I am stuck in a login loop, and when I tried to" use the console bypass with “startx” I got the return “Argument list to long” and that has remained the return for any command I run to try to fix it. cd is the only command that seems to work right now. Please help
Try:
startx /usr/bin/startplasma-x11
startx /usr/bin/startxfce4
startx /usr/bin/gnome-session
Hi @Catfish1243,
Not being an Xfce user, I’d suggest booting into a live environment, entering a chroot environment, and re-syncing your system. If that doesn’t work, you can get logs from the chroot environment that might be of help.
How to chroot
Ensure you’ve got a relatively new ISO or at least one with a still supported LTS kernel.
Write/copy/
ddthe ISO to a USB thumb drive. -
When done, boot with the above mentioned USB thumb drive into the live environment.
Once booted, open a terminal and enter the following command to enter the
chrootencironment:
manjaro-chroot -a
- If you have more than one Linux installation, select the correct one to use from the list provided.
When done, you should now be in the chroot environment.
But, be careful, as you’re now in an actual root environment on your computer, so any changes you make will persist after a restart.
In the chroot environment, you can now check that everything is up-to-date:
pamac checkupdates
If it isn’t, run update:
pamac update
If it is, or the update didn’t make a difference, please enter the chroot environment again, and provide the output of:
journalctl --boot=-1 --priority=warning..err
Tip:
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
For more information, please see:
Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Did not help, so here is part of the whole journal. I am on the live boot curently.
Sep 23 16:48:43 CatfishCreations kernel: Speculative Return Stack Overflow: IBPB-extending microcode not applied!
Sep 23 16:48:43 CatfishCreations kernel: Speculative Return Stack Overflow: WARNING: See https://kernel.org/doc/html/latest/admin-guide/hw-vuln/srso.html for mitigation options.
Sep 23 16:48:43 CatfishCreations kernel: #7 #8 #9 #10 #11
Sep 23 16:48:43 CatfishCreations kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GPP1.PTXH.RHUB.POT9], AE_NOT_FOUND (20230331/dswload2-162)
Sep 23 16:48:43 CatfishCreations kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20230331/psobject-220)
Sep 23 16:48:43 CatfishCreations kernel: pci 0000:00:00.2: can't derive routing for PCI INT A
Sep 23 16:48:43 CatfishCreations kernel: pci 0000:00:00.2: PCI INT A: not connected
Sep 23 16:48:43 CatfishCreations kernel: ata5: failed to resume link (SControl 0)
Sep 23 16:48:43 CatfishCreations kernel: acpi PNP0C14:02: duplicate WMI GUID 97845ED0-4E6D-11DE-8A39-0800200C9A66 (first instance was on PNP0C14:00)
Sep 23 16:48:43 CatfishCreations kernel: asus_wmi: Failed to get WMI notify code: AE_NOT_FOUND
Sep 23 16:48:43 CatfishCreations kernel: asus_wmi: Failed to get event during flush: -5
Sep 23 16:48:43 CatfishCreations (udev-worker)[361]: event4: Failed to call EVIOCSKEYCODE with scan code 0x7c, and key code 190: Invalid argument
Sep 23 16:48:43 CatfishCreations kernel: kvm_amd: SVM disabled (by BIOS) in MSR_VM_CR on CPU 7
Sep 23 16:48:43 CatfishCreations kernel: nvidia: loading out-of-tree module taints kernel.
Sep 23 16:48:43 CatfishCreations kernel: nvidia: module license 'NVIDIA' taints kernel.
Sep 23 16:48:43 CatfishCreations kernel: Disabling lock debugging due to kernel taint
Sep 23 16:48:43 CatfishCreations kernel: nvidia: module license taints kernel.
Sep 23 16:48:44 CatfishCreations kernel:
Sep 23 16:48:44 CatfishCreations kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 535.104.05 Sat Aug 19 01:15:15 UTC 2023
Sep 23 16:48:44 CatfishCreations kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
Sep 23 16:48:44 CatfishCreations kernel: r8168 Copyright (C) 2022 Realtek NIC software team <nicfae@realtek.com>
This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
Sep 23 16:48:45 CatfishCreations systemd[1]: Cannot find unit for notify message of PID 875, ignoring.
Sep 23 16:48:45 CatfishCreations systemd[1]: Cannot find unit for notify message of PID 876, ignoring.
Sep 23 16:48:45 CatfishCreations kernel: kauditd_printk_skb: 55 callbacks suppressed
Sep 23 16:48:45 CatfishCreations (uetoothd)[988]: bluetooth.service: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Sep 23 16:48:45 CatfishCreations systemd[1]: snapd.service: Got notification message from PID 995, but reception only permitted for main PID 813
Sep 23 16:48:45 CatfishCreations bluetoothd[988]: src/plugin.c:plugin_init() System does not support csip plugin
Sep 23 16:48:45 CatfishCreations bluetoothd[988]: src/plugin.c:plugin_init() System does not support vcp plugin
Sep 23 16:48:45 CatfishCreations bluetoothd[988]: src/plugin.c:plugin_init() System does not support mcp plugin
Sep 23 16:48:45 CatfishCreations bluetoothd[988]: src/plugin.c:plugin_init() System does not support bass plugin
Sep 23 16:48:45 CatfishCreations bluetoothd[988]: src/plugin.c:plugin_init() System does not support bap plugin
Sep 23 16:48:45 CatfishCreations kernel: Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
Sep 23 16:48:45 CatfishCreations NetworkManager[867]: <warn> [1695512925.4866] device (enp10s0): connectivity: "/proc/sys/net/ipv4/conf/enp10s0/rp_filter" is set to "1". This might break connectivity checking for IPv4 on this device
Sep 23 16:48:47 CatfishCreations kernel: Xorg[1025]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
Sep 23 16:48:48 CatfishCreations lightdm[1306]: gkr-pam: no password is available for user
Sep 23 16:48:48 CatfishCreations lightdm[1306]: gkr-pam: couldn't unlock the login keyring.
Sep 23 16:48:49 CatfishCreations wpa_supplicant[1232]: bgscan simple: Failed to enable signal strength monitoring
Sep 23 16:49:04 CatfishCreations NetworkManager[867]: <warn> [1695512944.7123] dispatcher: (10) failed (after 0.000 sec): Refusing activation, D-Bus is shutting down.
ESCOD
ESCOD
ESCOD
ESCOD
ESCOD
Hello @Catfish1243 ![]()
Sorry, but it is not. Use this for the whole journal:
journalctl --boot=-1 | curl -F'file=@-' https://0x0.st
It will print a link and internet access is necessary.
Additionally add your system information of your local installation:
inxi -v7azy
Note that you need to chroot (switch to local installation), to get real local information and not information of the live session.
https://0x0.st/HVHB.txt <— Like so?
12System:
12Kernel 6.5.3-1-MANJARO 12arch x86_64 12bits 64 12compiler gcc 12v 13.2.1
12clocksource tsc 12available hpet,acpi_pm
12parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_CINNAMON_2301 quiet
systemd.show_status=1 apparmor=1 security=apparmor driver=nonfree
nouveau.modeset=0 i915.modeset=1 radeon.modeset=1
12Desktop Cinnamon 12v 5.8.4 12tk GTK 12v 3.24.38 12dm N/A 12Distro Manjaro Linux
12base Arch Linux
12Machine:
12Type Desktop 12System ASUS 12product N/A 12v N/A 12serial N/A
12Mobo ASUSTeK 12model PRIME B550M-A WIFI II 12v Rev X.0x 12serial <filter>
12UEFI American Megatrends 12v 2806 12date 10/27/2022
12Battery:
12Message No system battery data found. Is one present?
12Memory:
12System RAM 12total 32 GiB 12available 31.14 GiB 12used 5.71 GiB (18.3%)
12Array-1 12capacity 128 GiB 12slots 4 12modules 4 12EC None 12max-module-size 32 GiB
12note est.
12Device-1 DIMM_A1 12type DDR4 12detail synchronous unbuffered (unregistered)
12size 8 GiB 12speed 2400 MT/s 12volts 12curr 1.2 12min 1.2 12max 1.2 12width (bits)
12data 64 12total 64 12manufacturer A-DATA 12part-no DDR4 2400 2OZ 12serial <filter>
12Device-2 DIMM_A2 12type DDR4 12detail synchronous unbuffered (unregistered)
12data 64 12total 64 12manufacturer Silicon-Power 12part-no N/A 12serial N/A
12Device-3 DIMM_B1 12type DDR4 12detail synchronous unbuffered (unregistered)
12Device-4 DIMM_B2 12type DDR4 12detail synchronous unbuffered (unregistered)
12CPU:
12Info 12model AMD Ryzen 5 5500 12socket AM4 12bits 64 12type MT MCP 12arch Zen 3 12gen 4
12level v3 12note check 12built 2021-22 12process TSMC n7 (7nm) 12family 0x19 (25)
12model-id 0x50 (80) 12stepping 0 12microcode 0xA50000D
12Topology 12cpus 1x 12cores 6 12tpc 2 12threads 12 12smt enabled 12cache 12L1 384 KiB
12desc d-6x32 KiB; i-6x32 KiB 12L2 3 MiB 12desc 6x512 KiB 12L3 16 MiB 12desc 1x16 MiB
12Speed (MHz) 12avg 1249 12high 3800 12min/max 400/4506 12base/boost 3800/4250
12scaling 12driver amd-pstate-epp 12governor powersave 12volts 1.4 V
12ext-clock 100 MHz 12cores 121 400 122 400 123 3799 124 400 125 400 126 3799 127 400 128 3800
129 400 1210 400 1211 400 1212 400 12bogomips 91227
12Flags 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
12Vulnerabilities
12Type gather_data_sampling 12status Not affected
12Type itlb_multihit 12status Not affected
12Type l1tf 12status Not affected
12Type mds 12status Not affected
12Type meltdown 12status Not affected
12Type mmio_stale_data 12status Not affected
12Type retbleed 12status Not affected
12Type spec_rstack_overflow 12mitigation safe RET, no microcode
12Type spec_store_bypass 12mitigation Speculative Store Bypass disabled via
12Type spectre_v1 12mitigation usercopy/swapgs barriers and __user pointer
12Type spectre_v2 12mitigation Retpolines, IBPB: conditional, IBRS_FW, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
12Type srbds 12status Not affected
12Type tsx_async_abort 12status Not affected
12Graphics:
12Device-1 NVIDIA GA106 [Geforce RTX 3050] 12vendor Exar 12driver nvidia
12v 535.104.05 12alternate nouveau,nvidia_drm 12non-free 535.xx+
12status current (as of 2023-08) 12arch Ampere 12code GAxxx 12process TSMC n7 (7nm)
12built 2020-22 12pcie 12gen 1 12speed 2.5 GT/s 12lanes 8 12link-max 12gen 4
12speed 16 GT/s 12lanes 16 12bus-ID 01:00.0 12chip-ID 10de:2507 12class-ID 0300
12Display 12server X.Org 12v 21.1.8 12with Xwayland 12v 23.2.0 12driver 12X 12loaded nvidia
12gpu nvidia 12display-ID :0 12screens 1
12Screen-1 0 12s-res 1920x1080 12s-dpi 101 12s-size 483x272mm (19.02x10.71")
12s-diag 554mm (21.82")
12Monitor-1 Unknown-1 12mapped HDMI-0 12res 1920x1080 12hz 60 12dpi 102
12size 477x268mm (18.78x10.55") 12modes 1024x768
12API OpenGL 12v 4.6.0 NVIDIA 535.104.05 12renderer NVIDIA GeForce RTX
3050/PCIe/SSE2 12direct-render Yes
12Audio:
12Device-1 NVIDIA GA106 High Definition Audio 12vendor Exar 12driver snd_hda_intel
12v kernel 12pcie 12gen 3 12speed 8 GT/s 12lanes 8 12link-max 12gen 4 12speed 16 GT/s
12lanes 16 12bus-ID 01:00.1 12chip-ID 10de:228e 12class-ID 0403
12Device-2 AMD Renoir Radeon High Definition Audio 12vendor ASUSTeK
12driver snd_hda_intel 12v kernel 12pcie 12gen 3 12speed 8 GT/s 12lanes 16 12link-max 12gen 4
12speed 16 GT/s 12bus-ID 0b:00.1 12chip-ID 1002:1637 12class-ID 0403
12Device-3 AMD Family 17h/19h HD Audio 12vendor ASUSTeK 12driver snd_hda_intel
12v kernel 12pcie 12gen 3 12speed 8 GT/s 12lanes 16 12link-max 12gen 4 12speed 16 GT/s
12bus-ID 0b:00.6 12chip-ID 1022:15e3 12class-ID 0403
12Device-4 Generalplus Usb Audio Device
12driver hid-generic,snd-usb-audio,usbhid 12type USB 12rev 1.1 12speed 12 Mb/s
12lanes 1 12mode 1.1 12bus-ID 1-8:5 12chip-ID 1b3f:2008 12class-ID 0300
12serial <filter>
12API ALSA 12v k6.5.3-1-MANJARO 12status kernel-api 12with aoss 12type oss-emulator
12tools alsactl,alsamixer,amixer
12Server-1 JACK 12v 1.9.22 12status off 12tools N/A
12Server-2 PipeWire 12v 0.3.80 12status off 12with 121 pipewire-pulse 12status off
122 pipewire-media-session 12status off 123 pipewire-alsa 12type plugin
12tools pactl,pw-cat,pw-cli
12Network:
12Device-1 MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
12vendor AzureWave 12driver mt7921e 12v kernel 12pcie 12gen 2 12speed 5 GT/s 12lanes 1
12bus-ID 09:00.0 12chip-ID 14c3:7961 12class-ID 0280
12IF wlp9s0 12state up 12mac <filter>
12IP v4 <filter> 12type dynamic noprefixroute 12scope global 12broadcast <filter>
12IP v6 <filter> 12type noprefixroute 12scope link
12Device-2 Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
12vendor ASUSTeK PRIME B450M-A 12driver r8169 12v kernel 12modules r8168 12pcie 12gen 1
12speed 2.5 GT/s 12lanes 1 12port e000 12bus-ID 0a:00.0 12chip-ID 10ec:8168
12class-ID 0200
12IF enp10s0 12state down 12mac <filter>
12WAN IP <filter>
12Bluetooth:
12Device-1 IMC Networks Wireless_Device 12driver btusb 12v 0.8 12type USB 12rev 2.1
12speed 480 Mb/s 12lanes 1 12mode 2.0 12bus-ID 1-5:3 12chip-ID 13d3:3563 12class-ID e001
12serial <filter>
12Report btmgmt 12ID hci0 12rfk-id 1 12state up 12address <filter> 12bt-v 5.2 12lmp-v 11
12status 12discoverable no 12pairing no 12class-ID 7c0104
12Logical:
12Message No logical block device data found.
12RAID:
12Message No RAID data found.
12Drives:
12Local Storage 12total 1.43 TiB 12used 407.49 GiB (27.8%)
12SMART Message Required tool smartctl not installed. Check --recommends
12ID-1 /dev/sda 12maj-min 8:0 12model SSD 12size 931.51 GiB 12block-size
12physical 512 B 12logical 512 B 12speed 6.0 Gb/s 12tech SSD 12serial <filter>
12fw-rev 9B0
12ID-2 /dev/sdb 12maj-min 8:16 12vendor Silicon Power 12model SPCC M.2 SSD
12size 476.94 GiB 12block-size 12physical 512 B 12logical 512 B 12speed 6.0 Gb/s
12tech SSD 12serial <filter> 12fw-rev 8B0
12ID-3 /dev/sdc 12maj-min 8:32 12vendor SanDisk 12model Cruzer Glide 12size 57.3 GiB
12block-size 12physical 512 B 12logical 512 B 12type USB 12rev 2.0 12spd 480 Mb/s 12lanes 1
12mode 2.0 12tech N/A 12serial <filter> 12fw-rev 1.00
12Message No optical or floppy data found.
12Partition:
12ID-1 / 12raw-size 476.64 GiB 12size 468.09 GiB (98.21%) 12used 407.49 GiB (87.1%)
12fs ext4 12block-size 4096 B 12dev /dev/sdb2 12maj-min 8:18 12label N/A
12uuid e80252c0-9cdb-480c-b85d-cae6132c25fc
12ID-2 /boot/efi 12raw-size 300 MiB 12size 299.4 MiB (99.80%) 12used 312 KiB (0.1%)
12fs vfat 12block-size 512 B 12dev /dev/sdb1 12maj-min 8:17 12label NO_LABEL
12uuid 6CA5-12BF
12Swap:
12Alert No swap data was found.
12Unmounted:
12ID-1 /dev/sda1 12maj-min 8:1 12size 931.51 GiB 12fs ext4 12label SATA SSD 1TB
12uuid d76d28a3-69fb-4d09-9ff6-49a8d587a5b7
12ID-2 /dev/sdc1 12maj-min 8:33 12size 3.49 GiB 12fs N/A
12label MANJARO_CINNAMON_2301 12uuid 2023-09-21-14-14-20-00
12ID-3 /dev/sdc2 12maj-min 8:34 12size 4 MiB 12fs N/A 12label MISO_EFI 12uuid 76E0-1EE9
12USB:
12Hub-1 1-0:1 12info hi-speed hub with single TT 12ports 10 12rev 2.0
12speed 480 Mb/s (57.2 MiB/s) 12lanes 1 12mode 2.0 12chip-ID 1d6b:0002 12class-ID 0900
12Device-1 1-3:2 12info SanDisk Cruzer Glide 12type mass storage
12driver usb-storage 12interfaces 1 12rev 2.0 12speed 480 Mb/s (57.2 MiB/s) 12lanes 1
12mode 2.0 12power 200mA 12chip-ID 0781:5575 12class-ID 0806 12serial <filter>
12Device-2 1-5:3 12info IMC Networks Wireless_Device 12type bluetooth
12driver btusb 12interfaces 3 12rev 2.1 12speed 480 Mb/s (57.2 MiB/s) 12lanes 1
12mode 2.0 12power 100mA 12chip-ID 13d3:3563 12class-ID e001 12serial <filter>
12Device-3 1-6:4 12info ASUSTek AURA LED Controller 12type HID
12driver hid-generic,usbhid 12interfaces 2 12rev 2.0 12speed 12 Mb/s (1.4 MiB/s)
12lanes 1 12mode 1.1 12power 16mA 12chip-ID 0b05:1939 12class-ID 0300 12serial <filter>
12Device-4 1-8:5 12info Generalplus Usb Audio Device 12type audio,HID
12driver hid-generic,snd-usb-audio,usbhid 12interfaces 3 12rev 1.1
12speed 12 Mb/s (1.4 MiB/s) 12lanes 1 12mode 1.1 12power 100mA 12chip-ID 1b3f:2008
12Hub-2 2-0:1 12info super-speed hub 12ports 4 12rev 3.1 12speed 10 Gb/s (1.16 GiB/s)
12lanes 1 12mode 3.2 gen-2x1 12chip-ID 1d6b:0003 12class-ID 0900
12Hub-3 3-0:1 12info hi-speed hub with single TT 12ports 4 12rev 2.0
12Hub-4 4-0:1 12info super-speed hub 12ports 2 12rev 3.1 12speed 10 Gb/s (1.16 GiB/s)
12Hub-5 5-0:1 12info hi-speed hub with single TT 12ports 4 12rev 2.0
12Device-1 5-1:2 12info Primax Dynex 5-Button Wired Optical Mouse 12type mouse
12driver hid-generic,usbhid 12interfaces 1 12rev 2.0 12speed 1.5 Mb/s (183 KiB/s)
12lanes 1 12mode 1.0 12power 100mA 12chip-ID 0461:4d42 12class-ID 0301
12Device-2 5-2:3 12info Darfon HP USB Keyboard 12type keyboard,HID
12driver hid-generic,usbhid 12interfaces 2 12rev 2.0 12speed 1.5 Mb/s (183 KiB/s)
12lanes 1 12mode 1.0 12power 100mA 12chip-ID 0d62:911e 12class-ID 0300
12Hub-6 6-0:1 12info super-speed hub 12ports 2 12rev 3.1 12speed 10 Gb/s (1.16 GiB/s)
12Sensors:
12System Temperatures 12cpu 52.1 C 12mobo N/A 12gpu nvidia 12temp 40 C
12Fan Speeds (rpm) N/A 12gpu nvidia 12fan 0%
12Info:
12Processes 319 12Uptime 1h 25m 12wakeups 0 12Init systemd 12v 254 12default graphical
12tool systemctl 12Compilers 12gcc 13.2.1 12clang 16.0.6 12Packages 12pm pacman 12pkgs 1885
12libs 490 12tools pamac,trizen,yay 12Client Unknown Client: systemd 12inxi 3.3.29
At least we know now that your Desktop Environment is Cinnamon and you Display-Manager is LightDM, what is pretty much important.
Probably you have not enough free space… ext4 takes 11% - 16% of the raw partition, so:
1% → filesystem
5% → reserved for root
5-10% → Journal
476.64 - 11% ~ 424GB available
476.64 - 16% ~ 400GB available
Depending on how many small files you have, the journal can grow to its max, but how much the journal allocate here, is not visible. However, lightdm is known to loop at login, when it cannot write to the disk.
The golden rule here is to always keep 20% of the root file system free. Maybe next time separate your home folder to another partition.
So took the nuclear option and just reformated my drive then reinstalled Manjaro. Not a satisfactory result, but it got the job done at the cost of all my files on that drive. Luckily I had a second drive that was only about 2/5 full of stuff, sadly it wouldn’t let me recover my main drive to my second drive, so I still lost all my files. Lesson learned I’m going to backup up my drive from now on onto a large HDD. My SSDs will run my system, files, game, and ect. and the HDD just hold my backups.
If anyone finds any other fixes let people know please, make sure this post is helpful to people who need it.
