rrd
24 September 2021 15:15
1
I just installed manjaro to a Dell G15 laptop.
On boot the login screen does not appear. If I switch to tty2 and than back to tty1, the login screen apperas.
I found similar problems in the forum, but did not managed to find a solution for my setup.
Please post output of inxi -Fazy --filter
rrd
24 September 2021 15:17
3
inxi -Fazy --filter ✔
Kernel: 5.13.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=6b97925a-c2a0-4906-9a82-eaeb4a9a4d71 rw quiet nvme_load=YES splash
Desktop: GNOME 40.4 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
Type: Laptop System: Dell product: Dell G15 5510 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0983D5 v: A00 serial: <filter> UEFI: Dell v: 1.3.1
date: 03/29/2021
ID-1: BAT0 charge: 54.9 Wh (100.0%) condition: 54.9/54.9 Wh (100.0%)
volts: 13.0 min: 11.4 model: BYD DELL DVG8M14 type: Li-poly serial: <filter>
status: Full
Info: Quad Core model: Intel Core i5-10200H bits: 64 type: MT MCP
arch: Comet Lake family: 6 model-id: A5 (165) stepping: 2 microcode: EA
cache: L2: 8 MiB
bogomips: 38408
Speed: 900 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 900 2: 900 3: 900
4: 900 5: 900 6: 900 7: 901 8: 900
Device-1: Intel vendor: Dell driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:9ba4 class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Dell
driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1f9d class-ID: 0300
Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-5:2 chip-ID: 0bda:565c class-ID: 0e02 serial: <filter>
Display: x11 server: X.org 1.20.13 compositor: gnome-shell driver:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT1) v: 4.6 Mesa 21.2.1
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Dell
driver: sof-audio-pci-intel-cnl
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
chip-ID: 8086:06c8 class-ID: 0401
Device-2: NVIDIA driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 10de:10fa class-ID: 0403
Sound Server-1: ALSA v: k5.13.15-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.35 running: yes
Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
port: 5000 bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
vendor: Dell driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0
bus-ID: 1-14:3 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 476.94 GiB used: 23.07 GiB (4.8%)
model: PC SN530 NVMe WDC 512GB size: 476.94 GiB block-size: physical: 512 B
rev: 21112012 temp: 42.9 C scheme: GPT
ID-1: / raw-size: 476.65 GiB size: 468.09 GiB (98.21%)
used: 23.07 GiB (4.9%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
used: 300 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 47.0 C mobo: N/A
Processes: 304 Uptime: 12m wakeups: 971 Memory: 7.55 GiB
used: 2.09 GiB (27.6%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1145 lib: 289 flatpak: 0 Shell: Zsh v: 5.8
running-in: gnome-terminal inxi: 3.3.06
What happens if you just wait without switching to tty?
rrd
24 September 2021 15:30
5
I waited for a few minutes. It just hangs.
winnie
24 September 2021 15:34
6
Did you try switching to exclusive proprietary and/or using PRIME or Optimus?
I just bought a new Dell G15, installed Manjaro Gnome from the latest iso using the entire disk, deleteing all particions.
The installaion went throught, but on restarting the system hangs on the Dell logo for minutes. If I switch it off, a manjaro logo comes up below the Dell logo for a second.
I reinstalled Manjaro just in case, but it is the same.
rrd
24 September 2021 15:38
7
not yet. I was not clear what should I set up here.
Actually I can not change anything here.
winnie
24 September 2021 15:42
8
It looks like it’s already installed (PRIME for the Nvidia and Intel GPUs, dGPU and iGPU respectively.)
winnie
24 September 2021 15:43
9
Can you paste results from journalctl -b
after rebooting?
rrd
24 September 2021 16:32
10
winnie
24 September 2021 16:50
11
Can you also add i915 to the MODULES array in /etc/mkinitcpio.conf
then rebuild the initramfs with mkinicpio -P
Another thing to try is to reconfigure/reinstall GDM.
rrd
24 September 2021 16:55
12
Adding i915 to the modules solved the issue.
Thank you so much.
winnie
24 September 2021 16:59
13
Welcome! Good luck going forwards with your daily usage of the hybrid graphics (Nvidia dGPU + Intel iGPU). I intentionally avoid such systems, personally, so I can only defer to others who use them regularly when it comes to gaming, performance, battery life, etc.
I err towards Intel-only for laptop , and Nvidia-only for desktop / sheer performance. I’ve read too many mixed stories about Nvidia/Intel hybrid laptops.
system
Closed
27 September 2021 07:00
14
