LTS 5.4 is running perfectly fine.
I installed 5.10 and rebooted. I can login and everything is working well until I lock the screen.
Then I can’t do anything. The screen remains black, even if I try to open a TTY (e.g. Ctrl+Alt+F3).
Only a hard reset helps and I need to switch back to 5.4.
I couldn’t find any information on this issue, any clue where I can start to investigate?
A good start is to provide some info as described in this post.
How to get your computer to more safely reboot can be found here .
Reboot and hold Shift while rebooting.
When grub appears select advanced options and boot to linux54.
When booted to linux54 remove the undesired kernel(s)
Yes, this is what I did (except pressing shift, grub always show up after reboot).
So there’s no hurry for me to fix it, until I get a problem with 5.4.
Usually an issue with KMS not being ready before the graphics server tries to start, enable early KMS for your kernel driver, i.e. amdgpu for the amd systems, and nvidia and nvidia_drm for the prop nvidia driver(arch forum)
https://wiki.archlinux.org/index.php/Kernel_mode_setting#Early_KMS_start
I added i915 in /etc/mkinitcpio.conf without success.
Here is the output of inxi --admin --verbosity=7 --filter --no-host --width:
Kernel: 5.10.32-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=c36d880b-9bb0-4ac3-9cbf-b6e8a2c5fb55 rw quiet udev.log_priority=3
Desktop: GNOME 3.38.4 tk: GTK 3.24.29 wm: gnome-shell dm: GDM 40.0
Type: Laptop System: AWOW product: AK41 v: N/A serial: <filter>
Mobo: AWOW model: AK41 PC BOX serial: <filter> UEFI: American Megatrends
v: AWOW-BI-MINIPC-M9GR200-GF60A-101-B date: 03/25/2020
Device-1: hidpp_battery_0
model: Logitech Marathon Mouse/Performance Plus M705 serial: <filter>
charge: 10% (should be ignored) rechargeable: yes status: Discharging
RAM: total: 7.59 GiB used: 3.4 GiB (44.8%)
Info: Quad Core model: Intel Celeron J4115 bits: 64 type: MCP
arch: Goldmont Plus family: 6 model-id: 7A (122) stepping: 1 microcode: 34
cache: L2: 4 MiB bogomips: 14284
Speed: 1217 MHz min/max: 800/2500 MHz Core speeds (MHz): 1: 1217 2: 977
3: 874 4: 2219
Flags: 3dnowprefetch acpi aes aperfmperf apic arat arch_capabilities
arch_perfmon art bts cat_l2 cdp_l2 clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est
flexpriority fpu fsgsbase fxsr ht ibpb ibrs ibrs_enhanced ida intel_pt
lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl
nx pae pat pbe pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti
pts rdpid rdrand rdseed rdt_a rdtscp rep_good sdbg sep sha_ni smap smep ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer tsc_known_freq umip vme vmx vnmi vpid x2apic
Device-1: Intel UHD Graphics 605 driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:3185 class-ID: 0300
Display: x11 server: X.org 1.20.11 compositor: gnome-shell driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa
OpenGL: renderer: Mesa Intel UHD Graphics 600 (GLK 2) v: 4.6 Mesa 21.0.3
direct render: Yes
Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus-ID: 00:0e.0 chip-ID: 8086:3198 class-ID: 0403
Sound Server-1: ALSA v: k5.10.32-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.26 running: yes
Device-1: Intel AC 1550i Wireless driver: iwlwifi v: kernel port: f000
bus-ID: 00:0c.0 chip-ID: 8086:31dc class-ID: 0280
IF: wlo2 state: up mac: <filter>
driver: r8169 v: kernel port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168
class-ID: 0200
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-9:5 chip-ID: 8087:0aaa class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: up address: <filter>
Device-1: chome maj-min: 254:0 type: LUKS dm: dm-0 size: 931.51 GiB
Components:
p-1: sda maj-min: 8:0 size: 931.51 GiB
<edited>
<edited>
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 75.05 GiB fs: ntfs label: Windows
uuid: F2E6333AE632FF03
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 800 MiB fs: ntfs label: Recovery
uuid: 6EF43374F4333DA1
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 9 rev: 2.0
Hub-2: 1-3:2 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Device-1: 1-4:3 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Hub-3: 1-7:4 info: NEC HighSpeed Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 0409:0059 class-ID: 0900
Device-1: 1-7.2:6 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-7.3:7 info: HP OfficeJet 3830 series type: Printer driver: usblp
interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 2mA chip-ID: 03f0:e511
class-ID: 0701 serial: <filter>
Device-3: 1-7.4:8 info: Logitech Logicool HID-Compliant Keyboard (106 key)
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s power: 100mA chip-ID: 046d:c30f class-ID: 0300
Device-4: 1-9:5 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-4: 2-0:1 info: Full speed (or root) Hub ports: 7 rev: 3.0 speed: 5 Gb/s
Device-1: 2-3:2 info: Toshiba America External Disk 1.5TB type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 896mA
chip-ID: 0480:a006 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 58.0 C mobo: N/A
Processes: 258 Uptime: 2m wakeups: 2 Init: systemd v: 247 tool: systemctl
Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: 1914 pacman: 1904 lib: 455
flatpak: 5 snap: 5 Shell: Zsh v: 5.8 running-in: tilda inxi: 3.3.04
journalctl --catalog --priority=3 --boot=-1
-- Journal begins at Tue 2020-12-29 21:34:14 CET, ends at Sat 2021-05-01 20:41:07 CEST. --
Mai 01 20:31:23 username-awow kernel: proc: Bad value for 'hidepid'
Mai 01 20:31:23 username-awow bluetoothd[780]: src/adapter.c:reset_adv_monitors_complete() Failed to reset Adv Monitors: Unknown Command (0x01)
Mai 01 20:31:24 username-awow kernel: iwlwifi 0000:00:0c.0: BIOS contains WGDS but no WRDS
Mai 01 20:31:24 username-awow colord-sane[981]: io/hpmud/musb.c 2099: Invalid usb_open: Permission denied
Mai 01 20:31:26 username-awow kernel: proc: Bad value for 'hidepid'
Mai 01 20:31:57 username-awow gdm-password][1573]: gkr-pam: unable to locate daemon control file
Mai 01 20:32:02 username-awow kernel: ata2.00: exception Emask 0x10 SAct 0x80000 SErr 0x440101 action 0x6 frozen
Mai 01 20:32:02 username-awow kernel: ata2.00: irq_stat 0x08000000, interface fatal error
Mai 01 20:32:02 username-awow kernel: ata2: SError: { RecovData UnrecovData CommWake Handshk }
Mai 01 20:32:02 username-awow kernel: ata2.00: failed command: WRITE FPDMA QUEUED
Mai 01 20:32:02 username-awow kernel: ata2.00: cmd 61/10:98:08:10:04/01:00:3a:00:00/40 tag 19 ncq dma 139264 out
res 40/00:98:08:10:04/00:00:3a:00:00/40 Emask 0x10 (ATA bus error)
Mai 01 20:32:02 username-awow kernel: ata2.00: status: { DRDY }
Mai 01 20:32:03 username-awow kernel: ata2.00: exception Emask 0x10 SAct 0x80000000 SErr 0x400100 action 0x6 frozen
Mai 01 20:32:03 username-awow kernel: ata2.00: irq_stat 0x08000000, interface fatal error
Mai 01 20:32:03 username-awow kernel: ata2: SError: { UnrecovData Handshk }
Mai 01 20:32:03 username-awow kernel: ata2.00: failed command: WRITE FPDMA QUEUED
Mai 01 20:32:03 username-awow kernel: ata2.00: cmd 61/10:f8:08:10:04/01:00:3a:00:00/40 tag 31 ncq dma 139264 out
res 40/00:f8:08:10:04/00:00:3a:00:00/40 Emask 0x10 (ATA bus error)
Mai 01 20:32:03 username-awow kernel: ata2.00: status: { DRDY }
Mai 01 20:32:03 username-awow kernel: ata2.00: exception Emask 0x10 SAct 0x1200000 SErr 0x400100 action 0x6 frozen
Mai 01 20:32:03 username-awow kernel: ata2.00: cmd 61/10:a8:08:10:04/01:00:3a:00:00/40 tag 21 ncq dma 139264 out
res 40/00:c0:00:00:00/00:00:00:00:00/40 Emask 0x10 (ATA bus error)
Mai 01 20:32:03 username-awow kernel: ata2.00: failed command: READ FPDMA QUEUED
Mai 01 20:32:03 username-awow kernel: ata2.00: cmd 60/01:c0:00:00:00/00:00:00:00:00/40 tag 24 ncq dma 512 in
Mai 01 20:32:04 username-awow kernel: ata2.00: exception Emask 0x10 SAct 0x300 SErr 0x400100 action 0x6 frozen
Mai 01 20:32:04 username-awow kernel: ata2.00: irq_stat 0x08000000, interface fatal error
Mai 01 20:32:04 username-awow kernel: ata2: SError: { UnrecovData Handshk }
Mai 01 20:32:04 username-awow kernel: ata2.00: failed command: WRITE FPDMA QUEUED
Mai 01 20:32:04 username-awow kernel: ata2.00: cmd 61/10:40:08:10:04/01:00:3a:00:00/40 tag 8 ncq dma 139264 out
res 40/00:48:00:00:00/00:00:00:00:00/40 Emask 0x10 (ATA bus error)
Mai 01 20:32:04 username-awow kernel: ata2.00: status: { DRDY }
Mai 01 20:32:04 username-awow kernel: ata2.00: failed command: READ FPDMA QUEUED
Mai 01 20:32:04 username-awow kernel: ata2.00: cmd 60/01:48:00:00:00/00:00:00:00:00/40 tag 9 ncq dma 512 in
Mai 01 20:32:09 username-awow kernel: proc: Bad value for 'hidepid'
Mai 01 20:32:10 username-awow kernel: proc: Bad value for 'hidepid'
Mai 01 20:34:59 username-awow kernel: proc: Bad value for 'hidepid'
Mai 01 20:36:43 username-awow gdm[837]: Gdm: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
Mai 01 20:36:45 username-awow kernel: watchdog: watchdog0: watchdog did not stop!
Added that inside modules? & Have u regenerated the initramfs?
sudo mkinitcpio -p linux (or linux-lts if u have lts kernel)
I wasn’t sure, so I regenerated the initramfs. Without success.
Note that I got some error messages and had to use sudo mkinitcpio -P.
Computer_Email23:
ERROR: Failed to load preset: `/etc/mkinitcpio.d/linux.preset'
ERROR: Failed to load preset: `/etc/mkinitcpio.d/linux-lts.preset'
This is not exactly the same issue, as it describes the inaccessibility of gdm, while I can always login at first. Additionally, the solution presented there didn’t work in my case.
My problem appears after I lock the screen and the monitor turns off. If I try to unlock during the few seconds before the screen turns off, there is no issue.
I found the same issue on Arch forum . Unfortunately, not fixed yet.
I tested today with Kernek 5.10.49, still happening.
Just tested with Kernel 5.15, still not fixed…
