Greetings! I recently installed Manjaro (21.1.16 stable it seems) with KDE Plasma on my system (R5 2600, GTX 1070 Ti, 16gb RAM, SSD) after using Windows my whole life (except a brief stint with MacOS) and I’m really liking it, but I’m having strange lag with the UI. Sometimes when scrolling my mouse through the task bar (equivalent of Windows’ start menu), the highlighted option doesn’t update until I actually move my mouse.
The other thing is that maximizing and minimizing windows has very clear hiccups, which annoy me alot because I like my OS to be smooth (as anyone would). This is all before I installed any apps (besides the driver for my Wi-Fi adapter)
I installed build-devel and kernel headers, and even on a clean install I had these issues. I installed 5.14 kernel from the menus, hoping it might help. I installed what seems to be the latest NVIDIA drivers. I tried I believe all compositors and it didn’t change anything
I’ll be happy to run any commands I can input for information to help you guys investigate this issue. Please write down these commands here and I’ll copy paste them.
I recommend installing Manjaro 21.1.6 first.
Sorry I made a mistake, that’s the one I installed
Which graphics driver is installed ?
Open source and the one from Nvidia ?
inxi -Fza
on console.
Here’s what that command gave me.
System: Kernel: 5.14.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64 root=UUID=ea67c09d-3775-40c1-8e80-0670602ae0eb rw quiet apparmor=1
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Machine: Type: Desktop System: Gigabyte product: B450M S2H v: N/A serial: <filter>
Mobo: Gigabyte model: B450M S2H v: x.x serial: <filter> UEFI: American Megatrends v: F41 date: 07/22/2019
Battery: Device-1: hidpp_battery_0 model: Logitech G305 Lightspeed Wireless Gaming Mouse serial: <filter>
charge: 100% (should be ignored) rechargeable: yes status: Discharging
CPU: Info: 6-Core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+ family: 17 (23) model-id: 8 stepping: 2
microcode: 800820D cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 81468
Speed: 1376 MHz min/max: 1550/3400 MHz boost: enabled Core speeds (MHz): 1: 1376 2: 1377 3: 1369 4: 2822 5: 1293
6: 1557 7: 1369 8: 1478 9: 2575 10: 1304 11: 1522 12: 1468
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: disabled, RSB filling
Graphics: Device-1: NVIDIA GP104 [GeForce GTX 1070 Ti] vendor: Micro-Star MSI driver: nvidia v: 470.63.01
alternate: nouveau,nvidia_drm bus-ID: 0a:00.0 chip-ID: 10de:1b82 class-ID: 0300
Device-2: Sunplus Innovation Canyon CNS-CWC5 Webcam type: USB driver: snd-usb-audio,uvcvideo bus-ID: 5-3.2.4:7
chip-ID: 1bcf:2284 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 5760x2160 s-dpi: 54 s-size: 2709x1016mm (106.7x40.0") s-diag: 2893mm (113.9")
Monitor-1: HDMI-0 res: 3840x2160 hz: 60 dpi: 154 size: 632x360mm (24.9x14.2") diag: 727mm (28.6")
Monitor-2: DP-5 res: 1920x1080 hz: 60 dpi: 55 size: 885x498mm (34.8x19.6") diag: 1015mm (40")
OpenGL: renderer: NVIDIA GeForce GTX 1070 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Audio: Device-1: NVIDIA GP104 High Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 0a:00.1
chip-ID: 10de:10f0 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 0c:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: ASUSTek Xonar SoundCard type: USB driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1:2
chip-ID: 0b05:189d class-ID: 0300
Device-4: C-Media Blue Snowball type: USB driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-1:2 chip-ID: 0d8c:0005
class-ID: 0300 serial: <filter>
Device-5: Sunplus Innovation Canyon CNS-CWC5 Webcam type: USB driver: snd-usb-audio,uvcvideo bus-ID: 5-3.2.4:7
Sound Server-1: ALSA v: k5.14.10-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8169 v: kernel
port: f000 bus-ID: 09:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp9s0 state: down mac: <filter>
Device-2: TP-Link Archer T2U PLUS [RTL8821AU] type: USB driver: rtl88XXau bus-ID: 1-7:2 chip-ID: 2357:0120
class-ID: 0000 serial: <filter>
IF: wlp2s0f0u7 state: up mac: <filter>
Drives: Local Storage: total: 2.29 TiB used: 10.74 GiB (0.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Smartbuy model: m.2 PS5013-2280T 512GB size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: EDFM00E3 temp: 32.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: DT01ACA200 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: ABB0 scheme: GPT
Partition: ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%) used: 10.74 GiB (2.3%) fs: ext4 dev: /dev/nvme0n1p2
maj-min: 259:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1
Swap: Alert: No swap data was found.
Sensors: System Temperatures: cpu: 38.2 C mobo: 16.8 C gpu: nvidia temp: 57 C
Info: Processes: 286 Uptime: 1h 44m wakeups: 7 Memory: 15.58 GiB used: 2.85 GiB (18.3%) Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1223 lib: 334 flatpak: 0 Shell: Zsh v: 5.8 default: Bash
v: 5.1.8 running-in: konsole inxi: 3.3.07
There where it shows the drivers in the hardware configuration, it doesn’t show the open source drivers as being checked,
Olli
13 November 2021 12:29
6
i recommend to use the original nvidia driver instead of open nouveau-driver. this lacks too much, same with mine 1050ti. check the wiki how to do this first
omano
13 November 2021 12:50
7
Install the Nvidia drivers from the Manjaro Settings tool, do not download and install from Nvidia website.
Sorry for the noob question, how exactly do I do this through the terminal? I’m guessing I need to both uninstall the current drivers and download the new ones through pamac?
It seems I already installed the proprietary drivers through the settings app…
I’ll try this very soon, as soon as I’m at my computer and report back!
omano
13 November 2021 13:18
11
Maybe try to configure your Compositor and Nvidia Settings (click to open the album)
you can check theses command
nvidia-smi
sudo systemd-analyze blame
sudo pacman -S htop
htop ( q for quit )
sudo journalctl -b0 -p4 ( for errors on boot current )
stephane:
nvidia-smi
nvidia-smi -
| NVIDIA-SMI 470.63.01 Driver Version: 470.63.01 CUDA Version: 11.4 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:0A:00.0 On | N/A |
| 29% 59C P0 39W / 180W | 1240MiB / 8116MiB | 1% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| 0 N/A N/A 528 G /usr/lib/Xorg 612MiB |
| 0 N/A N/A 911 G /usr/bin/kwin_x11 248MiB |
| 0 N/A N/A 1023 G /usr/bin/plasmashell 158MiB |
| 0 N/A N/A 13494 G /usr/bin/systemmonitor 5MiB |
| 0 N/A N/A 13917 G /usr/lib/firefox/firefox 189MiB |
| 0 N/A N/A 17346 G /usr/bin/systemsettings5 17MiB |
6min 44.177s man-db.service
4.601s pkgfile-update.service
1.480s systemd-random-seed.service
1.160s systemd-rfkill.service
628ms systemd-modules-load.service
422ms snapd.service
335ms apparmor.service
332ms tlp.service
181ms dev-nvme0n1p2.device
147ms ModemManager.service
105ms user@1000.service
105ms lvm2-monitor.service
103ms ldconfig.service
81ms upower.service
62ms systemd-udev-trigger.service
62ms boot-efi.mount
60ms systemd-tmpfiles-clean.service
56ms polkit.service
54ms systemd-journal-flush.service
53ms udisks2.service
52ms logrotate.service
46ms NetworkManager-wait-online.service
44ms systemd-udevd.service
43ms systemd-journald.service
34ms systemd-logind.service
32ms avahi-daemon.service
29ms NetworkManager.service
23ms cups.service
22ms packagekit.service
17ms systemd-tmpfiles-setup.service
15ms systemd-sysusers.service
12ms modprobe@fuse.service
12ms systemd-fsck@dev-disk-by\x2duuid-A492\x2dB37E.service
12ms systemd-journal-catalog-update.service
10ms systemd-binfmt.service
10ms wpa_supplicant.service
9ms dev-hugepages.mount
9ms systemd-tmpfiles-setup-dev.service
9ms user-runtime-dir@1000.service
9ms dev-mqueue.mount
9ms sys-kernel-debug.mount
8ms sys-kernel-tracing.mount
8ms systemd-sysctl.service
sudo pacman -S htop - it installed something
-- Journal begins at Sat 2021-11-13 14:39:12 +07, ends at Sun 2021-11-14 12:00:47 +07. --
ноя 13 17:27:49 ben-b450ms2h kernel: Expanded resource Reserved due to conflict with PCI Bus 0000:00
ноя 13 17:27:49 ben-b450ms2h kernel: nvme nvme0: missing or invalid SUBNQN field.
ноя 13 17:27:49 ben-b450ms2h kernel: usb: port power management may be unreliable
ноя 13 17:27:49 ben-b450ms2h kernel: acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
ноя 13 17:27:49 ben-b450ms2h kernel: ACPI Warning: SystemIO range 0x0000000000000B00-0x0000000000000B08 conflicts with OpRegion 0x0000000000000B00-0x0000000000000B0F (\GSA1.SMBI) (20210604/>
ноя 13 17:27:49 ben-b450ms2h kernel: nvidia: loading out-of-tree module taints kernel.
ноя 13 17:27:49 ben-b450ms2h kernel: nvidia: module license 'NVIDIA' taints kernel.
ноя 13 17:27:49 ben-b450ms2h kernel: Disabling lock debugging due to kernel taint
ноя 13 17:27:50 ben-b450ms2h kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 470.63.01 Tue Aug 3 20:44:16 UTC 2021
ноя 13 17:27:50 ben-b450ms2h kernel: kvm: disabled by bios
ноя 13 17:27:50 ben-b450ms2h kernel: kauditd_printk_skb: 29 callbacks suppressed
ноя 13 17:27:51 ben-b450ms2h kernel: kvm: disabled by bios
ноя 13 17:27:51 ben-b450ms2h kernel: hid-generic 0003:0D8C:0005.0001: No inputs registered, leaving
ноя 13 17:27:51 ben-b450ms2h kernel: hid-generic 0003:0B05:189D.0002: No inputs registered, leaving
ноя 13 17:27:51 ben-b450ms2h kernel: usb 5-3.2.4: Warning! Unlikely big volume range (=4096), cval->res is probably wrong.
ноя 13 17:27:51 ben-b450ms2h kernel: usb 5-3.2.4: [5] FU [Mic Capture Volume] ch = 1, val = 0/4096/1
ноя 13 17:27:51 ben-b450ms2h systemd-xdg-autostart-generator[758]: Configuration file /home/ben/.config/autostart/org.kde.yakuake.desktop is marked executable. Please remove executable perm>
ноя 13 17:27:52 ben-b450ms2h systemd-xdg-autostart-generator[853]: Configuration file /home/ben/.config/autostart/org.kde.yakuake.desktop is marked executable. Please remove executable perm>
ноя 13 17:27:52 ben-b450ms2h ksplashqml[809]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath2-2021.desktop/contents/splash/Splash.qml:74:28: Unable to assign int to QEasingCurve
ноя 13 17:27:52 ben-b450ms2h klauncher[894]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
ноя 13 17:27:52 ben-b450ms2h kcminit_startup[900]: QDBusConnection: error: could not send signal to service "" path "//home/ben/.kde4/share/config/kdeglobals" interface "org.kde.kconfig.not>
ноя 13 17:27:53 ben-b450ms2h kwin_x11[911]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5089:46: this compose sequence is a duplicate of another; skipping line
ноя 13 17:27:53 ben-b450ms2h kwin_x11[911]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5091:48: this compose sequence is a duplicate of another; skipping line
ноя 13 17:27:53 ben-b450ms2h kwin_x11[911]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5093:48: this compose sequence is a duplicate of another; skipping line
ноя 13 17:27:53 ben-b450ms2h kwin_x11[911]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5097:47: this compose sequence is a duplicate of another; skipping line
ноя 13 17:27:53 ben-b450ms2h kwin_x11[911]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5099:46: this compose sequence is a duplicate of another; skipping line
ноя 13 17:27:53 ben-b450ms2h kwin_x11[911]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5107:48: this compose sequence is a duplicate of another; skipping line
ноя 13 17:27:53 ben-b450ms2h kwin_x11[911]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5111:46: this compose sequence is a duplicate of another; skipping line
ноя 13 17:27:53 ben-b450ms2h kwin_x11[911]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5113:46: this compose sequence is a duplicate of another; skipping line
ноя 13 17:27:53 ben-b450ms2h kwin_x11[911]: kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5117:45: this compose sequence is a duplicate of another; skipping line
your are using nvidia drivers
is there also 2 monitors videos connected ?
can you return
sudo mhwd -li ( list installed )
sudo mhwd -l ( all drivers videis possible )
maybe wait new driver version nvidia
gan
14 November 2021 08:42
15
You have the man-db.service running for 6min!
I think this is the culprit.
Maybe check with the smartmontools if your hard disk is developing problems, because on your machine 6min is too long.
I have an SSD…it should be installed on my SSD. Maybe I should try formatting my HDD, even though none of my Linux installation is on there?
First command gives this -
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2020.11.30 false PCI
Second command gives this -
> 0000:09:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
network-r8168 2016.04.20 true PCI
> 0000:0a:00.0 (0300:10de:1b82) Display controller nVidia Corporation:
video-nvidia-390xx 2020.11.30 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
gan
14 November 2021 10:33
18
When a disk (ssd or hd) has problems, usually tends to slow down the system, even when it is not the one where the system is installed.
I would check both discs.
You can do it with the tool smartctl
in the console (HERE a good tutorial) or, if you want to do it with a GUI, you can install GSmartControl with:
sudo pacman -S gsmartcontrol
If you have never done this check on the disks (or for a long time), not even from Windows, I suggest you do an extended self-test, which will last some time, otherwise a short test (few minutes) is enough.
you can remove video-linux ( only free drivers video )
sudo mhwd -r pci video-linux
In GSmartControl, my HDD shows up but my SSD shows “UNKNOWN DEVICE”, could this be a hint to the problem?
