I already contacted my Mainboard Vendor (Gigabyte) and they created a NEW Bios Option after my request to disable Wifi and Bluetooth in the Bios. But my Eggs are not big enough to flash on my expensive new Mainboard a Pre-Alpha Bios version
I’m waiting 2-3 month till the newest Bios is stable and look if i can get rid at least on that Bluetooth error’s. I have a optional bluetooth usb adapter for my X-Box One Gamepad which i only use rarely.
TBH, i never used thunderbolt and i though i disabled that in Bios already.
I would disable that feature in Bios entirely or the Service under Linux, if i could…
Since i have a AM5 Mainboard its also a little confusing to see a thunderbolt info, since thunderbolt is from intel.
With all due respect, but I think @Kobold hasn’t yet decided what he wants. Anywhom, I’d rather work to solve as much of the errors instead of brushing them under the carpet.
Run the @pwx command and give us some more details.
I see that Eric Raymond / Rick Moen opus is more valid than ever, even after 2 decades.
Well i don’t mind to solve error’s… i don’t want to brush anything under the carpet.
If you have any idea how to solve anything, i’m open for that.
Where was your response in this Topic? I couldn’t see you there. I asked there if this output is harmless and they already responsed that it is no problem.
And what command from PWX are you talking about? I posted the journal output already.
Ensure plymouth is installed and set as default theme
If quiet doesn’t work you could pass a system.d line to the kernel, but it shouldn’t be necessary.
I too have the bluetooth error bluetoothd[760]: Failed to set mode: Failed (0x03)
but I also have it turned off in System Settings. I can’t find it in my bios so I just ignore it.
The thing is, he can’t solve the errors by himself. Pretty much everything (thunderbolt i don’t know, that is to be investigated) is driver/firmware/kernel related - one can only wait for new versions.
I think he said he wants to solve them, just doesn’t want to see them parading at boot time. But then how would you know there is an error, unless you check the logs at every boot which for my taste it’s a tad tedious.
[koboldx@koboldx-x870e ~]$ boltctl list
There is no output
Any more ideas around the Thunderbolt device?
You total missed the point, i only want to ignore that warnings because the info’s are unfixable.
I also wrote multiple times that i don’t want to use a boot logo (i also wrote that i manually disable Plymouth, why should i want to enable it again?) and i also rejected the idea about quiet (dark blank boot)… everything was mentionend already in this topic.
When i understand the info’s correct, then Thunderbolt is the only option which maybe can be solved here.
Bluetooth warnings are temporary till i can disable it in Bios with the newest update.
Maybe that will be the solution for thunderbolt too - to disable it in bios. But beware, on some machines it is combined with some usb ports.
For the by-passers, for educational purposes, the loglevels explained. Although the article is for the kernel, udev, systemd etc. Settings all follow this logic, as in the example of @pwx above where he silences everything passing 0 as option everywhere.
