 2021.12.18
INFO: Hybrid prime solution for NVIDIA Optimus Technology - Closed source NVIDIA driver & open source amd driver.
PRIORITY: 8
FREEDRIVER: false
DEPENDS: video-linux
CONFLICTS: video*nvidia*
CLASSIDS: 0300 0302 0300
VENDORIDS: 10de 1002
ATTACHED: PCI
VERSION: 2018.05.04
INFO: Standard open source drivers.
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300 0380 0302
VENDORIDS: 1002 8086 10de
> AVAILABLE:
ATTACHED: PCI
VERSION: 2021.12.18
PRIORITY: 8
FREEDRIVER: false
ATTACHED: PCI
VERSION: 2021.12.18
PRIORITY: 7
FREEDRIVER: false
ATTACHED: PCI
VERSION: 2021.12.18
INFO: Closed source NVIDIA drivers for linux.
PRIORITY: 5
FREEDRIVER: false
DEPENDS: -
CLASSIDS: 0300 0302
VENDORIDS: 10de
ATTACHED: PCI
VERSION: 2021.12.18
PRIORITY: 4
FREEDRIVER: false
DEPENDS: -
CLASSIDS: 0300 0302
VENDORIDS: 10de
ATTACHED: PCI
VERSION: 2018.05.04
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
> PCI Device: /devices/pci0000:00/0000:00:08.1/0000:05:00.0 (0300:1002:1638)
Display controller ATI Technologies Inc Cezanne
> INSTALLED:
ATTACHED: PCI
VERSION: 2021.12.18
PRIORITY: 8
FREEDRIVER: false
ATTACHED: PCI
VERSION: 2018.05.04
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
> AVAILABLE:
ATTACHED: PCI
VERSION: 2021.12.18
PRIORITY: 8
FREEDRIVER: false
ATTACHED: PCI
VERSION: 2021.12.18
PRIORITY: 7
FREEDRIVER: false
ATTACHED: PCI
VERSION: 2018.05.04
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
ATTACHED: PCI
VERSION: 2020.01.13
INFO: modesetting video driver.
PRIORITY: 1
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
ATTACHED: PCI
VERSION: 2017.03.12
INFO: vesa video driver.
PRIORITY: 0
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
I removed the links to some website
I’m trying to enter the necessary information here , but the forum forbids entering links , and there are a lot of them there and not all are clear to me, I tried to send screenshots, but it 's also blocked , can we continue communicating elsewhere ?
Welcome to the forum!
Tip: When pasting terminal output on Discourse forums, one can either…
Use the Preformatted text </> toolbar button.
Add three backticks ` above and below the text (Markdown):
type or paste code here
Use HTML:
<pre><code>
</pre></code>
I’ve done it for you this time.
Also please edit your previous post rather than posting multiple times in a row.
To what is ‘Optimus launcher’ set in your launcher-settings?
Right-click on a launcher in Lutris:
→ Configure → activate “Show advanced options” (left bottom) → click to tab “System options”
and scroll down to “Optimus launcher” option. “Optimus launcher” is set to off by default.
There is also an option in the same tab which is called “Enable NVIDIA Prime Render Offload”
… please try to play around with these setting if not set by now.
thanks to everyone the problem is solved
@anon66942069. If other people have the same issue and read this it would be kind of you to share your solution. So you can help others.
