Lots of applications refuse to start (VLC, SSR, Graphical software management Network manager...)
Hello friendly helpers,
I have several issues linked to the same problem but i dont seem to find a solution so i hope you all will be able to help.
Little by little the problem got worse: at first SSR wont start so i tried to start it via the terminal and have this answer: Bus error (core dumped)
So i restart the computer a few times until it works.
After that VLC follows, same error message :
VLC media player 3.0.13 Vetinari (revision 3.0.12.1-158-g6977abc430)
Same workaround: after a few reboot it seem to works
Then i realize that if SSR doesnt start none of the video application will start even if i try to install new ones, none of the music application wont start either but everything else works fine.
After a while it s the turn of the Network manager to bug, it doesnt seem to recognize my ethernet connexion, same workaround a few restarts and it works fine.
Now it doesnt work at all whatever i do none of the video apps launch and the network manager never starts and now dolphin says that kdeinit5 seems be in troubles (10 error messages in a row)
The only way i found to have internet is by disabling Network manager in the terminal and activating dhcpcd.
Now a new symptom is that the graphical software manager wont start either.
Last week i did this :
sudo pacman -Scc
439 vlc
440 sudo pacman -Qdt
441 sudo pacman -Sc
442 find ~/.cache/ -type f -atime +100 -delete
443 sudo journalctl --vacuum-size=50M
444 pamac remove --orphans
445 pamac clean --build-files
446 sudo pamac remove --orphans
447 sudo pacman -Syu
448 sudo pacman -S plasma kf5
without success
I installed gnome yesterday same problems but when i restarted kde plasma everything worked fine again.
This morning again same problem so i decided to seek for help.
Thanks for reading me and helping me.
 *-display
       description: VGA compatible controller
       product: GK208B [GeForce GT 710]
       vendor: NVIDIA Corporation
       physical id: 0
       bus info: pci@0000:01:00.0
       version: a1
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
       configuration: driver=nvidia latency=0
       resources: irq:44 memory:fa000000-faffffff memory:d0000000-d7ffffff memory:d8000000-d9ffffff ioport:e000(size=128) memory:c0000-dffff
  *-display
       description: Display controller
       product: 2nd Generation Core Processor Family Integrated Graphics Controller
       vendor: Intel Corporation
       physical id: 2
       bus info: pci@0000:00:02.0
       version: 09
       width: 64 bits
       clock: 33MHz
       capabilities: msi pm bus_master cap_list
       configuration: driver=i915 latency=0
       resources: irq:31 memory:fb400000-fb7fffff memory:c0000000-cfffffff ioport:f000(size=64)
  Kernel: 5.12.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64
  root=UUID=9ce18fce-9a7b-4d84-a2ab-481543288475 rw quiet splash apparmor=1
  security=apparmor resume=UUID=97c30645-15fa-4305-b4a3-0f9ca4abd220
  udev.log_priority=3
  Console: tty pts/1 wm: kwin_x11 DM: GDM 40.0 Distro: Manjaro Linux
  base: Arch Linux
  Type: Desktop Mobo: Intel model: DQ67SW v: AAG12527-310 serial: <filter>
  BIOS: Intel v: SWQ6710H.86A.0069.2018.0410.1438 date: 04/10/2018
  RAM: total: 15.52 GiB used: 2.98 GiB (19.2%)
  Array-1: capacity: 32 GiB slots: 4 EC: None max-module-size: 8 GiB
  note: est.
  Device-1: Channel A DIMM 0 size: 4 GiB speed: 1333 MT/s type: DDR3
  detail: synchronous bus-width: 64 bits total: 64 bits manufacturer: Kingston
  part-no: 9905474-040.A00LF serial: <filter>
  Device-2: Channel A DIMM 1 size: 4 GiB speed: 1333 MT/s type: DDR3
  part-no: 99U5474-028.A00LF serial: <filter>
  Device-3: Channel B DIMM 0 size: 4 GiB speed: 1333 MT/s type: DDR3
  Device-4: Channel B DIMM 1 size: 4 GiB speed: 1333 MT/s type: DDR3
  Info: Quad Core model: Intel Core i7-2600 socket: BGA1155 (SKTH) note: check
  bits: 64 type: MT MCP arch: Sandy Bridge family: 6 model-id: 2A (42)
  stepping: 7 microcode: 2F cache: L1: 256 KiB L2: 8 MiB L3: 8 MiB
  bogomips: 54296
  Speed: 1870 MHz min/max: 1600/3800 MHz base/boost: 3400/3800 volts: 1.1 V
  ext-clock: 100 MHz Core speeds (MHz): 1: 1870 2: 1723 3: 1596 4: 1596
  5: 1596 6: 1596 7: 1622 8: 1596
  Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
  constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est
  flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce md_clear
  mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
  pebs pge pln pni popcnt pse pse36 pti pts rdtscp rep_good sep smx ssbd sse
  sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
  tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
  Type: l1tf
  Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
  driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0102 class-ID: 0380
  Device-2: NVIDIA GK208B [GeForce GT 710] vendor: ASUSTeK driver: nvidia
  v: 460.80 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:128b
  class-ID: 0300
  Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
  bus-ID: 1-1.1.1:5 chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
  Display: server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: nvidia
  display-ID: :1 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 93 s-size: 524x301mm (20.6x11.9")
  s-diag: 604mm (23.8")
  Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 94 size: 521x293mm (20.5x11.5")
  diag: 598mm (23.5")
  OpenGL: renderer: GeForce GT 710/PCIe/SSE2 v: 4.6.0 NVIDIA 460.80
  direct render: Yes
  driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20
  class-ID: 0403
  Device-2: NVIDIA GK208 HDMI/DP Audio vendor: ASUSTeK driver: snd_hda_intel
  v: kernel bus-ID: 01:00.1 chip-ID: 10de:0e0f class-ID: 0403
  Sound Server-1: ALSA v: k5.12.2-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.28 running: yes
  Device-1: Intel 82579LM Gigabit Network driver: e1000e v: kernel port: f080
  bus-ID: 00:19.0 chip-ID: 8086:1502 class-ID: 0200
  IP v6: <filter> type: dynamic mngtmpaddr noprefixroute scope: global
  IP v6: <filter> scope: link
  vendor: TP-LINK TG-3468 driver: r8169 v: kernel port: d000 bus-ID: 03:00.0
  driver: btusb v: 0.8 bus-ID: 2-1.5:3 chip-ID: 0a12:0001 class-ID: e001
  Local Storage: total: 2.85 TiB used: 1.14 TiB (40.2%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD2002FYPS-01U1B1
  family: RE4-GP size: 1.82 TiB block-size: physical: 512 B logical: 512 B
  sata: 2.6 speed: 3.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 5G05
  temp: 45 C scheme: MBR
  SMART: yes state: enabled health: PASSED on: 4y 276d 16h cycles: 8222
  ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD PM800 2.5 128GB
  family: based SSDs size: 119.24 GiB block-size: physical: 512 B
  logical: 512 B speed: 3.0 Gb/s rotation: SSD serial: <filter> rev: 5D1Q
  scheme: MBR
  SMART: yes state: enabled health: PASSED on: 2y 196d 7h cycles: 9731
  ID-3: /dev/sdc maj-min: 8:32 vendor: SanDisk model: SSD PLUS 1000GB
  family: Marvell based SSDs size: 931.52 GiB block-size: physical: 512 B
  logical: 512 B sata: 3.2 speed: 3.0 Gb/s rotation: SSD serial: <filter>
  rev: 00RL temp: 33 C scheme: MBR
  SMART: yes state: enabled health: PASSED on: 147d 5h cycles: 671
  Optical-1: /dev/sr0 vendor: hp model: CDDVDW SH-216BB rev: HE50
  dev-links: cdrom
  Features: speed: 40 multisession: yes audio: yes dvd: yes
  ID-1: / raw-size: 914.43 GiB size: 899.08 GiB (98.32%)
  used: 407.09 GiB (45.3%) fs: ext4 block-size: 4096 B dev: /dev/sdc1
  maj-min: 8:33 label: N/A uuid: 9ce18fce-9a7b-4d84-a2ab-481543288475
  ID-2: /run/media/_3abd/6626322a-742f-446c-bf64-fdfcb5965995
  raw-size: 883.07 GiB size: 868.21 GiB (98.32%) used: 762.82 GiB (87.9%)
  fs: ext4 block-size: 4096 B dev: /dev/sda2 maj-min: 8:2 label: N/A
  uuid: 6626322a-742f-446c-bf64-fdfcb5965995
  ID-1: swap-1 type: partition size: 17.08 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/sdc2 maj-min: 8:34 label: N/A
  uuid: 97c30645-15fa-4305-b4a3-0f9ca4abd220
  ID-1: /dev/sda1 maj-min: 8:1 size: 979.95 GiB fs: ext4 label: N/A
  uuid: 6db9f21f-6343-4b10-98b3-c71c0b4250da
  ID-2: /dev/sdb1 maj-min: 8:17 size: 549 MiB fs: ntfs
  label: R\xc3\xa9serv\xc3\xa9 au syst\xc3\xa8me uuid: EC20B97320B944FC
  ID-3: /dev/sdb2 maj-min: 8:18 size: 118.15 GiB fs: ntfs label: N/A
  uuid: 60B4BCD5B4BCAEC2
  ID-4: /dev/sdb3 maj-min: 8:19 size: 561 MiB fs: ntfs label: N/A
  uuid: 388CC3CA8CC380BC
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 3 rev: 2.0
  speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
  Hub-3: 1-1.1:3 info: Huasheng USB2.0 HUB ports: 4 rev: 2.0 speed: 480 Mb/s
  power: 100mA chip-ID: 214b:7250 class-ID: 0900
  Device-1: 1-1.1.1:5 info: Logitech Webcam C270 type: Video,Audio
  power: 500mA chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
  Device-2: 1-1.1.2:6 info: [Maxxter] Optical Gaming Mouse [Xtrem]
  type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 2 rev: 1.1
  speed: 1.5 Mb/s power: 100mA chip-ID: 18f8:0f97 class-ID: 0300
  Device-3: 1-1.1.4:7 info: Genesys Logic microSD Card Reader
  type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
  speed: 480 Mb/s power: 98mA chip-ID: 05e3:0751 class-ID: 0806
  Device-4: 1-1.2:4 info: IBM NetVista Full Width Keyboard type: Keyboard
  driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
  power: 70mA chip-ID: 04b3:3025 class-ID: 0301
  Hub-4: 2-0:1 info: Full speed (or root) Hub ports: 3 rev: 2.0
  Hub-5: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
  Device-1: 2-1.5:3 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
  type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
  Device-2: 2-1.6:4 info: Alcor Micro AU6477 Card Reader Controller
  type: Mass Storage,HID driver: hid-generic,usb-storage,usbhid interfaces: 2
  rev: 2.0 speed: 480 Mb/s power: 250mA chip-ID: 058f:6364 class-ID: 0300
  serial: <filter>
  Hub-6: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-7: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 45.0 C mobo: N/A gpu: nvidia temp: 60 C
  Processes: 282 Uptime: 47m wakeups: 0 Init: systemd v: 247 tool: systemctl
  Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: 1813 pacman: 1806 lib: 475
  flatpak: 0 snap: 7 Shell: Bash (sudo) v: 5.1.8 running-in: yakuake
  inxi: 3.3.04
  1. Never run pamac as root: it has its own built-in authentication. (This specific command is no biggie though :sweat_smile: )
  2. Does this also happen when you create a new user and log in there? (E.G. najib2)
  3. If that doesn’t “solve” the problem, Please read this:
    [HowTo] Provide System Information
    and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
  4. An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
    Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
:+1:
Ok ok i didnt know that
Yes it does, i created a new user when i installed gnome to test if it was a bug in the environment but it s exactly the same issue with the new user and in gnome.
I did :sweat_smile: i m gonna check it again
that is exactly what i did. Doesn’t it appear?
here it is again :
sudo inxi --full --admin --verbosity=7 --filter --no-host --width
[sudo] Mot de passe de _3abd :
  udev.log_priority=3
  Console: tty pts/2 wm: kwin_x11 DM: GDM 40.0 Distro: Manjaro Linux
  base: Arch Linux
  RAM: total: 15.52 GiB used: 2.82 GiB (18.2%)
  note: est.
  bogomips: 54298
  Speed: 2138 MHz min/max: 1600/3800 MHz base/boost: 3400/3800 volts: 1.1 V
  ext-clock: 100 MHz Core speeds (MHz): 1: 2138 2: 1596 3: 1597 4: 2954
  5: 1595 6: 1596 7: 1929 8: 1626
  Type: l1tf
  class-ID: 0300
  diag: 598mm (23.5")
  direct render: Yes
  class-ID: 0403
  Local Storage: total: 2.85 TiB used: 407.26 GiB (14.0%)
  temp: 37 C scheme: MBR
  SMART: yes state: enabled health: PASSED on: 4y 278d 2h cycles: 8227
  scheme: MBR
  SMART: yes state: enabled health: PASSED on: 2y 197d 17h cycles: 9736
  rev: 00RL temp: 29 C scheme: MBR
  SMART: yes state: enabled health: PASSED on: 147d 13h cycles: 676
  dev-links: cdrom
  used: 407.26 GiB (45.3%) fs: ext4 block-size: 4096 B dev: /dev/sdc1
  ID-2: /dev/sda2 maj-min: 8:2 size: 883.07 GiB fs: ext4 label: N/A
  ID-3: /dev/sdb1 maj-min: 8:17 size: 549 MiB fs: ntfs
  ID-4: /dev/sdb2 maj-min: 8:18 size: 118.15 GiB fs: ntfs label: N/A
  ID-5: /dev/sdb3 maj-min: 8:19 size: 561 MiB fs: ntfs label: N/A
  serial: <filter>
  System Temperatures: cpu: 40.0 C mobo: N/A gpu: nvidia temp: 56 C
  Processes: 282 Uptime: 21m wakeups: 0 Init: systemd v: 247 tool: systemctl
  inxi: 3.3.04
thanks again for your help
I missed the scroll bar! Sorry!
Stop running everything with sudo!
Only use sudo when you actually need it! No wonder your system has weird problems!
:scream:
What’s he output of:
smartctl --all /dev/sdc
journalctl --system --boot=0 --priority=3 | tail
xdg-open Path/To/Any/Videofile.mp4
:question:
That 's ok
Actually it s true that i often use sudo but most of the time is because the system ask me to.
Here without the sudo some informations werent displayed that s why i used it.
For example without the sudo:
So you agree those problems are weird…
[_3abd@3abd-pc ~]$ smartctl --all /dev/sdc
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.12.2-1-MANJARO] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
Probable ATA device behind a SAT layer
Try an additional '-d ata' or '-d sat' argument.
[_3abd@3abd-pc ~]$ smartctl --all /dev/sdc -dsat
Read Device Identity failed: Operation not permitted
A mandatory SMART command failed: exiting. To continue, add one or more '-T permissive' options.
[_3abd@3abd-pc ~]$ smartctl --all /dev/sdc -d ata
Read Device Identity failed: Permission denied
[_3abd@3abd-pc ~]$ sudo smartctl --all /dev/sdc -d ata
=== START OF INFORMATION SECTION ===
Model Family:     Marvell based SanDisk SSDs
Device Model:     SanDisk SSD PLUS 1000GB
Serial Number:    190529802400
LU WWN Device Id: 5 001b44 8b92dc998
Firmware Version: UH5100RL
User Capacity:    1.000.207.286.272 bytes [1,00 TB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    Solid State Device
Form Factor:      2.5 inches
TRIM Command:     Available, deterministic
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ACS-2 T13/2015-D revision 3
SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Sun Jun  6 21:12:18 2021 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
                                        Auto Offline Data Collection: Disabled.
Self-test execution status:      (   0) The previous self-test routine completed
                                        without error or no self-test has ever
                                        been run.
Total time to complete Offline
data collection:                (  120) seconds.
capabilities:                    (0x15) SMART execute Offline immediate.
                                        No Auto Offline data collection support.
                                        Abort Offline collection upon new
                                        command.
                                        No Offline surface scan supported.
                                        Self-test supported.
                                        No Conveyance Self-test supported.
                                        No Selective Self-test supported.
SMART capabilities:            (0x0003) Saves SMART data before entering
                                        power-saving mode.
                                        Supports SMART auto save timer.
Error logging capability:        (0x01) Error logging supported.
                                        General Purpose Logging supported.
Short self-test routine
recommended polling time:        (   2) minutes.
Extended self-test routine
recommended polling time:        ( 182) minutes.
SMART Attributes Data Structure revision number: 1
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  5 Reallocated_Sector_Ct   0x0032   100   100   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       3542
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       676
165 Total_Write/Erase_Count 0x0032   100   100   000    Old_age   Always       -       772
166 Min_W/E_Cycle           0x0032   100   100   ---    Old_age   Always       -       4
167 Min_Bad_Block/Die       0x0032   100   100   ---    Old_age   Always       -       0
168 Maximum_Erase_Cycle     0x0032   100   100   ---    Old_age   Always       -       9
169 Total_Bad_Block         0x0032   100   100   ---    Old_age   Always       -       1203
170 Unknown_Marvell_Attr    0x0032   100   100   ---    Old_age   Always       -       0
171 Program_Fail_Count      0x0032   100   100   000    Old_age   Always       -       0
172 Erase_Fail_Count        0x0032   100   100   000    Old_age   Always       -       0
173 Avg_Write/Erase_Count   0x0032   100   100   000    Old_age   Always       -       4
174 Unexpect_Power_Loss_Ct  0x0032   100   100   000    Old_age   Always       -       162
184 End-to-End_Error        0x0032   100   100   ---    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       4604
188 Command_Timeout         0x0032   100   100   ---    Old_age   Always       -       0
194 Temperature_Celsius     0x0022   064   060   000    Old_age   Always       -       36 (Min/Max 12/60)
199 SATA_CRC_Error          0x0032   100   100   ---    Old_age   Always       -       0
230 Perc_Write/Erase_Count  0x0032   100   100   000    Old_age   Always       -       532 80 532
232 Perc_Avail_Resrvd_Space 0x0033   100   100   005    Pre-fail  Always       -       100
233 Total_NAND_Writes_GiB   0x0032   100   100   ---    Old_age   Always       -       4231
234 Perc_Write/Erase_Ct_BC  0x0032   100   100   000    Old_age   Always       -       12068
241 Total_Writes_GiB        0x0030   100   100   000    Old_age   Offline      -       5117
242 Total_Reads_GiB         0x0030   100   100   000    Old_age   Offline      -       5297
244 Thermal_Throttle        0x0032   000   100   ---    Old_age   Always       -       0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline       Fatal or unknown error        80%      2942         0
# 2  Short offline       Completed without error       00%      2879         -
Selective Self-tests/Logging not supported
jun 06 20:53:40 3abd-pc kernel: ata4.00: exception Emask 0x0 SAct 0x80000000 SErr 0x40000 action 0x0
jun 06 20:53:40 3abd-pc kernel: ata4.00: irq_stat 0x40000008
jun 06 20:53:40 3abd-pc kernel: ata4: SError: { CommWake }
jun 06 20:53:40 3abd-pc kernel: ata4.00: failed command: READ FPDMA QUEUED
jun 06 20:53:40 3abd-pc kernel: ata4.00: cmd 60/08:f8:a0:16:81/00:00:2b:00:00/40 tag 31 ncq dma 4096 in
                                         res 41/40:00:a0:16:81/00:00:2b:00:00/00 Emask 0x409 (media error) <F>
jun 06 20:53:40 3abd-pc kernel: ata4.00: status: { DRDY ERR }
jun 06 20:53:40 3abd-pc kernel: ata4.00: error: { UNC }
jun 06 20:53:40 3abd-pc kernel: blk_update_request: I/O error, dev sdc, sector 729880224 op 0x0:(READ) flags 0x3000 phys_seg 1 prio class 0
jun 06 20:53:40 3abd-pc kernel: EXT4-fs error (device sdc1): __ext4_find_entry:1534: inode #22807901: comm get_updates: reading directory lblock 0
the xdg command worked
It took more than a minute to load, the dolphin window freezed and it was like the video was stuck behind it cause i saw like a glimpse of an image.
But then the video loaded and so everything starts now.
Do you know what could cause that?
Thanks again for your help
Please read this:
Please boot a Manjaro USB stick and execute as root:
fsck /dev/sdc1
fsck /dev/sdc2
fsck /dev/sda1
fsck /dev/sda2
When you encounter an error, look up the exact error message on your phone / another computer and fix it.
Once done, shut down, remove the USB stick and boot normally
Perform the xdg-open again on the same file. If that works flawlessly, try your other applications too.
I will do it directly.
Thanks again.
Will let you know when i reboot.
Hehe … Very nice tutorial, indeed it happens to me all the time…
Thanks again
After you’ve fixed your system (I sincerely hope you don’t have to reinstall), please read this too:
:crossed_fingers:
