karam
17 November 2020 03:27
1
Hi,
can you help me ?
Low disk space on “Filesystem root” 0 bytes disk
~ >>> df -h
df: /run/user/1000/doc: Operation not permitted
Filesystem Size Used Avail Use% Mounted on
dev 3.9G 0 3.9G 0% /dev
run 3.9G 1.7M 3.9G 1% /run
/dev/sda4 9.8G 9.3G 84K 100% /
tmpfs 3.9G 84M 3.8G 3% /dev/shm
tmpfs 4.0M 0 4.0M 0% /sys/fs/cgroup
tmpfs 3.9G 47M 3.8G 2% /tmp
/dev/loop1 31M 31M 0 100% /var/lib/snapd/snap/snapd/9721
/dev/loop4 56M 56M 0 100% /var/lib/snapd/snap/core18/1932
/dev/loop2 52M 52M 0 100% /var/lib/snapd/snap/icloud-notes-linux-client/10
/dev/loop3 163M 163M 0 100% /var/lib/snapd/snap/gnome-3-28-1804/145
/dev/loop0 63M 63M 0 100% /var/lib/snapd/snap/gtk-common-themes/1506
/dev/sda1 197M 60M 138M 31% /boot/efi
tmpfs 787M 148K 787M 1% /run/user/1000
cscs
17 November 2020 04:02
2
You ran out of space. Delete stuff.
PS … for more help … usually start here:
This tutorial is superseded by this one. Remember all Tutorials are wiki posts that can be edited by TL2 (Trust Level 2) members and above.
Welcome to Manjaro!
To allow all of us helpful people on this forum TO HELP YOU, we need some basic information about your system. This probably means you described the symptoms of your problem, but now we need some more information to know where the origin of your issue is exactly.
Someone else probably linked you to…
You can free up space by removing log files mostly, if that is not enough try uninstalling some apps/games that you installed manually…
Also always provide info needed as instructed by cscs above when you ask help without providing enough info around what/why you need it.
Strit
17 November 2020 04:45
4
10 GB for a root filesystem is a bit on the low side and will require some maintainance to keep going.
You can also remove packages from cache, by doing sudo pacman -Sc, which will remove all packages from cache, except those that are installed.
karam
17 November 2020 12:40
5
@Strit @cscs is there any way to expand the /dev/sda4 Size ?
Depends on your HD that is labeled as sda, pls supply output of sudo fdisk -l /dev/sda
karam
17 November 2020 21:07
7
Thank you @TriMoon
~ >>> sudo fdisk -l /dev/sda
Disk /dev/sda: 698.64 GiB, 750156374016 bytes, 1465149168 sectors
Disk model: APPLE HDD HTS547
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: B8C71D86-1EDF-4C6D-AF74-D7E87DC83FCB
Device Start End Sectors Size Type
/dev/sda1 40 409639 409600 200M EFI System
/dev/sda2 411648 1074524127 1074112480 512.2G Apple APFS
/dev/sda3 1074524128 1444177608 369653481 176.3G Apple APFS
/dev/sda4 1444177610 1465149127 20971518 10G Linux filesystem
Partition 4 does not start on physical sector boundary.
this is my macbook pro 2012
/dev/sda have sda1 sda2 and sda3
i installed manjaro in sda3 but manjaro OS create sda4 automaticly
Sorry i do not write english well
cscs
18 November 2020 01:03
8
It seems thats all you left it.
I dont know what you have on sda3 … but manjaro root (the whole system) was installed on sda4 with only 10g left … so you would need to cut some space out from sda3.
(fair warning - resizing partitions always brings potential for fragmentation and data loss)
karam
18 November 2020 11:37
9
Thanks for all
i fix this by " gparted " app and live CD
1: resize some space
2: form live cd use gparted to resize partition to space
