We have REL 7.8 and REL 7.5 and one of my users wants to see his “File Manager” folder icon on his REL 7.8 machine look like a ‘folder’ icon and not a ‘file’ icon. On my REL 7.5 host, my “File Manager” icon does display a ‘folder’ icon.
REL 7.8 - Thunar 1.6.16
REL 7.5 - Thunar 1.6.11
Any way to change the icons? It’s trivial but my user states it really bothers him.
All should use the icons as defined in the selected theme ; and the first two can be individually changed, from menulibre and the launcher’s properties respectively.
I’m not able to upload a ‘jpg’ to show which icon but basically when open “File Manager” from the ‘Applications’ it pops up my /home/dir/ and the icons are displayed. Hope this helps. Thanks again.
Well, i don’t know enough about Thunar to tell where to look. The only idea i have is to try changing / reinstalling the icon theme, or try another file manager like pcmanfm to check whether it’s an application issue or a theme issue.
