I’m new to this .pacnew game and therefore pacdiff -o lists a bunch of .pacnew files I haven’t paid attention to since I installed Manjaro last year.
I’m currently checking those files with DIFFPROG=meld pacdiff -s and came across /etc/default/grub.pacnew. It looks like there’s a lot of formatting changes to the file which go back to a commit from 11 months ago. A lot of text passages get moved to different lines or rewritten/improved.
The only notable difference apart for the reformatting/reshuffling of text are two lines.
Is this correct/still valid today? My CMDLINE doesn’t have a resume_offset like the one in the old forum topic though. I haven’t made any changes to /etc/default/grub since installation. I wonder why Manjaro adds everything into GRUB_CMDLINE_LINUX_DEFAULT then.
Apart from that I also vaguely remember reading somewhere about having to do another step when messing around with grub files. What do I have to do in case I make all these changes to /etc/default/grub? Or am I confusing this with /boot/grub/grub.cfg
Both those changes should be acceptable, and they are the defaults.
You can check if you have that file for the theme first. ex
ls /usr/share/grub/themes/
But the options also arent a requirement
splash is for boot splash things like plymouth
apparmor is for … apparmor (access control security, notably for SNAPs)
resume is for hibernation
In my case I dont use any of those things so I dont use any of those options.
That is something I would suggest … but these arent custom … these are the upstream defaults. So add them where they are on DEFAULT.
(you would want to put extra things you want to add, like nowatchdog, on the second line)
This would be
sudo grub-mkconfig -o /boot/grub/grub.cfg
(equivalent to sudo update-grub, which is no longer included by default)
First - the path is hardcoded … so what happens if your grub config file is not at exactly /boot/grub/grub.cfg ?
Second - Its only ‘simpler’ in that the literal text typed is shorter in this example … but as far as package dependencies, and the local filesystem go … its more complicated and ‘messy’ … this does the job of an alias by having a whole package and extra bin script to provide functionality already present from existing tools.
You are free to keep the package and use it.
(up til now there was still some work to be done with mhwd having update-grub as a hard dependency in the code, but thats arguably a different topic)
Or in some future where thats the way, and update-grub does not exist … again, I think an alias makes more sense. ex
~/.bashrc
alias update-grub="grub-mkconfig -o /boot/grub/grub.cfg"
An alias is just a replacement.
The above example, when placed in a relevant file, like your shells rc file (.bashrc, .zshrc, etc) would act very much like the previous package … typing
sudo update-grub
would then be the same as
And, yes, this means you could augment it any number of ways, including a different path.
Some people use aliases to change the default function of a command.
If you check your shellrc file you will probably notice something like
alias grep="grep --color=auto"
Which would mean whenever you use grep its actually the listed command, so grep always shows color.
Similarly people use it for their preferred update string, ex:
Not sure how you did that .. but in this example it would be the same path whether you had a partition mounted to /boot or not (still is /boot/grub/grub.cfg unless something else changed).
For what its worth .. when I changed /boot/efi to /efi I just changed the fstab entry (after creating the relevant directory) .. in your case it sounds like you would just .. remove the entry, with /boot just mounted along with / as usual. Hard to say without looking.
I’ve checked and the file /usr/share/grub/themes/manjaro/theme.txt exists. So I’ve kept GRUB_THEME from the original grub file.
Thanks for elaborating. Good to know what these options stand for.
Glad I asked for clarifiation. Since these are upstream defaults as you say, I made no changes and let them live in GRUB_CMDLINE_LINUX_DEFAULT
I checked and update-grub is installed on my system. After all the necessary changes to /etc/default/grub I decided to use your grub-mkconfig command though. Not gonna lie, I held my breath when rebooting but I’m glad to report everything went fine.
Does any of these files also require some additional steps (similar to grub-mkconfig for /etc/default/grub) after making the changes? Especially asking for pamac.conf and pacman.conf since I’ve read somewhere in the forum you can badly screw up your system when messing with these config files.
