Idk what to do. Couple days ago I was using the KDE partition manger and out of no where for an unknown reason something happened that caused the app to become unresponsive and not open up. Clicking on it multiple times just caused it to freeze up my entire computer and eventually I decided to forcefully shut the computer down to fix it which may have not been the wisest choice. Since then whenever I try to log in after entering my username and password the login screen just starts becoming completely frozen. I can still move my mouse, the screen will turn off after a couple minutes of inactivity, and am able to use CTRL + F2 but besides that I canât get to my desktop.
Iâve been looking for a solution to this online for like an entire day and canât seem to find a fix that I know how to put into the command line. I started using Linux since I heard almost everything can now be done using the GUI and now all of a sudden I can only use the command line that I have no clue how to use. I have ProtonVPN with a kill switch installed that auto starts with the computer so any command that makes me need to update/reinstall x11/x.org assumes I have an internet connection which the vpn is most likely blocking.
Cat fstab says âno such file or directoryâ.
Also when I do inxi âadmin âverbosity=7 âfilter âwidth | curl -F âclbin=<â https://clbin.com it says curl: (26) Failed to open/read local data from file/application
Iâm noticing two /dev/sdd3 while /dev/sdd4 has duplicate mount points. Is this what the initial error message I got was referring to and if so which one would I remove and with what command?
Btw I was able to use sudo startx to login as root where I could only see/use some of my apps. I decided to once again use KDE partition manager (specifically itâs âchange mount pointsâ of the drives being partioned feature) and it made the situation even worse by putting me in emergency mode now. So, that app has some major bugs and is probably whatâs causing these issues.
