Hello \o
I’m currently using two monitors and one of them always has the login prompt upon boot.
Problem is, that monitor is slower than my main monitor and it’s pivoted witch means login prompt is tilted. Upon logging in when screensaver hits, login prompt is at my main monitor (the right one).
I know, i know, this is a minor inconvenience but it still annoys me and i want to fix it somehow.
It seems like monitor 1 & 2 should be the other way around.
Does anyone know how to fix this and wanna help out?
My `inxi -Fazy` output:
Kernel: 5.15.7-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=c6e13d02-6bad-4f72-9962-5c5f7b5ba396 rw quiet apparmor=1
security=apparmor resume=UUID=195bc30c-4b27-4815-a4a9-40576b3dbf77
udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: Micro-Star model: X370 SLI PLUS (MS-7A33) v: 2.0
serial: <superuser required> UEFI: American Megatrends v: 3.JS
date: 07/01/2020
Info: model: AMD Ryzen 5 3600X bits: 64 type: MT MCP arch: Zen 2
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 2293 high: 3597 min/max: 2200/4409 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2118
3: 2053 4: 2595 5: 2048 6: 2198 7: 3597 8: 2057 9: 2057 10: 2200 11: 2197
12: 2202 bogomips: 91245
conditional, RSB filling
Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: ASUSTeK driver: nvidia
v: 470.86 alternate: nouveau,nvidia_drm bus-ID: 2e:00.0 chip-ID: 10de:1b81
class-ID: 0300
Display: x11 server: X.Org 1.21.1.2 compositor: xfwm4 v: 4.16.1 driver:
loaded: nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3000x1920 s-dpi: 96 s-size: 794x508mm (31.3x20.0")
s-diag: 943mm (37.1")
Monitor-1: HDMI-0 res: 1080x1920 hz: 60
Monitor-2: DP-2 res: 1920x1080 dpi: 92 size: 531x299mm (20.9x11.8")
diag: 609mm (24")
OpenGL: renderer: NVIDIA GeForce GTX 1070/PCIe/SSE2 v: 4.6.0 NVIDIA 470.86
direct render: Yes
Device-1: NVIDIA GP104 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 2e:00.1 chip-ID: 10de:10f0
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 30:00.4 chip-ID: 1022:1487
class-ID: 0403
Device-3: Astro Gaming A50 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-1.3:3 chip-ID: 9886:0015
class-ID: 0300
Sound Server-1: ALSA v: k5.15.7-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel port: f000 bus-ID: 29:00.0
IF: enp41s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 2.5 TiB used: 153.15 GiB (6.0%)
model: WDS512G1X0C-00ENX0 size: 476.94 GiB block-size: physical: 512 B
rev: B35500WD temp: 57.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD20EFRX-68EUZN0 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 0A82 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Corsair model: Corsair Force LE SSD
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 12.2 scheme: MBR
ID-1: / raw-size: 459.45 GiB size: 451.17 GiB (98.20%)
used: 153.15 GiB (33.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: partition size: 17.19 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 56 C
Processes: 297 Uptime: 14m wakeups: 0 Memory: 15.63 GiB
used: 1.78 GiB (11.4%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: N/A Packages: 1183 pacman: 1174 lib: 343 flatpak: 0 snap: 9 Shell: Bash
v: 5.1.12 running-in: xfce4-terminal inxi: 3.3.11
