Im looking for arch based derivative that has customized lightweight desktop and works with vmware workstation. Since vmware is unsupported. It looks like i will have to elsewhere. I don’t appreciate the passive aggressive undertone
I guess there is indeed no point then in keeping the thread open. But then don’t start a new one about the same subject.
Well, then you shouldn’t set the example of what you deem “passive-aggressive”. All I’ve seen from you in this thread so far is “I don’t like that. I don’t want that. It shouldn’t be like it is”, and similar complaints, all because of some insignificant thing that’s most likely just because you’re using vmware
instead of virtualbox
, or because you don’t understand how things work in a UNIX operating system.
I wish you good luck.
