Login screen spinning progress icon stuck
After updating to Qonos, I began to have an issue with the login screen getting stuck with a forever spinning wheel after typing password.
I have auto-login on boot, so I have no issue booting, it’s only after suspend or screenlock.
I noticed some other topics with something similar, but mine is not quite the same, although surely related.
This issue only manifests intermittently, I may have days without it, or it might happen several times a day.
I found a way to easily dodge the issue when it happens: By clicking the user session in the bottom right (where you may usually choose x11 or wayland) it triggers a full logout. Then I click my user name & enter password again - this always works to login without the spinning wheel.
It is not a terrible problem, but it is annoying & I would like to fix it if possible.
inxi --admin --verbosity=7 --filter --width                     ξ‚² βœ”
  Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
    root=UUID=b4f0a1a8-ec55-40cf-a380-b762e3b7092a rw quiet splash apparmor=1
    security=apparmor udev.log_priority=3 iommu=soft
  Desktop: GNOME 41.3 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
  Type: Laptop System: LENOVO product: 20VF v: ThinkBook 14 G2 ARE
    serial: <superuser required> Chassis: type: 10 v: ThinkBook 14 G2 ARE
  Mobo: LENOVO model: LNVNB161216 v: SDK0J40700 WIN
    serial: <superuser required> UEFI: LENOVO v: FACN28WW(V1.11)
    date: 05/18/2021
  ID-1: BAT1 charge: 16.4 Wh (40.0%) condition: 41.0/45.0 Wh (91.2%)
    volts: 11.2 min: 11.5 model: 0x43 0x65 0x6C 0x78 0x70 0x65 0x 0x4C 0x31
    0x39 0x43 0x33 0x50 0x4500
    type: Li-ion serial: <filter> status: Discharging cycles: 156
  Device-1: hidpp_battery_0 model: Logitech M585/M590 Multi-Device Mouse
    status: Discharging
  RAM: total: 19.41 GiB used: 3.65 GiB (18.8%)
  RAM Report:
  Info: model: AMD Ryzen 5 4500U with Radeon Graphics bits: 64 type: MCP
    arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
    microcode: 0x8600106
  Topology: cpus: 1x cores: 6 smt: <unsupported> cache: L1: 384 KiB
    desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
    desc: 2x4 MiB
  Speed (MHz): avg: 1397 min/max: 1400/2375 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 1397 2: 1397 3: 1397
    4: 1397 5: 1397 6: 1397 bogomips: 28452
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
    pfthreshold pge pni popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
    sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
    tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
    wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
  Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
  Device-1: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel bus-ID: 05:00.0
    chip-ID: 1002:1636 class-ID: 0300
  Device-2: IMC Networks Integrated Camera type: USB driver: uvcvideo
    bus-ID: 1-3:2 chip-ID: 13d3:56ff class-ID: 0e02
  Display: wayland server: X.org 1.21.1.3 compositor: gnome-shell driver:
    loaded: amdgpu note: n/a (using device driver) - try sudo/root display-ID: 0
  Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo
    driver: snd_hda_intel v: kernel bus-ID: 05:00.1 chip-ID: 1002:1637
    class-ID: 0403
  Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
    vendor: Lenovo driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x
    bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
  Sound Server-3: JACK v: 1.9.20 running: no
  Sound Server-4: PulseAudio v: 15.0 running: yes
  Sound Server-5: PipeWire v: 0.3.43 running: no
    vendor: Lenovo driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0
  Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
    vendor: Lenovo driver: rtw89_pci v: N/A modules: rtw89pci port: 2000
    bus-ID: 04:00.0 chip-ID: 10ec:8852 class-ID: 0280
  IF: wlp4s0 state: up mac: <filter>
  Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
    bus-ID: 3-4:4 chip-ID: 0bda:4852 class-ID: e001 serial: <filter>
  Report: rfkill ID: hci0 rfk-id: 5 state: down bt-service: enabled,running
  Local Storage: total: 704.24 GiB used: 297.89 GiB (42.3%)
    model: MZALQ256HAJD-000L2 size: 238.47 GiB block-size: physical: 512 B
    rev: BL2QFXV7 temp: 27.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500MX500SSD1
    size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    type: SSD serial: <filter> rev: 032 scheme: MBR
  ID-1: / raw-size: 118.99 GiB size: 116.56 GiB (97.96%)
    used: 66.58 GiB (57.1%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
    label: N/A uuid: b4f0a1a8-ec55-40cf-a380-b762e3b7092a
    used: 5.4 MiB (1.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: EB07-8818
  ID-3: /mnt/SSD500 raw-size: 465.76 GiB size: 457.45 GiB (98.22%)
    used: 231.3 GiB (50.6%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: SSD500
    uuid: a1936d96-6ea6-4cb5-b62d-618a8ec8a2a8
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 118.99 GiB fs: ext4 label: N/A
    uuid: 0f80e24b-1488-4fd7-b5a4-c563182bf4f7
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 1-3:2 info: IMC Networks Integrated Camera type: Video
  Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-2:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
    power: 98mA chip-ID: 046d:c52b class-ID: 0300
  Device-2: 3-3:6 info: Elan Micro ELAN:Fingerprint type: <vendor specific>
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
    chip-ID: 04f3:0c4b class-ID: 0000
  Device-3: 3-4:4 info: Realtek Bluetooth Radio type: Bluetooth
    driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s power: 500mA
  Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 34.5 C mobo: N/A gpu: amdgpu temp: 33.0 C
  Processes: 268 Uptime: 3h 32m wakeups: 20 Init: systemd v: 250
  tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1447
  lib: 464 flatpak: 0 Shell: Zsh v: 5.8 running-in: gnome-terminal
  inxi: 3.3.12
5.13 is EOL. Switch to a supported kernel:
sudo manjaro-chroot -a
sudo pacman-mirrors --fasttrack 5 && sudo pacman -Syyu
sudo mhwd-kernel -i linux515
exit
Then reboot into 5.15 (Press Esc during boot to get into grub menu and boot with 5.15)
Double check your running kernel is not 5.13 then remove it:
uname -r
sudo mhwd-kernel -r linux513
ahh yes, darn, I had forgot about that. I am a little stuck until 5.16 because my wifi card driver is not in 5.15
Without wifi I wont be able to install the required headers, base-devel & driver.
I am currently unable to use ethernet at my location.
oh I notice 5.16.2 is supported now.
Can I just as easily update to 5.16 using Manjaro Setting Manager GUI, or should I use terminal as you demonstrated (linux516) ?
Yes you can use the Manjaro settings manager to change kernel just don’t remove the active kernel.
The issue persists with 5.16
  Kernel: 5.16.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
    parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
    date: 05/18/2021
  ID-1: BAT1 charge: 35.6 Wh (87.3%) condition: 40.8/45.0 Wh (90.7%)
    volts: 12.2 min: 11.5 model: 0x43 0x65 0x6C 0x78 0x70 0x65 0x 0x4C 0x31
    type: Li-ion serial: <filter> status: Discharging cycles: 158
    status: Discharging
  RAM: total: 19.41 GiB used: 3.03 GiB (15.6%)
  RAM Report:
    desc: 2x4 MiB
    4: 1397 5: 1397 6: 1397 bogomips: 28453
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    class-ID: 0403
    alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x bus-ID: 05:00.5
  Sound Server-1: ALSA v: k5.16.2-1-MANJARO running: yes
    vendor: Lenovo driver: rtw89_pci v: kernel port: 2000 bus-ID: 04:00.0
  Report: rfkill ID: hci0 rfk-id: 6 state: down bt-service: enabled,running
  Local Storage: total: 704.24 GiB used: 307.09 GiB (43.6%)
    rev: BL2QFXV7 temp: 26.9 C scheme: GPT
    used: 75.74 GiB (65.0%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
    uuid: EB07-8818
    used: 231.34 GiB (50.6%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: SSD500
  Device-2: 3-3:8 info: Elan Micro ELAN:Fingerprint type: <vendor specific>
  System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 33.0 C
  Processes: 265 Uptime: 11h 17m wakeups: 37 Init: systemd v: 250
  tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1449
  inxi: 3.3.12
This is still an issue with the latest Manjaro GNOME Testing branch (I can’t collect logs as the laptop is unworkable right now). Clicking the accounts icon returns to the outer login, but the previous session is restored after logging in.
Even when pressing the power button for 10 seconds, the computer does not force off, so it could be an issue interfacing with the Embedded Controller.
I managed to catch a log of this issue which is during the 19:43 timestamp here. Although I cant identify where the issue is exactly, it must be in this part of the log as I noted the time as it happened.
 2月 07 19:44:00 Sulaco systemd[34735]: Reached target Exit the Session.
 2月 07 19:44:00 Sulaco systemd[34735]: Finished Exit the Session.
 2月 07 19:44:00 Sulaco systemd[34735]: Reached target Shutdown.
 2月 07 19:44:00 Sulaco systemd[34735]: Removed slice User Application Slice.
 2月 07 19:44:00 Sulaco systemd[34735]: Closed Sound System.
 2月 07 19:44:00 Sulaco systemd[34735]: Closed PipeWire Multimedia System Socket.
 2月 07 19:44:00 Sulaco systemd[34735]: Closed p11-kit server.
 2月 07 19:44:00 Sulaco systemd[34735]: Closed GnuPG cryptographic agent and passphrase cache.
 2月 07 19:44:00 Sulaco systemd[34735]: Closed GnuPG cryptographic agent (ssh-agent emulation).
 2月 07 19:44:00 Sulaco systemd[34735]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
 2月 07 19:44:00 Sulaco systemd[34735]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
 2月 07 19:44:00 Sulaco systemd[34735]: Closed GCR ssh-agent wrapper.
 2月 07 19:44:00 Sulaco systemd[34735]: Closed GnuPG network certificate management daemon.
 2月 07 19:44:00 Sulaco systemd[34735]: Closed D-Bus User Message Bus Socket.
 2月 07 19:44:00 Sulaco systemd[34735]: Stopped target Timers.
 2月 07 19:44:00 Sulaco systemd[34735]: Stopped target Sockets.
 2月 07 19:44:00 Sulaco systemd[34735]: Stopped target Paths.
 2月 07 19:44:00 Sulaco systemd[34735]: Stopped target Basic System.
 2月 07 19:44:00 Sulaco systemd[34735]: Stopped D-Bus User Message Bus.
 2月 07 19:44:00 Sulaco systemd[34735]: Stopping D-Bus User Message Bus...
 2月 07 19:44:00 Sulaco systemd[34735]: Stopped target Main User Target.
 2月 07 19:44:00 Sulaco systemd[34735]: Removed slice User Core Session Slice.
 2月 07 19:44:00 Sulaco systemd[34735]: Activating special unit Exit the Session...
 2月 07 19:44:00 Sulaco systemd[1]: Stopping User Manager for UID 120...
 2月 07 19:43:50 Sulaco nautilus[35131]: Could not delete '.meta.isrunning': No such file or directory
 2月 07 19:43:50 Sulaco gdm[441]: Gdm: Child process -34745 was already dead.
 2月 07 19:43:50 Sulaco polkitd[390]: Unregistered Authentication Agent for unix-session:3 (system bus name :1.652, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_GB.>
 2月 07 19:43:50 Sulaco systemd-logind[393]: Removed session 3.
 2月 07 19:43:50 Sulaco systemd[1]: session-3.scope: Consumed 3.038s CPU time.
 2月 07 19:43:50 Sulaco systemd[1]: Stopped Session 3 of User gdm.
 2月 07 19:43:50 Sulaco systemd[1]: session-3.scope: Deactivated successfully.
 2月 07 19:43:50 Sulaco gsd-color[1047]: failed to connect to device: Failed to connect to missing device /org/freedesktop/ColorManager/devices/xrandr_Chimei_Innolux_Corporation_gdm_120
 2月 07 19:43:50 Sulaco systemd[1]: Stopping Session 3 of User gdm...
 2月 07 19:43:50 Sulaco kernel: audit: type=1104 audit(1644263030.619:423): pid=34724 uid=0 auid=120 ses=3 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="gdm" exe="/usr/lib/g>
 2月 07 19:43:50 Sulaco kernel: audit: type=1106 audit(1644263030.619:422): pid=34724 uid=0 auid=120 ses=3 subj==unconfined msg='op=PAM:session_close grantors=pam_loginuid,pam_keyinit,pam_su>
 2月 07 19:43:50 Sulaco gdm-launch-environment][34724]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
 2月 07 19:43:50 Sulaco audit[34724]: CRED_DISP pid=34724 uid=0 auid=120 ses=3 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="gdm" exe="/usr/lib/gdm-session-worker" hostname=>
 2月 07 19:43:50 Sulaco audit[34724]: USER_END pid=34724 uid=0 auid=120 ses=3 subj==unconfined msg='op=PAM:session_close grantors=pam_loginuid,pam_keyinit,pam_succeed_if,pam_permit,pam_syste>
 2月 07 19:43:50 Sulaco pulseaudio[34824]: X11 I/O error exit handler called, preparing to tear down X11 modules
 2月 07 19:43:50 Sulaco pulseaudio[34824]: X11 I/O error handler called
 2月 07 19:43:50 Sulaco gnome-shell[34759]: Connection to xwayland lost
 2月 07 19:43:45 Sulaco systemd[777]: Started VTE child process 35217 launched by gnome-terminal-server process 35194.
 2月 07 19:43:45 Sulaco systemd[777]: Started GNOME Terminal Server.
 2月 07 19:43:45 Sulaco dbus-daemon[796]: [session uid=1000 pid=796] Successfully activated service 'org.gnome.Terminal'
 2月 07 19:43:45 Sulaco systemd[777]: Starting GNOME Terminal Server...
 2月 07 19:43:45 Sulaco systemd[777]: Created slice Slice /app/org.gnome.Terminal.
 2月 07 19:43:45 Sulaco dbus-daemon[796]: [session uid=1000 pid=796] Activating via systemd: service name='org.gnome.Terminal' unit='gnome-terminal-server.service' requested by ':1.844' (uid>
 2月 07 19:43:45 Sulaco systemd[777]: Started Application launched by gnome-shell.
 2月 07 19:43:44 Sulaco systemd[777]: app-gnome-firefox-19575.scope: Consumed 47min 54.022s CPU time.
 2月 07 19:43:44 Sulaco gnome-shell[19575]: ###!!! [Parent][RunMessage] Error: Channel closing: too late to send/recv, messages will be lost
 2月 07 19:43:40 Sulaco dbus-daemon[796]: [session uid=1000 pid=796] Successfully activated service 'org.gnome.NautilusPreviewer'
 2月 07 19:43:40 Sulaco dbus-daemon[796]: [session uid=1000 pid=796] Successfully activated service 'org.gnome.ArchiveManager1'
 2月 07 19:43:40 Sulaco appindicatorsupport@rgcjonas.gmail.com[826]: unable to update icon for Fcitx
 2月 07 19:43:40 Sulaco gnome-shell[826]: Received property WindowId with type u does not match expected type i in the expected interface
 2月 07 19:43:40 Sulaco gnome-shell[826]: clutter_actor_iter_next: assertion 'ri->age == ri->root->priv->age' failed
 2月 07 19:43:40 Sulaco dbus-daemon[796]: [session uid=1000 pid=796] Activated service 'org.freedesktop.FileManager1' failed: Process org.freedesktop.FileManager1 exited with status 1
 2月 07 19:43:40 Sulaco org.freedesktop.FileManager1[35133]: Failed to register: Unable to acquire bus name 'org.gnome.Nautilus'
 2月 07 19:43:40 Sulaco dbus-daemon[796]: [session uid=1000 pid=796] Successfully activated service 'org.gnome.Nautilus'
 2月 07 19:43:40 Sulaco dbus-daemon[35137]: writing oom_score_adj error: Permission denied
 2月 07 19:43:40 Sulaco dbus-daemon[796]: [session uid=1000 pid=796] Activating service name='org.gnome.ArchiveManager1' requested by ':1.834' (uid=1000 pid=35090 comm="gjs /usr/share/gnome->
 2月 07 19:43:40 Sulaco dbus-daemon[35135]: writing oom_score_adj error: Permission denied
 2月 07 19:43:40 Sulaco dbus-daemon[35133]: writing oom_score_adj error: Permission denied
 2月 07 19:43:40 Sulaco dbus-daemon[796]: [session uid=1000 pid=796] Activating service name='org.gnome.NautilusPreviewer' requested by ':1.834' (uid=1000 pid=35090 comm="gjs /usr/share/gnom>
 2月 07 19:43:40 Sulaco dbus-daemon[796]: [session uid=1000 pid=796] Activating service name='org.freedesktop.FileManager1' requested by ':1.834' (uid=1000 pid=35090 comm="gjs /usr/share/gno>
 2月 07 19:43:40 Sulaco dbus-daemon[35131]: writing oom_score_adj error: Permission denied
 2月 07 19:43:40 Sulaco dbus-daemon[796]: [session uid=1000 pid=796] Activating service name='org.gnome.Nautilus' requested by ':1.834' (uid=1000 pid=35090 comm="gjs /usr/share/gnome-shell/e>
 2月 07 19:43:40 Sulaco gnome-shell[35129]: Errors from xkbcomp are not fatal to the X server
 2月 07 19:43:40 Sulaco gnome-shell[35129]: >                   X11 cannot support keycodes above 255.
 2月 07 19:43:40 Sulaco gnome-shell[35129]: > Warning:          Unsupported maximum keycode 708, clipping.
 2月 07 19:43:40 Sulaco gnome-shell[35129]: The XKEYBOARD keymap compiler (xkbcomp) reports:
 2月 07 19:43:40 Sulaco NetworkManager[388]: <info>  [1644263020.3451] agent-manager: agent[944881b4f8a9345c,:1.24/org.gnome.Shell.NetworkAgent/1000]: agent registered
 2月 07 19:43:40 Sulaco gnome-shell[826]: Timelines with detached actors are not supported
 2月 07 19:43:40 Sulaco gnome-shell[826]: INFO: [kt indicator] Initializing extension
 2月 07 19:43:40 Sulaco gnome-shell[826]: INFO: [kt timers] Attaching indicator
 2月 07 19:43:39 Sulaco kernel: audit: type=1110 audit(1644263019.969:421): pid=35075 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,p>
 2月 07 19:43:39 Sulaco kernel: audit: type=1101 audit(1644263019.969:420): pid=35075 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pa>
 2月 07 19:43:39 Sulaco kernel: audit: type=1100 audit(1644263019.969:419): pid=35075 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_p>
 2月 07 19:43:39 Sulaco audit[35075]: CRED_REFR pid=35075 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyrin>
 2月 07 19:43:39 Sulaco audit[35075]: USER_ACCT pid=35075 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="rico" exe="/usr>
 2月 07 19:43:39 Sulaco audit[35075]: USER_AUTH pid=35075 uid=0 auid=1000 ses=1 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome>
 2月 07 19:43:39 Sulaco gdm-password][35075]: gkr-pam: unlocked login keyring
 2月 07 19:43:39 Sulaco kernel: audit: type=1334 audit(1644263019.632:418): prog-id=0 op=UNLOAD
 2月 07 19:43:39 Sulaco audit: BPF prog-id=0 op=UNLOAD
 2月 07 19:43:39 Sulaco audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? t>
 2月 07 19:43:39 Sulaco kernel: audit: type=1131 audit(1644263019.602:417): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd>
 2月 07 19:43:39 Sulaco kernel: kauditd_printk_skb: 17 callbacks suppressed
 2月 07 19:43:39 Sulaco systemd[1]: fprintd.service: Deactivated successfully.
 2月 07 19:43:35 Sulaco gdm-password][35075]: pam_systemd_home(gdm-password:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
 2月 07 19:43:35 Sulaco dbus-daemon[386]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
 2月 07 19:43:35 Sulaco dbus-daemon[386]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.681' (uid=0 pid=350>
 2月 07 19:43:32 Sulaco gnome-shell[34759]: Registering session with GDM
 2月 07 19:43:32 Sulaco /usr/lib/gdm-wayland-session[34750]: dbus-daemon[34750]: [session uid=120 pid=34750] Successfully activated service 'org.gnome.Shell.Screencast'
 2月 07 19:43:32 Sulaco org.gnome.Shell.desktop[35032]: Errors from xkbcomp are not fatal to the X server
 2月 07 19:43:32 Sulaco org.gnome.Shell.desktop[35032]: >                   X11 cannot support keycodes above 255.
 2月 07 19:43:32 Sulaco org.gnome.Shell.desktop[35032]: > Warning:          Unsupported maximum keycode 708, clipping.
 2月 07 19:43:32 Sulaco org.gnome.Shell.desktop[35032]: The XKEYBOARD keymap compiler (xkbcomp) reports:
 2月 07 19:43:32 Sulaco xbrlapi.desktop[35030]: cannot connect to braille devices daemon brltty at :0
 2月 07 19:43:32 Sulaco xbrlapi.desktop[35030]: openConnection: connect: No such file or directory
 2月 07 19:43:32 Sulaco gnome-session-binary[34751]: Entering running state
 2月 07 19:43:32 Sulaco /usr/lib/gdm-wayland-session[34750]: dbus-daemon[34750]: [session uid=120 pid=34750] Successfully activated service 'org.freedesktop.portal.IBus'
 2月 07 19:43:32 Sulaco /usr/lib/gdm-wayland-session[34750]: dbus-daemon[34750]: [session uid=120 pid=34750] Activating service name='org.freedesktop.portal.IBus' requested by ':1.35' (uid=1>
 2月 07 19:43:32 Sulaco gnome-shell[34759]: ATK Bridge is disabled but a11y has already been enabled.
 2月 07 19:43:32 Sulaco gsd-media-keys[34860]: Failed to grab accelerator for keybinding settings:magnifier-zoom-out
 2月 07 19:43:32 Sulaco gsd-media-keys[34860]: Failed to grab accelerator for keybinding settings:hibernate
 2月 07 19:43:32 Sulaco gsd-media-keys[34860]: Failed to grab accelerator for keybinding settings:playback-repeat
 2月 07 19:43:32 Sulaco /usr/lib/gdm-wayland-session[34750]: dbus-daemon[34750]: [session uid=120 pid=34750] Activating service name='org.gnome.Shell.Screencast' requested by ':1.26' (uid=12>
 2月 07 19:43:32 Sulaco systemd[34735]: Started Sound Service.
 2月 07 19:43:32 Sulaco rtkit-daemon[921]: Supervising 7 threads of 3 processes of 2 users.
 2月 07 19:43:32 Sulaco rtkit-daemon[921]: Successfully made thread 34966 of process 34824 owned by '120' RT at priority 5.
 2月 07 19:43:32 Sulaco rtkit-daemon[921]: Supervising 6 threads of 3 processes of 2 users.
 2月 07 19:43:32 Sulaco rtkit-daemon[921]: Successfully made thread 34965 of process 34824 owned by '120' RT at priority 5.
 2月 07 19:43:32 Sulaco rtkit-daemon[921]: Supervising 5 threads of 3 processes of 2 users.
 2月 07 19:43:32 Sulaco org.gnome.Shell.desktop[34759]: Window manager warning: Overwriting existing binding of keysym 36 with keysym 36 (keycode f).
 2月 07 19:43:32 Sulaco org.gnome.Shell.desktop[34759]: Window manager warning: Overwriting existing binding of keysym 38 with keysym 38 (keycode 11).
 2月 07 19:43:32 Sulaco org.gnome.Shell.desktop[34759]: Window manager warning: Overwriting existing binding of keysym 35 with keysym 35 (keycode e).
 2月 07 19:43:32 Sulaco org.gnome.Shell.desktop[34759]: Window manager warning: Overwriting existing binding of keysym 39 with keysym 39 (keycode 12).
 2月 07 19:43:32 Sulaco org.gnome.Shell.desktop[34759]: Window manager warning: Overwriting existing binding of keysym 34 with keysym 34 (keycode d).
 2月 07 19:43:32 Sulaco org.gnome.Shell.desktop[34759]: Window manager warning: Overwriting existing binding of keysym 33 with keysym 33 (keycode c).
 2月 07 19:43:32 Sulaco org.gnome.Shell.desktop[34759]: Window manager warning: Overwriting existing binding of keysym 32 with keysym 32 (keycode b).
 2月 07 19:43:32 Sulaco org.gnome.Shell.desktop[34759]: Window manager warning: Overwriting existing binding of keysym 37 with keysym 37 (keycode 10).
 2月 07 19:43:32 Sulaco org.gnome.Shell.desktop[34759]: Window manager warning: Overwriting existing binding of keysym 31 with keysym 31 (keycode a).
 2月 07 19:43:32 Sulaco gsd-usb-protect[34843]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .se>
 2月 07 19:43:32 Sulaco gnome-shell[34759]: Error looking up permission: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for geolocation
 2月 07 19:43:32 Sulaco /usr/lib/gdm-wayland-session[34750]: dbus-daemon[34750]: [session uid=120 pid=34750] Successfully activated service 'org.gnome.ScreenSaver'
 2月 07 19:43:32 Sulaco NetworkManager[388]: <info>  [1644263012.2124] agent-manager: agent[2229db340ec913f6,:1.652/org.gnome.Shell.NetworkAgent/120]: agent registered
 2月 07 19:43:32 Sulaco kernel: rfkill: input handler disabled
 2月 07 19:43:32 Sulaco audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname>
 2月 07 19:43:32 Sulaco systemd[1]: Started Hostname Service.
 2月 07 19:43:32 Sulaco dbus-daemon[386]: [system] Successfully activated service 'org.freedesktop.hostname1'
 2月 07 19:43:32 Sulaco gsd-sharing[34841]: Failed to StopUnit service: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
 2月 07 19:43:32 Sulaco /usr/lib/gdm-wayland-session[34750]: dbus-daemon[34750]: [session uid=120 pid=34750] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.syst>
 2月 07 19:43:32 Sulaco /usr/lib/gdm-wayland-session[34750]: dbus-daemon[34750]: [session uid=120 pid=34750] Activating service name='org.freedesktop.systemd1' requested by ':1.13' (uid=120 >
 2月 07 19:43:32 Sulaco /usr/lib/gdm-wayland-session[34750]: dbus-daemon[34750]: [session uid=120 pid=34750] Activating service name='org.gnome.ScreenSaver' requested by ':1.12' (uid=120 pid>
 2月 07 19:43:32 Sulaco systemd[1]: Starting Hostname Service...
 2月 07 19:43:32 Sulaco audit: BPF prog-id=94 op=LOAD
 2月 07 19:43:32 Sulaco audit: BPF prog-id=93 op=LOAD
 2月 07 19:43:32 Sulaco audit: BPF prog-id=92 op=LOAD
 2月 07 19:43:32 Sulaco dbus-daemon[386]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.662' (uid=1>
 2月 07 19:43:32 Sulaco dbus-daemon[386]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.Avahi.service': Unit dbus-org.freedesktop.Avahi.service not found.
 2月 07 19:43:32 Sulaco dbus-daemon[386]: [system] Activating via systemd: service name='org.freedesktop.Avahi' unit='dbus-org.freedesktop.Avahi.service' requested by ':1.661' (uid=120 pid=3>
 2月 07 19:43:32 Sulaco /usr/lib/gdm-wayland-session[34750]: dbus-daemon[34750]: [session uid=120 pid=34750] Successfully activated service 'org.gnome.Shell.Notifications'
 2月 07 19:43:32 Sulaco /usr/lib/gdm-wayland-session[34831]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
 2月 07 19:43:32 Sulaco /usr/lib/gdm-wayland-session[34786]: dbus-daemon[34786]: Successfully activated service 'org.a11y.atspi.Registry'
 2月 07 19:43:32 Sulaco /usr/lib/gdm-wayland-session[34786]: dbus-daemon[34786]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=120 pid=34759 comm="/usr/bin/gnome>
 2月 07 19:43:32 Sulaco /usr/lib/gdm-wayland-session[34750]: dbus-daemon[34750]: [session uid=120 pid=34750] Activating service name='org.gnome.Shell.Notifications' requested by ':1.3' (uid=>
 2月 07 19:43:32 Sulaco polkitd[390]: Registered Authentication Agent for unix-session:3 (system bus name :1.652 [/usr/bin/gnome-shell], object path /org/freedesktop/PolicyKit1/Authenticatio>
 2月 07 19:43:32 Sulaco rtkit-daemon[921]: Successfully made thread 34824 of process 34824 owned by '120' high priority at nice level -11.
 2月 07 19:43:32 Sulaco systemd[34735]: Starting Sound Service...
 2月 07 19:43:32 Sulaco systemd[34735]: Created slice User Core Session Slice.
 2月 07 19:43:32 Sulaco audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=?>
 2月 07 19:43:32 Sulaco systemd[1]: Started Locale Service.
 2月 07 19:43:32 Sulaco dbus-daemon[386]: [system] Successfully activated service 'org.freedesktop.locale1'
 2月 07 19:43:32 Sulaco /usr/lib/gdm-wayland-session[34750]: dbus-daemon[34750]: [session uid=120 pid=34750] Activating service name='org.freedesktop.portal.IBus' requested by ':1.7' (uid=12>
 2月 07 19:43:32 Sulaco /usr/lib/gdm-wayland-session[34750]: dbus-daemon[34750]: [session uid=120 pid=34750] Successfully activated service 'org.freedesktop.impl.portal.PermissionStore'
 2月 07 19:43:31 Sulaco /usr/lib/gdm-wayland-session[34750]: dbus-daemon[34750]: [session uid=120 pid=34750] Activating service name='org.freedesktop.impl.portal.PermissionStore' requested b>
 2月 07 19:43:31 Sulaco systemd[1]: Starting Locale Service...
 2月 07 19:43:31 Sulaco audit: BPF prog-id=91 op=LOAD
 2月 07 19:43:31 Sulaco audit: BPF prog-id=90 op=LOAD
 2月 07 19:43:31 Sulaco audit: BPF prog-id=89 op=LOAD
 2月 07 19:43:31 Sulaco dbus-daemon[386]: [system] Activating via systemd: service name='org.freedesktop.locale1' unit='dbus-org.freedesktop.locale1.service' requested by ':1.652' (uid=120 p>
 2月 07 19:43:31 Sulaco gnome-shell[34759]: Will monitor session 3
 2月 07 19:43:31 Sulaco gnome-shell[34759]: Unset XDG_SESSION_ID, getCurrentSessionProxy() called outside a user session. Asking logind directly.
 2月 07 19:43:31 Sulaco gnome-shell[34759]: Skipping parental controls support as it’s disabled
 2月 07 19:43:31 Sulaco gnome-shell[34759]: Using Wayland display name 'wayland-0'
 2月 07 19:43:31 Sulaco gnome-shell[34759]: Using public X11 display :1024, (using :1025 for managed services)
 2月 07 19:43:31 Sulaco /usr/lib/gdm-wayland-session[34750]: dbus-daemon[34750]: [session uid=120 pid=34750] Successfully activated service 'org.a11y.Bus'
 2月 07 19:43:31 Sulaco /usr/lib/gdm-wayland-session[34750]: dbus-daemon[34750]: [session uid=120 pid=34750] Activating service name='org.a11y.Bus' requested by ':1.4' (uid=120 pid=34759 com>
 2月 07 19:43:31 Sulaco gnome-shell[34759]: Disabling DMA buffer screen sharing for driver 'amdgpu'.
 2月 07 19:43:31 Sulaco gnome-shell[34759]: Boot VGA GPU /dev/dri/card0 selected as primary
 2月 07 19:43:31 Sulaco gnome-shell[34759]: Created gbm renderer for '/dev/dri/card0'
 2月 07 19:43:31 Sulaco gnome-shell[34759]: Added device '/dev/dri/card0' (amdgpu) using atomic mode setting.
 2月 07 19:43:31 Sulaco gnome-shell[34759]: Device '/dev/dri/card0' prefers shadow buffer
 2月 07 19:43:31 Sulaco gnome-shell[34759]: Running GNOME Shell (using mutter 41.3) as a Wayland display server
 2月 07 19:43:31 Sulaco gnome-session-binary[34751]: WARNING: Could not parse desktop file orca-autostart.desktop or it references a not found TryExec binary
 2月 07 19:43:31 Sulaco gnome-session[34751]: gnome-session-binary[34751]: WARNING: Could not parse desktop file orca-autostart.desktop or it references a not found TryExec binary
 2月 07 19:43:31 Sulaco gnome-session-binary[34751]: GLib-GIO-CRITICAL: g_bus_get_sync: assertion 'error == NULL || *error == NULL' failed
 2月 07 19:43:31 Sulaco gnome-session[34751]: gnome-session-binary[34751]: GLib-GIO-CRITICAL: g_bus_get_sync: assertion 'error == NULL || *error == NULL' failed
 2月 07 19:43:31 Sulaco systemd[34735]: Started D-Bus User Message Bus.
 2月 07 19:43:31 Sulaco kernel: rfkill: input handler enabled
 2月 07 19:43:31 Sulaco audit[34724]: USER_START pid=34724 uid=0 auid=120 ses=3 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_succeed_if,pam_permit,pam_syst>
 2月 07 19:43:31 Sulaco gdm-launch-environment][34724]: pam_env(gdm-launch-environment:session): deprecated reading of user environment enabled
 2月 07 19:43:31 Sulaco systemd[34735]: Startup finished in 118ms.
 2月 07 19:43:31 Sulaco systemd[34735]: Reached target Main User Target.
 2月 07 19:43:31 Sulaco systemd[34735]: Finished Update XDG user dir configuration.
 2月 07 19:43:31 Sulaco systemd[1]: Started Session 3 of User gdm.
 2月 07 19:43:31 Sulaco systemd[34735]: Starting Update XDG user dir configuration...
 2月 07 19:43:31 Sulaco audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=?>
 2月 07 19:43:31 Sulaco systemd[1]: Started User Manager for UID 120.
 2月 07 19:43:31 Sulaco systemd[34735]: Reached target Basic System.
 2月 07 19:43:31 Sulaco systemd[34735]: Reached target Sockets.
 2月 07 19:43:31 Sulaco systemd[34735]: Listening on D-Bus User Message Bus Socket.
 2月 07 19:43:31 Sulaco systemd[34735]: Listening on Sound System.
 2月 07 19:43:31 Sulaco systemd[34735]: Listening on PipeWire Multimedia System Socket.
 2月 07 19:43:31 Sulaco systemd[34735]: Listening on p11-kit server.
 2月 07 19:43:31 Sulaco systemd[34735]: Listening on GnuPG cryptographic agent and passphrase cache.
 2月 07 19:43:31 Sulaco systemd[34735]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
 2月 07 19:43:31 Sulaco systemd[34735]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
 2月 07 19:43:31 Sulaco systemd[34735]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
 2月 07 19:43:31 Sulaco systemd[34735]: Listening on GCR ssh-agent wrapper.
 2月 07 19:43:31 Sulaco systemd[34735]: Listening on GnuPG network certificate management daemon.
 2月 07 19:43:31 Sulaco systemd[34735]: Starting D-Bus User Message Bus Socket...
 2月 07 19:43:31 Sulaco systemd[34735]: Reached target Timers.
 2月 07 19:43:31 Sulaco systemd[34735]: Reached target Paths.
 2月 07 19:43:31 Sulaco systemd[34735]: Created slice User Application Slice.
 2月 07 19:43:31 Sulaco systemd[34735]: Queued start job for default target Main User Target.
 2月 07 19:43:31 Sulaco audit: BPF prog-id=0 op=UNLOAD
 2月 07 19:43:31 Sulaco audit: PROCTITLE proctitle=2F7573722F6C69622F73797374656D642F73797374656D64002D2D75736572
 2月 07 19:43:31 Sulaco audit[34735]: SYSCALL arch=c000003e syscall=321 success=yes exit=8 a0=5 a1=7ffedf1d7160 a2=78 a3=7ffedf1d7160 items=0 ppid=1 pid=34735 auid=120 uid=120 gid=120 euid=1>
 2月 07 19:43:31 Sulaco audit: BPF prog-id=88 op=LOAD
 2月 07 19:43:31 Sulaco kernel: audit: type=1006 audit(1644263011.088:403): pid=34735 uid=0 subj==unconfined old-auid=4294967295 auid=120 tty=(none) old-ses=4294967295 ses=4 res=1
 2月 07 19:43:31 Sulaco kernel: audit: type=1103 audit(1644263011.088:402): pid=34735 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="gdm" exe="/us>
 2月 07 19:43:31 Sulaco kernel: audit: type=1101 audit(1644263011.088:401): pid=34735 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_uni>
 2月 07 19:43:31 Sulaco audit[34735]: USER_START pid=34735 uid=0 auid=120 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_systemd_home,pam_>
 2月 07 19:43:31 Sulaco systemd[34735]: pam_env(systemd-user:session): deprecated reading of user environment enabled
 2月 07 19:43:31 Sulaco systemd[34735]: pam_unix(systemd-user:session): session opened for user gdm(uid=120) by (uid=0)
 2月 07 19:43:31 Sulaco systemd[34735]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[gdm] ruser=[<unknown>] rhost=[<unknown>
 2月 07 19:43:31 Sulaco audit: PROCTITLE proctitle="(systemd)"
 2月 07 19:43:31 Sulaco audit[34735]: SYSCALL arch=c000003e syscall=1 success=yes exit=3 a0=9 a1=7fffe8cb0ce0 a2=3 a3=78 items=0 ppid=1 pid=34735 auid=120 uid=0 gid=0 euid=0 suid=0 fsuid=0 e>
 2月 07 19:43:31 Sulaco audit[34735]: CRED_ACQ pid=34735 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="gdm" exe="/usr/lib/systemd/systemd" hostna>
 2月 07 19:43:31 Sulaco audit[34735]: USER_ACCT pid=34735 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct=">
 2月 07 19:43:31 Sulaco systemd[34735]: pam_systemd_home(systemd-user:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
 2月 07 19:43:31 Sulaco dbus-daemon[386]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
 2月 07 19:43:31 Sulaco dbus-daemon[386]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.648' (uid=0 pid=347>
 2月 07 19:43:31 Sulaco kernel: audit: type=1130 audit(1644263011.085:400): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@120 comm="systemd" exe="/us>
 2月 07 19:43:31 Sulaco systemd[1]: Starting User Manager for UID 120...
 2月 07 19:43:31 Sulaco audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostn>
 2月 07 19:43:31 Sulaco systemd[1]: Finished User Runtime Directory /run/user/120.
 2月 07 19:43:31 Sulaco gdm-password][34730]: pam_systemd_home(gdm-password:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
 2月 07 19:43:31 Sulaco dbus-daemon[386]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.647' (uid=0 pid=347>
 2月 07 19:43:31 Sulaco systemd-logind[393]: New session 3 of user gdm.
 2月 07 19:43:31 Sulaco systemd[1]: Starting User Runtime Directory /run/user/120...
 2月 07 19:43:31 Sulaco systemd[1]: Created slice User Slice of UID 120.
 2月 07 19:43:31 Sulaco kernel: audit: type=1327 audit(1644263011.071:399): proctitle=67646D2D73657373696F6E2D776F726B6572205B70616D2F67646D2D6C61756E63682D656E7669726F6E6D656E745D
 2月 07 19:43:31 Sulaco kernel: audit: type=1300 audit(1644263011.071:399): arch=c000003e syscall=1 success=yes exit=3 a0=8 a1=7ffc68c79260 a2=3 a3=78 items=0 ppid=441 pid=34724 auid=120 uid>
 2月 07 19:43:31 Sulaco kernel: audit: type=1006 audit(1644263011.071:399): pid=34724 uid=0 subj==unconfined old-auid=4294967295 auid=120 tty=(none) old-ses=4294967295 ses=3 res=1
 2月 07 19:43:31 Sulaco kernel: audit: type=1103 audit(1644263011.071:398): pid=34724 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="gdm">
 2月 07 19:43:31 Sulaco kernel: audit: type=1101 audit(1644263011.071:397): pid=34724 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_succeed_if,pam>
 2月 07 19:43:31 Sulaco audit: PROCTITLE proctitle=67646D2D73657373696F6E2D776F726B6572205B70616D2F67646D2D6C61756E63682D656E7669726F6E6D656E745D
 2月 07 19:43:31 Sulaco audit[34724]: SYSCALL arch=c000003e syscall=1 success=yes exit=3 a0=8 a1=7ffc68c79260 a2=3 a3=78 items=0 ppid=441 pid=34724 auid=120 uid=0 gid=120 euid=0 suid=0 fsuid>
 2月 07 19:43:31 Sulaco audit[34724]: CRED_ACQ pid=34724 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="gdm" exe="/usr/lib/gdm-session-wo>
 2月 07 19:43:31 Sulaco audit[34724]: USER_ACCT pid=34724 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_succeed_if,pam_permit acct="gdm" exe="/usr>
 2月 07 19:43:31 Sulaco kernel: audit: type=1100 audit(1644263011.068:396): pid=34724 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_succeed_if>
 2月 07 19:43:31 Sulaco audit[34724]: USER_AUTH pid=34724 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_succeed_if,pam_permit acct="gdm" exe=">
 2月 07 19:43:31 Sulaco gdm[441]: GLib-GObject: g_object_set_is_valid_property: object class 'GdmLocalDisplay' has no property named 'supported-session-tyes'
 2月 07 19:43:09 Sulaco gnome-shell[826]: #0   56025207b018 i   resource:///org/gnome/gjs/modules/core/overrides/Gio.js:114 (223aa2cd7e70 @ 28)
 2月 07 19:43:09 Sulaco gnome-shell[826]: == Stack trace for context 0x56025187b1e0 ==
 2月 07 19:43:09 Sulaco gnome-shell[826]: Object Gio.DBusProxy (0x56025493d960), has been already disposed β€” impossible to access it. This might be caused by the object having been destroyed>
 2月 07 19:43:09 Sulaco gnome-shell[826]: #6   560258d5abd8 i   self-hosted:693 (20561150dc40 @ 15)
 2月 07 19:43:09 Sulaco gnome-shell[826]: #5   560258d5ac80 i   resource:///org/gnome/shell/ui/calendar.js:249 (20561157c150 @ 538)
 2月 07 19:43:09 Sulaco gnome-shell[826]: #4   560258d5ad28 i   resource:///org/gnome/shell/ui/calendar.js:277 (20561157bec0 @ 44)
 2月 07 19:43:09 Sulaco gnome-shell[826]: #3   560258d5adc0 i   resource:///org/gnome/shell/ui/calendar.js:338 (20561157bd30 @ 215)
 2月 07 19:43:09 Sulaco gnome-shell[826]: #2   560258d5ae70 i   resource:///org/gnome/gjs/modules/core/overrides/Gio.js:147 (223aa2cd7d80 @ 45)
 2月 07 19:43:09 Sulaco gnome-shell[826]: #1   560258d5af28 i   resource:///org/gnome/gjs/modules/core/overrides/Gio.js:129 (223aa2cd7ec0 @ 1218)
 2月 07 19:43:09 Sulaco gnome-shell[826]: #0   7fffe7df46a0 b   resource:///org/gnome/gjs/modules/core/overrides/Gio.js:418 (223aa2cd7470 @ 180)
 2月 07 19:43:09 Sulaco gnome-shell[826]: Object Gio.DBusProxy (0x56025493d960), has been already disposed β€” impossible to connect to any signal on it. This might be caused by the object hav>
 2月 07 19:43:09 Sulaco gnome-shell[826]: Object Gio.DBusProxy (0x56025493d960), has been already disposed β€” impossible to add toggle reference on it. This might be caused by the object havi>
 2月 07 19:43:09 Sulaco gnome-shell[826]: #1   560258d5abd8 i   self-hosted:693 (20561150dc40 @ 15)
 2月 07 19:43:09 Sulaco gnome-shell[826]: #0   560258d5ac80 i   resource:///org/gnome/shell/ui/calendar.js:242 (20561157c150 @ 470)
 2月 07 19:43:09 Sulaco gnome-shell[826]: #0   560258d5ac80 i   resource:///org/gnome/shell/ui/calendar.js:235 (20561157c150 @ 438)
 2月 07 19:43:09 Sulaco gnome-shell[826]: #2   560258d5abd8 i   self-hosted:693 (20561150dc40 @ 15)
 2月 07 19:43:09 Sulaco gnome-shell[826]: #1   560258d5ac80 i   resource:///org/gnome/shell/ui/calendar.js:228 (20561157c150 @ 304)
 2月 07 19:43:09 Sulaco gnome-shell[826]: #0   7fffe7df4d00 b   resource:///org/gnome/gjs/modules/core/_signals.js:22 (223aa2cd94c0 @ 97)
 2月 07 19:43:09 Sulaco gnome-shell[826]: #0   7fffe7df4d00 b   resource:///org/gnome/gjs/modules/core/_signals.js:21 (223aa2cd94c0 @ 86)
 2月 07 19:43:09 Sulaco gnome-shell[826]: #0   56025207b018 i   resource:///org/gnome/gjs/modules/core/overrides/Gio.js:424 (223aa2cd7330 @ 71)
 2月 07 19:43:09 Sulaco gnome-shell[826]: Spurious clutter_actor_allocate called for actor 0x5602567ff630/<dashtodockContainer>[<Gjs_dash-to-dock_micxgx_gmail_com_docking_DashToDock>:0x56025>
 2月 07 19:43:09 Sulaco gnome-shell[826]: st_widget_get_theme_node called on the widget [0x5602567ff630 Gjs_dash-to-dock_micxgx_gmail_com_docking_DashToDock.bottom dashtodock running-dots au>
 2月 07 19:43:09 Sulaco gnome-shell[826]: INFO: [kt timers] Detaching indicator from timers
 2月 07 19:43:09 Sulaco gnome-shell[826]: INFO: [kt indicator] Initializing extension
 2月 07 19:43:09 Sulaco gnome-shell[826]: INFO: [kt timers] Attaching indicator
 2月 07 19:43:09 Sulaco kernel: audit: type=1130 audit(1644262989.117:395): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd>
 2月 07 19:43:09 Sulaco audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? >
 2月 07 19:43:09 Sulaco systemd[1]: Started Fingerprint Authentication Daemon.
 2月 07 19:43:09 Sulaco dbus-daemon[386]: [system] Successfully activated service 'net.reactivated.Fprint'
 2月 07 19:43:09 Sulaco kernel: audit: type=1334 audit(1644262989.067:394): prog-id=87 op=LOAD
 2月 07 19:43:09 Sulaco systemd[1]: Starting Fingerprint Authentication Daemon...
 2月 07 19:43:09 Sulaco audit: BPF prog-id=87 op=LOAD
 2月 07 19:43:09 Sulaco dbus-daemon[386]: [system] Activating via systemd: service name='net.reactivated.Fprint' unit='fprintd.service' requested by ':1.24' (uid=1000 pid=826 comm="/usr/bin/>
 2月 07 19:41:52 Sulaco wpa_supplicant[691]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
 2月 07 19:41:40 Sulaco org.fcitx.Fcitx5.desktop[1156]: I2022-02-07 19:41:40.423819 instance.cpp:1268] End autosave
 2月 07 19:41:40 Sulaco org.fcitx.Fcitx5.desktop[1156]: I2022-02-07 19:41:40.397124 instance.cpp:1266] Running autosave...
The issue remains with 21.2.5 / Gnome 41.4
