Did this just now)
I know GSmartControl had, some years ago, problems with the m.2 disks, but now it would be ok.
You can try with the smartctl command in the console:
sudo smartctl -t /dev/nvme0n1
and after a few minutes,
sudo smartctl -a /dev/nvme0n1
If smartctl doesn’t work too, maybe you could check the disk with some tool from the vendor Smartbuy (I don’t know it, so I can’t be more specific, sorry).
Anyway, check the other HDD (Toshiba) with GSmartControl/smartctl (at least a short test).
More exactly, see if the RAW values of the ‘Reallocated_Sector_Count
’, ‘Spin_Retry_Count
’, and ‘Current_Pending_Sector
’ properties are ZERO; otherwise your disc is at risk of breaking.
I don’t know for sure if the lag problem in your system is a disk problem (mine is just a suspect), but it’s still a good idea to check your disks from time to time.
Unplug the HDD and boot, see if it solves anything instead of going through all this. Smart could still be read even if the program doesn’t know your disk.
EDIT: Share sudo inxi --admin --verbosity=7 --filter --width
to provide good system information for support, it will give more info than above (edit the initial post where you already posted inxi info).
Do sudo smartctl -t /dev/… takes only max 5 minutes.
Disconnected all cables, open the pc, unplug, close, reconnected… how long does it take?
I don’t understand anything.
Is it a question or a statement?
How long does what take? To disconnect the HDD?
To disconnect the HDD have you to open the case of pc?
If you have, like me, your PC under your desk, it’s not very easy to do, don’t you think?
In any case, checking the health of the discs is always advisable.
Then, it will be up to @HorseyMD to evaluate what to do.
If you want the reason at all costs, no problem. I close it here.
I believe I have given some good advice.
Here is inxi
Kernel: 5.14.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=ea67c09d-3775-40c1-8e80-0670602ae0eb rw quiet apparmor=1
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Gigabyte product: B450M S2H v: N/A serial: <filter>
Mobo: Gigabyte model: B450M S2H v: x.x serial: <filter>
UEFI: American Megatrends v: F41 date: 07/22/2019
Device-1: hidpp_battery_0
model: Logitech G305 Lightspeed Wireless Gaming Mouse serial: <filter>
charge: 100% (should be ignored) rechargeable: yes status: Discharging
RAM: total: 15.58 GiB used: 2.54 GiB (16.3%)
Info: 6-Core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+
family: 17 (23) model-id: 8 stepping: 2 microcode: 800820D cache: L2: 3 MiB
bogomips: 81465
Speed: 2692 MHz min/max: 1550/3400 MHz boost: enabled Core speeds (MHz):
1: 2692 2: 2255 3: 1542 4: 1546 5: 1557 6: 1544 7: 1547 8: 1547 9: 2021
10: 2045 11: 1426 12: 1546
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rapl rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca
sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall
tce topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
disabled, RSB filling
Device-1: NVIDIA GP104 [GeForce GTX 1070 Ti] vendor: Micro-Star MSI
driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 0a:00.0
chip-ID: 10de:1b82 class-ID: 0300
Device-2: Sunplus Innovation Canyon CNS-CWC5 Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 5-3.2.4:7 chip-ID: 1bcf:2284
class-ID: 0102 serial: <filter>
Screen-1: 0 s-res: 5760x2160 s-dpi: 154 s-size: 950x361mm (37.4x14.2")
s-diag: 1016mm (40")
Monitor-1: HDMI-0 res: 3840x2160 hz: 60 dpi: 154
size: 632x360mm (24.9x14.2") diag: 727mm (28.6")
Monitor-2: DP-5 res: 1920x1080 hz: 60 dpi: 55 size: 885x498mm (34.8x19.6")
diag: 1015mm (40")
OpenGL: renderer: NVIDIA GeForce GTX 1070 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Device-1: NVIDIA GP104 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 0a:00.1 chip-ID: 10de:10f0
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus-ID: 0c:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: ASUSTek Xonar SoundCard type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1:2 chip-ID: 0b05:189d
class-ID: 0300
Device-4: C-Media Blue Snowball type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-1:2 chip-ID: 0d8c:0005
class-ID: 0300 serial: <filter>
Device-5: Sunplus Innovation Canyon CNS-CWC5 Webcam type: USB
Sound Server-1: ALSA v: k5.14.10-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
vendor: Gigabyte driver: r8169 v: kernel port: f000 bus-ID: 09:00.0
IF: enp9s0 state: down mac: <filter>
Device-2: TP-Link Archer T2U PLUS [RTL8821AU] type: USB driver: rtl88XXau
bus-ID: 1-7:6 chip-ID: 2357:0120 class-ID: 0000 serial: <filter>
IF: wlp2s0f0u7 state: up mac: <filter>
Local Storage: total: 2.29 TiB used: 18.09 GiB (0.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Smartbuy
model: m.2 PS5013-2280T 512GB size: 476.94 GiB block-size: physical: 512 B
rev: EDFM00E3 temp: 32.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: DT01ACA200 size: 1.82 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD
rpm: 7200 serial: <filter> rev: ABB0 scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
used: 18.09 GiB (3.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: ea67c09d-3775-40c1-8e80-0670602ae0eb
label: NO_LABEL uuid: A492-B37E
ID-1: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sda2 maj-min: 8:2 size: 1.82 TiB fs: ntfs label: Games
uuid: 181C7A591C7A31BC
Device-1: 1-7:6 info: TP-Link Archer T2U PLUS [RTL8821AU] type: Network
driver: rtl88XXau interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 500mA
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Device-1: 3-1:2 info: ASUSTek Xonar SoundCard type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 7 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 0b05:189d class-ID: 0300
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 5-1:2 info: C-Media Blue Snowball type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0d8c:0005 class-ID: 0300
serial: <filter>
Device-2: 5-2:3 info: Logitech USB Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c53f class-ID: 0300
Hub-6: 5-3:4 info: Huasheng USB2.0 HUB ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 214b:7250 class-ID: 0900
Hub-7: 5-3.2:6 info: Super Top Hub [Super Top] ports: 4 rev: 2.0
speed: 480 Mb/s power: 100mA chip-ID: 14cd:8608 class-ID: 0900
Device-1: 5-3.2.4:7 info: Sunplus Innovation Canyon CNS-CWC5 Webcam
type: Video,Audio driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 1bcf:2284 class-ID: 0102
serial: <filter>
Device-2: 5-4:5 info: Corsair Gaming K55 RGB Keyboard type: Keyboard,HID
power: 500mA chip-ID: 1b1c:1b3d class-ID: 0300 serial: <filter>
Hub-8: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 47.1 C mobo: 16.8 C gpu: nvidia temp: 61 C
Processes: 300 Uptime: 1h 17m wakeups: 3 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 Packages: 1269 pacman: 1256 lib: 354
flatpak: 5 snap: 8 Shell: Zsh v: 5.8 default: Bash v: 5.1.8
running-in: konsole inxi: 3.3.08
This command gave me an error, I’ll try to unplug my HDD
the command I gave should have provided better info. Do the command I gave, update your message.
In your system settings, rendering backend, is it configured to opengl? if not, configure it for opengl.
In your display settings, is your refresh rate correctly configured?
If this still doesn’t work, you can try repacing kwin with kwinft, it’s a faster and more responsive re-write of kwin, but it’s also a beta product so you may experience some issues when using it.
If all else fails, you can either switch to testing or wait until the stable branch of manjaro updates to use the nvidia 490 driver series (should be fairly soon i think 1 or 2 weeks; if you can’t wait, just switch to testing), and use wayland instead of X
Or just use another desktop environment, by the sound of it you’re new to linux and you want something similar to windows, there’s a lot of environments that can provide you with what you want, KDE is just the most popular one, you could try XFCE, Cinnamon or Mate for example.
I’m sorry for sounding stupid, I’m not sure which command you’re referring to as it seems I ran all the commands you’ve been referring to…I unplugged my HDD right now and I’ll see what smart control says
All of these commands threw back the following error
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.14.10-1-MANJARO] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
=======> INVALID ARGUMENT TO -t: /dev/nvme0n1
=======> VALID ARGUMENTS ARE: offline, short, long, conveyance, force, vendor,N, select,M-N, pending,N, afterselect,[on|off] <=======
Use smartctl -h to get a usage summary
This is the information output from SmartControl GUI, it still says UNKNOWN DEVICE
=== START OF INFORMATION SECTION ===
Model Number: m.2 Smartbuy PS5013-2280T 512GB
Serial Number: 296E079B18FC00009970
Firmware Version: EDFM00E3
PCI Vendor/Subsystem ID: 0x1987
IEEE OUI Identifier: 0x6479a7
Total NVM Capacity: 512 110 190 592 [512 GB]
Unallocated NVM Capacity: 0
Controller ID: 1
NVMe Version: 1.3
Number of Namespaces: 1
Namespace 1 Size/Capacity: 512 110 190 592 [512 GB]
Namespace 1 Formatted LBA Size: 512
Namespace 1 IEEE EUI-64: 6479a7 2b10823730
Local Time is: Sun Nov 14 23:21:31 2021 +07
Firmware Updates (0x12): 1 Slot, no Reset required
Optional Admin Commands (0x001f): Security Format Frmw_DL NS_Mngmt Self_Test
Optional NVM Commands (0x005e): Wr_Unc DS_Mngmt Wr_Zero Sav/Sel_Feat Timestmp
Log Page Attributes (0x0e): Cmd_Eff_Lg Ext_Get_Lg Telmtry_Lg
Maximum Data Transfer Size: 64 Pages
Warning Comp. Temp. Threshold: 68 Celsius
Critical Comp. Temp. Threshold: 70 Celsius
Supported Power States
St Op Max Active Idle RL RT WL WT Ent_Lat Ex_Lat
0 + 4.50W - - 0 0 0 0 0 0
1 + 2.70W - - 1 1 1 1 0 0
2 + 2.16W - - 2 2 2 2 0 0
3 - 0.0700W - - 3 3 3 3 1000 1000
4 - 0.0020W - - 4 4 4 4 5000 60000
Supported LBA Sizes (NSID 0x1)
Id Fmt Data Metadt Rel_Perf
0 + 512 0 1
1 - 4096 0 0
=== START OF SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
I’m starting to think that the SSD might be the issue because booting does seem to take a bit of time. Not too long, maybe 10-11 seconds on the Manjaro start screen. With how light Manjaro is compared to WIndows, I’d expect quicker, but maybe I’m just being unrealistic
Sorry, I forgot an argument:
sudo smartctl -t short -a /dev/nvme0n1
I’m referring exactly to the command I gave. I gave only one.
//EDIT: anyway if you successfully got your SMART result now, whatever.
I’m sorry, I ran it without the sudo it seems! My fault…
Here’s the new output:
Console: pty pts/2 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
base: Arch Linux
Type: Desktop System: Gigabyte product: B450M S2H v: N/A serial: N/A
Mobo: Gigabyte model: B450M S2H v: x.x serial: N/A UEFI: American Megatrends
RAM: total: 15.58 GiB used: 2.56 GiB (16.4%)
Array-1: capacity: 128 GiB slots: 4 EC: None max-module-size: 32 GiB
note: est.
Device-1: DIMM 0 size: No Module Installed
Device-2: DIMM 1 size: 8 GiB speed: 3000 MT/s type: DDR4
detail: synchronous unbuffered (unregistered) bus-width: 64 bits
total: 64 bits manufacturer: A-DATA Technology part-no: DDR4 3000
serial: <filter>
Device-3: DIMM 0 size: No Module Installed
Device-4: DIMM 1 size: 8 GiB speed: 3000 MT/s type: DDR4
serial: <filter>
Info: 6-Core model: AMD Ryzen 5 2600 socket: AM4 bits: 64 type: MT MCP
arch: Zen+ family: 17 (23) model-id: 8 stepping: 2 microcode: 800820D cache:
L1: 576 KiB L2: 3 MiB L3: 16 MiB bogomips: 81466
Speed: 2518 MHz min/max: 1550/3400 MHz base/boost: 3400/3900 boost: enabled
volts: 1.1 V ext-clock: 100 MHz Core speeds (MHz): 1: 2518 2: 1331 3: 1374
4: 1373 5: 1326 6: 1373 7: 1374 8: 1375 9: 2621 10: 1472 11: 1334 12: 1373
Display: server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: nvidia
diag: 1015mm (40")
class-ID: 0403
class-ID: 0300
Local Storage: total: 476.94 GiB used: 18.14 GiB (3.8%)
rev: EDFM00E3 temp: 36.9 C scheme: GPT
SMART: yes health: PASSED on: 374d 7h cycles: 990
read-units: 99,081,144 [50.7 TB] written-units: 56,123,616 [28.7 TB]
used: 18.14 GiB (3.9%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2 label: N/A uuid: ea67c09d-3775-40c1-8e80-0670602ae0eb
used: 288 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: NO_LABEL uuid: A492-B37E
serial: <filter>
serial: <filter>
System Temperatures: cpu: 38.0 C mobo: 16.8 C gpu: nvidia temp: 61 C
Processes: 305 Uptime: 13m wakeups: 3 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 Packages: 1272 pacman: 1259 lib: 354 flatpak: 5
snap: 8 Shell: Zsh (sudo) v: 5.8 default: Bash v: 5.1.8 running-in: konsole
inxi: 3.3.08
SMART/Health Information (NVMe Log 0x02)
Critical Warning: 0x00
Temperature: 35 Celsius
Available Spare: 100%
Available Spare Threshold: 5%
Percentage Used: 5%
Data Units Read: 99 081 178 [50,7 TB]
Data Units Written: 56 123 631 [28,7 TB]
Host Read Commands: 501 161 363
Host Write Commands: 523 442 077
Controller Busy Time: 20 660
Power Cycles: 990
Power On Hours: 8 983
Unsafe Shutdowns: 245
Media and Data Integrity Errors: 0
Error Information Log Entries: 1 576
Warning Comp. Temperature Time: 0
Critical Comp. Temperature Time: 0
Error Information (NVMe Log 0x01, 16 of 16 entries)
Num ErrCount SQId CmdId Status PELoc LBA NSID VS
0 1576 0 0x1016 0x4005 0x028 0 0 -
You didn’t post the entire output.
Please post the output from the line:
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
I ran this command sudo smartctl -t short -a /dev/nvme0n1
and got the following output
Controller ID: 1
NVMe Version: 1.3
Local Time is: Sun Nov 14 23:38:07 2021 +07
0 + 512 0 1
1 - 4096 0 0
Temperature: 45 Celsius
Percentage Used: 5%
Data Units Read: 99 082 865 [50,7 TB]
Data Units Written: 56 126 938 [28,7 TB]
Host Read Commands: 501 171 189
Host Write Commands: 523 456 328
Power Cycles: 990
Oh, run this command:
