Kobold
18 February 2023 17:20
1
Hello,
i want to resize my Swap Partition (sdc2) and extend it from 3Gbyte to 6Gbyte.
I hope someone can assist me, how to archive this goal.
I was thinking to boot with my Manjaro usb bootstick and boot into live environment to get good and easy access.
I thinking to use KDE Partition Manager where i got already a little experience with and reduce / partition (root) (sdc1) by 3 Gbyte and extend the swap partition (sdc2) and clicking on apply and done and restart into the normal boot?
Is this as easy as it sounds or did i miss something? Do i have to maybe also use chroot or fstab and that i also need to update grub in terminal?
I don’t want to do something wrong, i hope someone can give me advise. I also created Timeshift backup, just in case. But im not sure if backup even works after i changed and reduced root partition.
Please help me out.
$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.15.93-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/vmlinuz-5.15-x86_64
root=UUID=eb235aa7-d461-413d-800e-ea57385703fb rw quiet apparmor=1
sysrq_always_enabled=1 retbleed=off security=apparmor
resume=UUID=a44dd3c4-f5f1-4587-8934-6f7413d28d4f udev.log_priority=3
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Gigabyte product: Z170X-UD3 v: N/A
serial: <superuser required>
Mobo: Gigabyte model: Z170X-UD3-CF v: x.x serial: <superuser required>
UEFI-[Legacy]: American Megatrends v: F23d date: 12/01/2017
RAM: total: 15.58 GiB used: 5.8 GiB (37.2%)
Info: model: Intel Core i7-6700K bits: 64 type: MT MCP arch: Skylake-S
gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
model-id: 0x5E (94) stepping: 3 microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 4410 high: 4500 min/max: 800/4700 scaling:
driver: intel_pstate governor: performance cores: 1: 4500 2: 4500 3: 4500
4: 4500 5: 4500 6: 4120 7: 4169 8: 4497 bogomips: 64026
dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
vulnerable
Type: retbleed status: Vulnerable
prctl and seccomp
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA TU102 [GeForce RTX 2080 Ti Rev. A] vendor: Micro-Star MSI
driver: nvidia v: 525.89.02 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1e07
class-ID: 0300
Display: x11 server: X.Org v: 21.1.7 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 122 s-size: 532x302mm (20.94x11.89")
s-diag: 612mm (24.08")
Monitor-1: DP-4 res: 2560x1440 dpi: 123 size: 527x296mm (20.75x11.65")
diag: 604mm (23.8") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 525.89.02 renderer: NVIDIA GeForce RTX 2080
Ti/PCIe/SSE2 direct-render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
class-ID: 0403
Device-2: NVIDIA TU102 High Definition Audio vendor: Micro-Star MSI
bus-ID: 01:00.1 chip-ID: 10de:10f7 class-ID: 0403
Device-3: Creative Labs CA0132 Sound Core3D [Sound Blaster Recon3D /
Z-Series BlasterX AE-5 Plus] driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 0b:00.0 chip-ID: 1102:0012 class-ID: 0403
Sound API: ALSA v: k5.15.93-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.65 running: yes
Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 4.57 TiB used: 953.34 GiB (20.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 960 EVO 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 2B7QCXE7 temp: 36.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 PRO 1TB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 2B6Q scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: HGST (Hitachi) model: HDN724030ALE640
size: 2.73 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: A5E0 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Samsung
model: Portable SSD T5 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: <filter> scheme: MBR
ID-1: / raw-size: 88.61 GiB size: 86.66 GiB (97.80%) used: 26.48 GiB (30.6%)
fs: ext4 dev: /dev/sdc1 maj-min: 8:33 label: N/A
uuid: eb235aa7-d461-413d-800e-ea57385703fb
ID-2: /boot raw-size: 200 MiB size: 188.2 MiB (94.09%)
used: 68.9 MiB (36.6%) fs: ext3 dev: /dev/sdc3 maj-min: 8:35 label: N/A
uuid: 26eda82e-b403-49b8-abca-202167417020
ID-3: /home raw-size: 332.03 GiB size: 325.75 GiB (98.11%)
used: 25.87 GiB (7.9%) fs: ext4 dev: /dev/sdc4 maj-min: 8:36 label: N/A
uuid: ada4a6a2-bd0a-4652-b386-7c637bba7ee9
ID-4: /media/temp raw-size: 63.48 GiB size: 62.18 GiB (97.96%)
used: 37.21 GiB (59.8%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: temp
uuid: 1e81b7c2-3438-438a-b572-ff8a966a78e1
ID-5: /run/media/koboldx/Linux-games raw-size: 196.58 GiB
size: 192.43 GiB (97.89%) used: 112.24 GiB (58.3%) fs: ext4 dev: /dev/sda3
maj-min: 8:3 label: Linux-games uuid: dd5af583-9d00-4017-adf7-e1d8876486e7
ID-6: /run/media/koboldx/games raw-size: 585.94 GiB
size: 585.94 GiB (100.00%) used: 371.99 GiB (63.5%) fs: ntfs dev: /dev/sda4
maj-min: 8:4 label: games uuid: 165692E31D7ADAF2
ID-7: /run/media/koboldx/ssm raw-size: 442.47 GiB
size: 442.47 GiB (100.00%) used: 378.52 GiB (85.5%) fs: ntfs
dev: /dev/nvme0n1p1 maj-min: 259:1 label: ssm uuid: AE7EDC0696B158FD
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 2.93 GiB used: 969.4 MiB (32.3%)
priority: -2 dev: /dev/sdc2 maj-min: 8:34 label: N/A
uuid: a44dd3c4-f5f1-4587-8934-6f7413d28d4f
ID-1: /dev/sda1 maj-min: 8:1 size: 50 MiB fs: ntfs label: System-reserviert
uuid: B2286A122869D5BF
ID-2: /dev/sda2 maj-min: 8:2 size: 97.09 GiB fs: ntfs label: win10
uuid: 5E60C09860C077F3
ID-3: /dev/sdb2 maj-min: 8:18 size: 1.57 TiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/sdb3 maj-min: 8:19 size: 1.09 TiB fs: <superuser required>
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-9:2 info: Endor AG ClubSportPedal type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 0eb7:183b class-ID: 0300
Device-2: 1-13:3 info: A4Tech XL-730K / XL-750BK XL-755BK Mice
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 09da:9090 class-ID: 0301
Hub-2: 2-0:1 info: Super-speed hub ports: 10 rev: 3.0 speed: 5 Gb/s
Device-1: 2-5:2 info: Samsung Portable SSD T5 type: Mass Storage
driver: uas interfaces: 1 rev: 3.1 speed: 5 Gb/s power: 896mA
chip-ID: 04e8:61f5 class-ID: 0806 serial: <filter>
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-6: 6-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 38.0 C mobo: N/A gpu: nvidia temp: 35 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 25%
Processes: 250 Uptime: 2d 4h 28m wakeups: 1 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: 1483 pm: pacman pkgs: 1477 libs: 417 tools: pamac pm: flatpak
pkgs: 6 Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.25
Wollie
18 February 2023 18:47
2
It looks like you are booting in BIOS mode as your sdc is formatted with MBR. In your case I would disable swap, remove the existing swap partition, extend the space of your / partition to take benefit of this space (e.g. using GParted) and create a new partition for swap using the unallocated space at the end of the disk.
All this should be done from a live boot (Manjaro on USB stick) to make sure no partition is mounted. All details you will find easily using a search engine of your choice.
Kobold
19 February 2023 09:48
3
Is there something wrong by reducing my Root Partition?
I only have found infos for swapfile but not swap partition.
I also searched in this forum… i dont see anything that would answer my questions.
Is there more infos that i need to know about? Or why you suggest to search the internet for more details?
Kobold
19 February 2023 22:53
4
Wollie:
I did everything exactly as you said. But when i boot into Manjaro after that, i get “error hybernation device:UUID=a44dd3c4-f5f1-4587-8934-6f7413d28d4f not found” and the system stuck,
not even TTY worked.
I rebooted again on the livedisk and edited fstab with the changed UUI and it finally boot into Manjaro but i still got the same error.
$ inxi --admin --verbosity=7 --filter --no-host --width:
RAM: total: 15.58 GiB used: 2.25 GiB (14.5%)
Speed (MHz): avg: 4501 high: 4509 min/max: 800/4700 scaling:
driver: intel_pstate governor: performance cores: 1: 4499 2: 4502 3: 4509
4: 4500 5: 4500 6: 4506 7: 4497 8: 4497 bogomips: 64026
vulnerable
prctl and seccomp
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1e07 class-ID: 0300
class-ID: 0403
Local Storage: total: 4.57 TiB used: 197.25 GiB (4.2%)
lanes: 4 type: SSD serial: <filter> rev: 2B7QCXE7 temp: 33.9 C scheme: GPT
ID-1: / raw-size: 88.61 GiB size: 86.66 GiB (97.80%) used: 28.24 GiB (32.6%)
used: 25.97 GiB (8.0%) fs: ext4 dev: /dev/sdc4 maj-min: 8:36 label: N/A
ID-4: /media/linux-games raw-size: 196.58 GiB size: 192.43 GiB (97.89%)
used: 112.25 GiB (58.3%) fs: ext4 dev: /dev/sda3 maj-min: 8:3
ID-5: /media/temp raw-size: 63.48 GiB size: 62.18 GiB (97.96%)
used: 30.73 GiB (49.4%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: temp
ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%) priority: -2
uuid: 717b267e-7322-4bf9-a840-f1210d422d1a
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 442.47 GiB fs: ntfs label: ssm
ID-2: /dev/sda1 maj-min: 8:1 size: 50 MiB fs: ntfs label: System-reserviert
ID-3: /dev/sda2 maj-min: 8:2 size: 97.09 GiB fs: ntfs label: win10
ID-4: /dev/sda4 maj-min: 8:4 size: 585.94 GiB fs: ntfs label: games
ID-5: /dev/sdb2 maj-min: 8:18 size: 1.57 TiB fs: <superuser required>
ID-6: /dev/sdb3 maj-min: 8:19 size: 1.09 TiB fs: <superuser required>
System Temperatures: cpu: 30.0 C mobo: N/A gpu: nvidia temp: 36 C
Processes: 238 Uptime: 14m wakeups: 4 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1483
pm: pacman pkgs: 1477 libs: 417 tools: pamac pm: flatpak pkgs: 6 Shell: Bash
Edit: i see in inxi still the old UUID entry:
resume=UUID=a44dd3c4-f5f1-4587-8934-6f7413d28d4f udev.log_priority=3.
Under Kernel and parameters.
Kobold
19 February 2023 23:39
5
I finally fixed the error by myself with:
sudo nano /etc/default/grub
where i was looking for:
and replaced the UUID with the new one, i saved grub.
and did:
sudo update-grub
system
Closed
22 February 2023 13:39
6
