Looking for mesa [pkg-upd] 23.1.5 on gitlab so can recompile mesa.
Had to downgrade to mesa 23.0.4-1 to add support for:
-D video-codecs=vc1dec,h264dec,h264enc,h265dec,h265enc \
Can we get mesa [pkg-upd] 23.1.5 on gitlab?
Wrong branch. ![]()
Tried downloading from the parent branch, editing PKGBUILD with the -D video-codecs=vc1dec,h264dec,h264enc,h265dec,h265enc \ modification. Compilation was successful. But installing the compiled mesa drivers did not provide support for the required codecs.
Looking here…
Don’t add the backslash. Notice the Meson options are in they’re own local meson_options=() array.
Note that I’ve moved the discussion to it’s own Support topic.
For build tools:
sudo pacman -Syu base-devel git bison byacc polly flex --needed
Clone
git clone https://github.com/mesa-freeworld/mesa-nonfree.git
Sync dependencies, and build
$ cd mesa-nonfree
$ makepkg --syncdeps
Install built files as root
# pacman -U *
Can’t get it working for AMD KABINI R300:
$ vainfo
Trying display: wayland
Trying display: x11
vainfo: VA-API version: 1.19 (libva 2.19.0)
vainfo: Driver version: Mesa Gallium driver 23.1.5 for KABINI (, LLVM 15.0.7, DRM 2.50, 6.1.44-1-MANJARO)
vainfo: Supported profile and entrypoints
VAProfileNone : VAEntrypointVideoProc
Had to install old drivers:
$ vainfo
Trying display: x11
vainfo: Driver version: Mesa Gallium driver 23.0.4 for KABINI (, LLVM 15.0.7, DRM 2.50, 6.1.44-1-MANJARO)
VAProfileMPEG2Simple : VAEntrypointVLD
VAProfileMPEG2Main : VAEntrypointVLD
VAProfileVC1Simple : VAEntrypointVLD
VAProfileVC1Main : VAEntrypointVLD
VAProfileVC1Advanced : VAEntrypointVLD
VAProfileH264ConstrainedBaseline: VAEntrypointVLD
VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice
VAProfileH264Main : VAEntrypointVLD
VAProfileH264Main : VAEntrypointEncSlice
VAProfileH264High : VAEntrypointVLD
VAProfileH264High : VAEntrypointEncSlice
Technically you can use the PKGBUILD from https://github.com/mesa-freeeworld/mesa-nonfree.
Don’t clone the repo - the docs folder contains the packages used for the https://nonfree.eu repo.
Simply copy the PKGBILD into a folder of your choice - then cd into the folder and run makepkg -is
If you would like to skip building you can use directions found at https://nonfree.eu
Followed instructions here for https://nonfree.eu
$ vainfo
Trying display: x11
$ su
Password:
# pacman-key --recv-keys B728DB23B92CB01B && \
> pacman-key --lsign-key B728DB23B92CB01B
gpg: key B728DB23B92CB01B: public key "Mesa Freeworld <info@manjaro.download>" imported
gpg: Total number processed: 1
gpg: imported: 1
-> Locally signed 1 keys.
==> Updating trust database...
gpg: public key DB323392796CA067 is 3037 days newer than the signature
gpg: marginals needed: 3 completes needed: 1 trust model: pgp
gpg: depth: 0 valid: 1 signed: 22 trust: 0-, 0q, 0n, 0m, 0f, 1u
gpg: depth: 1 valid: 22 signed: 99 trust: 1-, 0q, 0n, 21m, 0f, 0u
gpg: depth: 2 valid: 77 signed: 31 trust: 77-, 0q, 0n, 0m, 0f, 0u
gpg: next trustdb check due at 2023-10-27
# sh -c "curl -s https://nonfree.eu/$(pacman-mirrors -G)/ > /etc/pacman.d/mesa-nonfree.pre.repo.conf"
# sed -i '/^\[core\]/i \Include = /etc/pacman.d/mesa-nonfree.pre.repo.conf\n' /etc/pacman.conf
# pacman -Syyuw
mesa-nonfree 8.8 KiB 19.3 KiB/s 00:00 [--------------] 100%
core 145.7 KiB 199 KiB/s 00:01 [--------------] 100%
extra 8.6 MiB 1731 KiB/s 00:05 [--------------] 100%
multilib 146.8 KiB 227 KiB/s 00:01 [--------------] 100%
warning: lib32-libva-mesa-driver: local (23.1.5-2) is newer than mesa-nonfree (23.1.2-1)
warning: lib32-mesa: local (23.1.5-2) is newer than mesa-nonfree (23.1.2-1)
warning: lib32-mesa-vdpau: local (23.1.5-2) is newer than mesa-nonfree (23.1.2-1)
warning: lib32-vulkan-intel: local (23.1.5-2) is newer than mesa-nonfree (23.1.2-1)
warning: lib32-vulkan-radeon: local (23.1.5-2) is newer than mesa-nonfree (23.1.2-1)
resolving dependencies...
Packages (10) libva-mesa-driver-1:23.1.5-2 mesa-1:23.1.5-2
mesa-vdpau-1:23.1.5-2 opencl-clover-mesa-1:23.1.5-2
opencl-rusticl-mesa-1:23.1.5-2 vulkan-intel-1:23.1.5-2
vulkan-mesa-layers-1:23.1.5-2 vulkan-radeon-1:23.1.5-2
vulkan-swrast-1:23.1.5-2 vulkan-virtio-1:23.1.5-2
Total Download Size: 75.04 MiB
:: Proceed with download? [Y/n] y
:: Retrieving packages...
vulkan-intel-1.2... 7.2 MiB 561 KiB/s 00:13 [--------------] 100%
opencl-rusticl-m... 7.2 MiB 516 KiB/s 00:14 [--------------] 100%
libva-mesa-drive... 4.4 MiB 486 KiB/s 00:09 [--------------] 100%
mesa-vdpau-1.23.... 4.1 MiB 491 KiB/s 00:08 [--------------] 100%
vulkan-swrast-1.... 2.1 MiB 478 KiB/s 00:04 [--------------] 100%
vulkan-radeon-1.... 2.7 MiB 504 KiB/s 00:05 [--------------] 100%
vulkan-virtio-1.... 418.2 KiB 433 KiB/s 00:01 [--------------] 100%
vulkan-mesa-laye... 310.2 KiB 377 KiB/s 00:01 [--------------] 100%
opencl-clover-me... 18.0 MiB 577 KiB/s 00:32 [--------------] 100%
mesa-1.23.1.5-2-... 28.8 MiB 784 KiB/s 00:38 [--------------] 100%
Total (10/10) 75.0 MiB 2042 KiB/s 00:38 [--------------] 100%
(10/10) checking keys in keyring [--------------] 100%
(10/10) checking package integrity [--------------] 100%
# pacman -Syu
mesa-nonfree is up to date
core is up to date
extra is up to date
multilib is up to date
Total Installed Size: 254.80 MiB
Net Upgrade Size: 0.01 MiB
:: Proceed with installation? [Y/n] y
(10/10) loading package files [--------------] 100%
(10/10) checking for file conflicts [--------------] 100%
(10/10) checking available disk space [--------------] 100%
(1/1) Creating Timeshift snapshot before upgrade...
First run mode (config file not found)
Selected default snapshot type: BTRFS
Using system disk as snapshot device for creating snapshots in BTRFS mode
Mounted '/dev/sda7' at '/run/timeshift/2543/backup'
btrfs: Quotas are not enabled
Creating new backup...(BTRFS)
Saving to device: /dev/sda7, mounted at path: /run/timeshift/2543/backup
Created directory: /run/timeshift/2543/backup/timeshift-btrfs/snapshots/2023-08-13_06-41-08
Created subvolume snapshot: /run/timeshift/2543/backup/timeshift-btrfs/snapshots/2023-08-13_06-41-08/@
Created control file: /run/timeshift/2543/backup/timeshift-btrfs/snapshots/2023-08-13_06-41-08/info.json
BTRFS Snapshot saved successfully (0s)
Tagged snapshot '2023-08-13_06-41-08': ondemand
Mounted '/dev/sda7' at '/run/timeshift/2683/backup'
Selected default snapshot device: /dev/sda7
Removing snapshot: 2023-08-13_00-14-09
Deleting subvolume: @ (Id:317)
Deleted subvolume: @ (Id:317)
Deleted directory: /run/timeshift/2683/backup/timeshift-btrfs/snapshots/2023-08-13_00-14-09
Removed snapshot: 2023-08-13_00-14-09
Found linux image: /boot/vmlinuz-6.1-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-6.1-x86_64.img
Found initrd fallback image: /boot/initramfs-6.1-x86_64-fallback.img
Found Windows Boot Manager on /dev/sda1@/efi/Microsoft/Boot/bootmgfw.efi
Detecting snapshots ...
Found snapshot: 2023-08-13 06:41:08 | timeshift-btrfs/snapshots/2023-08-13_06-41-08/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
Found snapshot: 2023-08-13 00:25:11 | timeshift-btrfs/snapshots/2023-08-13_00-25-11/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
Found snapshot: 2023-08-13 00:23:52 | timeshift-btrfs/snapshots/2023-08-13_00-23-52/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
Found 3 snapshot(s)
Unmount /tmp/grub-btrfs.PwOemGuWUf .. Success
done
( 1/10) upgrading libva-mesa-driver [--------------] 100%
( 2/10) upgrading mesa [--------------] 100%
( 3/10) upgrading mesa-vdpau [--------------] 100%
( 4/10) upgrading opencl-clover-mesa [--------------] 100%
( 5/10) upgrading opencl-rusticl-mesa [--------------] 100%
( 6/10) upgrading vulkan-intel [--------------] 100%
( 7/10) upgrading vulkan-mesa-layers [--------------] 100%
( 8/10) upgrading vulkan-radeon [--------------] 100%
( 9/10) upgrading vulkan-swrast [--------------] 100%
(10/10) upgrading vulkan-virtio [--------------] 100%
(1/1) Arming ConditionNeedsUpdate...
# exit
exit
$ vainfo
Trying display: x11
Attempted to make this response, but could not even see your post.
So had to downgrade mesa before being able to make this post:
$ vainfo
Trying display: x11
Now element-desktop does not display correctly.
I don’t even know what that is …
From what I could look up in a jiffy - it seems the GPU was first manufactured a long time ago.
I wouldn’t expect such GPU to support the same as more recent GPUs.
So what you are trying to achieve may not be possible - at least not if the GPU is no longer supported - for whatever you are doing.
The gpu AMD R300 appears to be EOL - judging from the AMD web where it is not possible to locate drivers for it - this makes it even harder for you.
After re-booting, element-desktop displays correctly.
So the older display drivers work!
$ vainfo
Trying display: x11
the repo is gone?
Appears any graphics card with OpenGL < 3.3 will not have support going forward.
