Lower resolution (960x540) on video-hybrid-intel-nvidia-390xx-bumblebee
again the same issue, i have no idea whats happening here… this just should not happen…
post output from:
pacman -Qs nvidia
chroot? or in the actual konsole?
    ~   pacman -Qs nvidia         ✔
local/egl-wayland 2:1.1.11-2
    EGLStream-based Wayland external platform
local/lib32-libvdpau 1.5-1
    Nvidia VDPAU library
local/libvdpau 1.5-1
local/libxnvctrl-390xx 390.154-1
    NVIDIA NV-CONTROL X extension
local/mhwd-nvidia 520.56.06-2
    MHWD module-ids for nvidia 520.56.06
local/mhwd-nvidia-390xx 390.154-2
    MHWD module-ids for nvidia 390.154
local/mhwd-nvidia-470xx 470.141.03-3
    MHWD module-ids for nvidia 470.141.03
local/xf86-video-nouveau 1.0.17-2 (xorg-drivers)
    Open Source 3D acceleration driver for nVidia cards
looks ok, so i dont understand why its happening…
so try this:
sudo pacman -S nvidia-390xx-utils lib32-nvidia-390xx-utils --overwrite '*'
then this:
sudo mhwd -i -f pci video-hybrid-intel-nvidia-390xx-bumblebee
    ~  sudo pacman -S nvidia-390xx-utils lib32-nvidia-390xx-utils --overwrite '*'                     ✔
[sudo] password for pergamin:
resolving dependencies...
Packages (2) lib32-nvidia-390xx-utils-390.154-1  nvidia-390xx-utils-390.154-2
Total Installed Size:  194,30 MiB
:: Proceed with installation? [Y/n] y
(2/2) checking keys in keyring                                     [####################################] 100%
(2/2) checking package integrity                                   [####################################] 100%
(2/2) loading package files                                        [####################################] 100%
(2/2) checking for file conflicts                                  [####################################] 100%
(2/2) checking available disk space                                [####################################] 100%
(1/2) installing nvidia-390xx-utils                                [####################################] 100%
==> If you run into trouble with CUDA not being available, run nvidia-modprobe first.
Optional dependencies for nvidia-390xx-utils
    xorg-server-devel: nvidia-xconfig
    opencl-nvidia-390xx: OpenCL support
(2/2) installing lib32-nvidia-390xx-utils                          [####################################] 100%
Optional dependencies for lib32-nvidia-390xx-utils
    lib32-opencl-nvidia
(1/6) Creating system user accounts...
(2/6) Reloading system manager configuration...
(3/6) Reloading device manager configuration...
(4/6) Arming ConditionNeedsUpdate...
(5/6) Refreshing PackageKit...
(6/6) Updating the desktop file MIME type cache...
    ~  nvidia-modprobe         ✔  7s 
    ~  sudo mhwd -i -f pci video-hybrid-intel-nvidia-390xx-bumblebee                                1 ✘
Error: invalid use of option: -i/--install
Usage: mhwd [OPTIONS] <config(s)>
  --pci                                 list only pci devices and driver configs
  --usb                                 list only usb devices and driver configs
  -h/--help                             show help
  -v/--version                          show version of mhwd
  -f/--force                            force reinstallation
  -d/--detail                           show detailed info for -l/-li/-lh
  -l/--list                             list available configs for devices
  -la/--listall                         list all driver configs
  -li/--listinstalled                   list installed driver configs
  -lh/--listhardware                    list hardware information
  -i/--install <usb/pci> <config(s)>    install driver config(s)
  -ic/--installcustom <usb/pci> <path>  install custom config(s)
  -r/--remove <usb/pci> <config(s)>     remove driver config(s)
  -a/--auto <usb/pci> <free/nonfree> <classid>  auto install configs for classid
  --pmcachedir <path>                   set package manager cache path
  --pmconfig <path>                     set package manager config
  --pmroot <path>                       set package manager root
and this:
sudo mhwd -i pci video-hybrid-intel-nvidia-390xx-bumblebee --force
It works! Reboot?
    ~  sudo mhwd -i pci video-hybrid-intel-nvidia-390xx-bumblebee --force                           1 ✘
> Installing video-hybrid-intel-nvidia-390xx-bumblebee...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-390xx-bumblebee/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
 core downloading...
 extra downloading...
 community downloading...
 multilib downloading...
:: Some packages should be upgraded first...
Packages (1) manjaro-keyring-20221028-2
Total Download Size:    0,53 MiB
Total Installed Size:   0,71 MiB
Net Upgrade Size:      -0,01 MiB
:: Retrieving packages...
 manjaro-keyring-20221028-2-any downloading...
error: failed retrieving file 'manjaro-keyring-20221028-2-any.pkg.tar.xz' from mirror1.cl.netactuate.com : The requested URL returned error: 404
warning: failed to retrieve some files
error: failed to commit transaction (failed to retrieve some files)
warning: nvidia-390xx-utils-390.154-2 is up to date -- skipping
warning: xf86-video-intel-1:2.99.917+916+g31486f40-2 is up to date -- skipping
warning: lib32-nvidia-390xx-utils-390.154-1 is up to date -- skipping
warning: dependency cycle detected:
warning: primus will be installed before its bumblebee dependency
Packages (7) primus-20151110-9  bumblebee-3.2.1-22  lib32-primus-20151110-4  linux510-bbswitch-0.8-169  linux510-nvidia-390xx-390.154-15  linux515-bbswitch-0.8-89  linux515-nvidia-390xx-390.154-18
Total Installed Size:  31,15 MiB
checking keyring...
checking package integrity...
loading package files...
checking for file conflicts...
checking available disk space...
installing primus...
installing bumblebee...
Don't forget to add yourself to the 'bumblebee' group to use Bumblebee
Optional dependencies for bumblebee
    xf86-video-nouveau: nouveau driver [installed]
    nouveau-dri: 3D acceleration features fo nouveau
    bbswitch: switch on/off discrete card [pending]
    nvidia: NVIDIA kernel driver [pending]
    virtualgl: alternative back-end for optirun
    lib32-virtualgl: run 32bit applications with optirun
    lib32-primus: faster back-end for optirun [pending]
installing lib32-primus...
installing linux510-nvidia-390xx...
installing linux510-bbswitch...
installing linux515-nvidia-390xx...
installing linux515-bbswitch...
(5/6) Updating module dependencies...
(6/6) Refreshing PackageKit...
bumblebee: install reason has been set to 'explicitly installed'
nvidia-390xx-utils: install reason has been set to 'explicitly installed'
xf86-video-intel: install reason has been set to 'explicitly installed'
lib32-primus: install reason has been set to 'explicitly installed'
lib32-nvidia-390xx-utils: install reason has been set to 'explicitly installed'
linux510-nvidia-390xx: install reason has been set to 'explicitly installed'
linux510-bbswitch: install reason has been set to 'explicitly installed'
linux515-nvidia-390xx: install reason has been set to 'explicitly installed'
linux515-bbswitch: install reason has been set to 'explicitly installed'
xorg configuration file: '/etc/X11/mhwd.d/intel.conf'
Created symlink /etc/systemd/system/multi-user.target.wants/bumblebeed.service → /usr/lib/systemd/system/bumblebeed.service.
> Successfully installed video-hybrid-intel-nvidia-390xx-bumblebee
yes reboot and hopefully you dont end up with a black screen
Man, it works!!!
But, I receive a message in nvidia settings:
"You do not appear to be using the NVIDIA X driver. Please edit your X configuration file (just run `nvidia-config`as root), and restart the X server.
I execute sudo mvidia-config and nothing happen.
post output from:
inxi -G
May I have to uninstall video-linux?
    ~  mhwd -l         ✔
> 0000:01:00.0 (0300:10de:0fe4) Display controller nVidia Corporation:
video-hybrid-intel-nvidia-390xx-bumblebee            2021.11.26               false            PCI
    video-nvidia-390xx            2021.11.26               false            PCI
           video-linux            2018.05.04                true            PCI
> 0000:00:02.0 (0300:8086:0416) Display controller Intel Corporation:
    ~  mhwd -li         ✔
> Installed PCI configs:
    ~   inxi -G         ✔
  Device-1: Intel 4th Gen Core Processor Integrated Graphics driver: i915
    v: kernel
  Device-2: NVIDIA GK107M [GeForce GT 750M] driver: N/A
  Device-3: Realtek Lenovo EasyCamera type: USB driver: uvcvideo
  Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3 driver: X:
    loaded: intel dri: i965 gpu: i915 resolution: 1: 1440x900~60Hz
    2: 1366x768~60Hz
  OpenGL: renderer: Mesa Intel HD Graphics 4600 (HSW GT2) v: 4.6 Mesa
    22.1.7
no, dont uninstall it…
the nvidia driver is not available…
output from:
sudo cat /proc/acpi/bbswitch
    ~   sudo cat /proc/acpi/bbswitch         ✔
0000:01:00.0 OFF
so checked the arch wiki and you need to add a kernel parameter:
kate /etc/default/grub
and in this line GRUB_CMDLINE_LINUX_DEFAULT inside the quotes add this parameter:
pcie_port_pm=off
add it to existing parameters, dont remove anything from there, save the file, update grub:
sudo update-grub
reboot and post output from:
inxi -G
    v: kernel
    2: 1366x768~60Hz
    22.1.7
But, now I have another problem. I configure with autologin and I cannot acces to desktop, it seems like GNome activities, how I can back to normal?
so how did you posted the inxi -G output if you cant access the desktop?
Yes, but Gnome like desktop. Its weird.
what do you mean gnome like, post screenshot
