New PC showing some errors while booting, is it okay to ignore?
I have brand new hardware and im writting this on my new PC right now.
Jul 16 01:42:36 koboldx-x870e kernel: virt/tdx: TDX not supported by the host platform
Jul 16 01:42:36 koboldx-x870e kernel: integrity: Problem loading X.509 certificate -22
Jul 16 01:42:38 koboldx-x870e kernel: thunderbolt 0000:1c:00.0: probe with driver thunderbolt failed with error -110
This TDX error showed up after i updated from kernel 7.0 to 7.1 btw
Both TDX and Thunderbolt are Intel things. It is expected that they are not present on AMD machines. Just ignore the messages.
No idea about the thunderbolt, but the other 3 are safe to ignore. Indeed the vtx one is since kernel 7 also on my install, but it is up and running so it is just a false warning it seems.
The certificate error is secure boot related, even if it is turned off.
I read about the TDX error earlier today - nothing to worry about: [SOLVED] Boot error warning: TDX not supported by the host / Newbie Corner / Arch Linux Forums
Looks like you should update the bios too.
Thanks everyone for the feedback :slight_smile:
