Hello,
I’m new to the forum and relatively new to linux, and I really wish I came up with a better title for this, but I hope this describes it. Also I hope I formattet the logs right…
basic information:
manjaro
stable
kde plasma
kernel 5.9.16-1
how the errors appeared:
I didn’t run manjaro for two weeks and got a lot of updates on packages and the kernel (5.10.2-2) in pamac. I ran all of them (1.8 GB as orientation, idk) and at the end I got a massive list of errors. As most of them seem to point to the kernel I hope I’m in the right category.
what I did:
I googled some of them and most pointed to people that can’t boot after some kernel update. I really wish to avoid that and did not reboot jet.
The most concerning error for me is Error while configuring manjaro-system
(full error-list below). The rest of the errors all are the type of
Warning: <sth>: /usr/lib/modules/5.10.2-2-MANJARO/kernel/<sth> already existed in filesystem It has been backed up to <sth>
and could just indicate, that kernel stuff is being backed up… but why is it a warning then?
I also tried checking the pacman log and found 5 errors, but nothing helps. One is really unspecific and the other 4 are about kernel 5.8.18-1 so probably unrelevant. Its over a thousand lines long so I included a section at the end.
my concern:
Are those errors critical to boot ('cause googleing seems to point to that)? Can I find out more?
I hope someone could help me out. I’m not really a noob but can’t find any instructions how to fix this and the very unspecific errors don’t lead me anywhere either.
Thanks for everyone who read that and might help.
logs/errors:
pamac “warning” window extract
logfile
Warning: linux510: /boot/linux510-x86_64.kver already existed in filesystem
It has been backed up to /boot/linux510-x86_64.kver.old
Warning: linux510: /usr/lib/modules/5.10.2-2-MANJARO/build/vmlinux already existed in filesystem
It has been backed up to /usr/lib/modules/5.10.2-2-MANJARO/build/vmlinux.old
Warning: linux510: /usr/lib/modules/5.10.2-2-MANJARO/extramodules already existed in filesystem
It has been backed up to /usr/lib/modules/5.10.2-2-MANJARO/extramodules.old
Warning: linux510: /usr/lib/modules/5.10.2-2-MANJARO/kernel/arch/x86/crypto/aegis128-aesni.ko.xz already existed in filesystem
It has been backed up to /usr/lib/modules/5.10.2-2-MANJARO/kernel/arch/x86/crypto/aegis128-aesni.ko.xz.old
Warning: linux510: /usr/lib/modules/5.10.2-2-MANJARO/kernel/arch/x86/crypto/aesni-intel.ko.xz already existed in filesystem
It has been backed up to /usr/lib/modules/5.10.2-2-MANJARO/kernel/arch/x86/crypto/aesni-intel.ko.xz.old
Warning: linux510: /usr/lib/modules/5.10.2-2-MANJARO/kernel/arch/x86/crypto/blake2s-x86_64.ko.xz already existed in filesystem
It has been backed up to /usr/lib/modules/5.10.2-2-MANJARO/kernel/arch/x86/crypto/blake2s-x86_64.ko.xz.old
Warning: linux510: /usr/lib/modules/5.10.2-2-MANJARO/kernel/arch/x86/crypto/blowfish-x86_64.ko.xz already existed in filesystem
It has been backed up to /usr/lib/modules/5.10.2-2-MANJARO/kernel/arch/x86/crypto/blowfish-x86_64.ko.xz.old
Warning: linux510: /usr/lib/modules/5.10.2-2-MANJARO/kernel/arch/x86/crypto/camellia-aesni-avx-x86_64.ko.xz already existed in filesystem
It has been backed up to /usr/lib/modules/5.10.2-2-MANJARO/kernel/arch/x86/crypto/camellia-aesni-avx-x86_64.ko.xz.old
Warning: linux510: /usr/lib/modules/5.10.2-2-MANJARO/kernel/arch/x86/crypto/camellia-aesni-avx2.ko.xz already existed in filesystem
It has been backed up to /usr/lib/modules/5.10.2-2-MANJARO/kernel/arch/x86/crypto/camellia-aesni-avx2.ko.xz.old
logfile
Warning: linux510: /usr/lib/modules/5.10.2-2-MANJARO/modules.order already existed in filesystem
It has been backed up to /usr/lib/modules/5.10.2-2-MANJARO/modules.order.old
Warning: linux510: /usr/lib/modules/5.10.2-2-MANJARO/modules.softdep already existed in filesystem
It has been backed up to /usr/lib/modules/5.10.2-2-MANJARO/modules.softdep.old
Warning: linux510: /usr/lib/modules/5.10.2-2-MANJARO/modules.symbols already existed in filesystem
It has been backed up to /usr/lib/modules/5.10.2-2-MANJARO/modules.symbols.old
Warning: linux510: /usr/lib/modules/5.10.2-2-MANJARO/modules.symbols.bin already existed in filesystem
It has been backed up to /usr/lib/modules/5.10.2-2-MANJARO/modules.symbols.bin.old
Warning: linux510: /usr/lib/modules/5.10.2-2-MANJARO/pkgbase already existed in filesystem
It has been backed up to /usr/lib/modules/5.10.2-2-MANJARO/pkgbase.old
Warning: linux510: /usr/lib/modules/5.10.2-2-MANJARO/vmlinuz already existed in filesystem
It has been backed up to /usr/lib/modules/5.10.2-2-MANJARO/vmlinuz.old
Warning: linux510: /usr/lib/modules/extramodules-5.10-MANJARO/version already existed in filesystem
It has been backed up to /usr/lib/modules/extramodules-5.10-MANJARO/version.old
Warning: mhwd-nvidia: /var/lib/mhwd/ids/pci/nvidia.ids already existed in filesystem
It has been backed up to /var/lib/mhwd/ids/pci/nvidia.ids.old
Warning: mhwd-db: /var/lib/mhwd/db/pci/graphic_drivers/hybrid-amd-nvidia-prime/MHWDCONFIG already existed in filesystem
It has been backed up to /var/lib/mhwd/db/pci/graphic_drivers/hybrid-amd-nvidia-prime/MHWDCONFIG.old
Warning: mhwd-db: /var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-prime/MHWDCONFIG already existed in filesystem
It has been backed up to /var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-prime/MHWDCONFIG.old
Warning: mhwd-db: /var/lib/mhwd/db/pci/graphic_drivers/nvidia/MHWDCONFIG already existed in filesystem
It has been backed up to /var/lib/mhwd/db/pci/graphic_drivers/nvidia/MHWDCONFIG.old
A restart is required for the changes to take effect.
/var/log/pacman.log extract (not the 5.8.18-1 errors)
logfile
[2021-01-08T16:57:53+0100] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.9-x86_64-fallback.img
[2021-01-08T16:57:57+0100] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-01-08T16:57:57+0100] [ALPM-SCRIPTLET] error: command failed to execute correctly
[2021-01-08T16:57:57+0100] [ALPM-SCRIPTLET] e[1;1me[1;32m==>e[1;0me[1;1m Checking if graphic drivers need an update ...e[1;0m
[2021-01-08T16:57:57+0100] [ALPM-SCRIPTLET] e[1;1me[1;32m==>e[1;0me[1;1m Removing EOL kernel 5.7.xe[1;0m
