Linux 5.19: Display refresh rate is very low (about 0.25 fps)
Summary
When booting with a Linux 5.19 kernel, my computer’s built-in display seems to have an extremely low refresh rate. The display refreshes faster if I’m actively typing (e.g. typing into Konsole or pressing the arrow keys), but not if I’m moving the mouse or pressing and holding a key. The display refreshes faster in a TTY, but I still notice some delay when opening an application like vim or moving the cursor.
After about two minutes of using the desktop, the screen shows what looks like static. After a few more seconds, the screen goes black except for a few pixels at the top of the screen:
tmp
When this happens, TTYs work as expected — I can press ctrl+alt+F5 and my screen displays the contents of the TTY.
Reason for attempting to update
After a recent update, I found myself needing to restart the wireplumber service frequently to get audio to work. I’m running Linux 5.15 and the suggested solution was to update to Linux 6.x. I first discovered the above issue with the 6.0-based kernel.
System Information
Working kernel:
$ ixni
CPU: 12-core (4-mt/8-st) 12th Gen Intel Core i7-1260P (-MST AMCP-)
speed/min/max: 630/400/4700:3400 MHz Kernel: 5.15.81-1-MANJARO x86_64 Up: 4m
Mem: 3373.4/15722.1 MiB (21.5%) Storage: 953.87 GiB (11.4% used) Procs: 335
Shell: Zsh inxi: 3.3.24
Non-working kernel:
$ inxi
speed/min/max: 2404/400/4700:3400 MHz Kernel: 5.19.17-2-MANJARO x86_64 Up: 4m Mem: 3696.2/15721.8
MiB (23.5%) Storage: 953.87 GiB (11.5% used) Procs: 360 Shell: Zsh inxi: 3.3.24
Desktop environment: KDE Plasma (Wayland)
Bootloader: GNU Grub (dual-booting Windows and Manjaro)
Working kernel version: 5.15.81-1 (Installed through the “Kernel” tab in system settings)
First non-working kernel version of the kernels available in settings: 5.19.17-2
I attempted to run Ubuntu 22.10 on the computer which, I think, uses a 5.18-based kernel. I experienced the same issue.
provide full system info:
inxi -Faz
and kernel 5.19 is end of life, which means its no longer supported, so dont use it and remove it…
you are on wayland, so try with xorg
as @brahma said, no information → no answer. without basic information everything is digging in the dark!
please provide the output of
that’s better than inxi -Faz and please use the option of the preformatted text to paste the output inside there.
More-detailed system information:
5.15.81 kernel (working)
  Kernel: 5.15.81-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    root=UUID=3494edc0-335a-4910-ba00-317adbad0c05 rw quiet
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_wayland vt: 2
  Type: Laptop System: LENOVO product: 82SX v: Lenovo Slim 7 14IAP7
    serial: <superuser required> Chassis: type: 10 v: Lenovo Slim 7 14IAP7
  Mobo: LENOVO model: LNVNB161216 v: SDK0T76463 WIN
    serial: <superuser required> UEFI: LENOVO v: JHCN21WW date: 05/16/2022
  ID-1: BAT0 charge: 60.8 Wh (100.0%) condition: 60.8/61.0 Wh (99.6%)
    volts: 17.6 min: 15.4 model: Sunwoda L19D4PH3 type: Li-poly serial: <filter>
    status: full cycles: 26
  RAM: total: 15.35 GiB used: 2.85 GiB (18.6%)
  Info: model: 12th Gen Intel Core i7-1260P bits: 64 type: MST AMCP
    arch: Alder Lake level: v3 note: check built: 2021+
    process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
    microcode: 0x424
  Topology: cpus: 1x cores: 12 mt: 4 tpc: 2 st: 8 threads: 16 smt: enabled
    cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32 KiB, 8x64 KiB L2: 9 MiB
    desc: 4x1.2 MiB, 2x2 MiB L3: 18 MiB desc: 1x18 MiB
  Speed (MHz): avg: 760 high: 1140 min/max: 400/4700:3400 scaling:
    driver: intel_pstate governor: powersave cores: 1: 866 2: 828 3: 1140 4: 808
    5: 691 6: 615 7: 1033 8: 663 9: 400 10: 858 11: 721 12: 668 13: 680 14: 650
    15: 763 16: 785 bogomips: 79888
    bts cat_l2 cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid
    f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
    hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
    intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
    movbe movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe
    pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
    rdpid rdrand rdseed rdt_a rdtscp rep_good sdbg sep serialize sha_ni smap
    smep smx split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq
    umip vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec
    xsaveopt xsaves xtopology xtpr
    prctl and seccomp
  Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
  Device-1: Intel Alder Lake-P Integrated Graphics vendor: Lenovo driver: i915
    v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports:
    active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 00:02.0
    chip-ID: 8086:46a6 class-ID: 0300
  Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
    bus-ID: 3-8:2 chip-ID: 04f2:b756 class-ID: fe01 serial: <filter>
  Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.5
    compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: 0
  Monitor-1: eDP-1 res: 1646x1029 size: N/A modes: N/A
  API: OpenGL v: 4.6 Mesa 22.2.4 renderer: Mesa Intel Graphics (ADL GT2)
    direct render: Yes
  Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Lenovo
    driver: sof-audio-pci-intel-tgl
    alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
    chip-ID: 8086:51c8 class-ID: 0401
  Sound API: ALSA v: k5.15.81-1-MANJARO running: yes
  Sound Server-1: PulseAudio v: 16.1 running: no
  Sound Server-2: PipeWire v: 0.3.61 running: yes
  Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
  Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 3-10:3
    chip-ID: 8087:0033 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
  Local Storage: total: 953.87 GiB used: 110.17 GiB (11.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVL21T0HCLR-00BL2
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 type: SSD serial: <filter> rev: CL1QGXA7 temp: 29.9 C scheme: GPT
  ID-1: / raw-size: 642.32 GiB size: 631.17 GiB (98.26%)
    used: 110.13 GiB (17.4%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
    label: N/A uuid: 3494edc0-335a-4910-ba00-317adbad0c05
  ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
    used: 41.3 MiB (16.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: SYSTEM_DRV uuid: B8E0-8A4F
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 309.33 GiB fs: ntfs
    label: Windows-SSD uuid: 10D8E13AD8E11F2A
  ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 1.95 GiB fs: ntfs
    label: WINRE_DRV uuid: 6AB2E1E0B2E1B0AD
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-2: 2-0:1 info: Super-speed hub ports: 3 rev: 3.1 speed: 20 Gb/s
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-8:2 info: Chicony Integrated Camera type: Video
    driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s power: 500mA
  Device-2: 3-10:3 info: Intel type: Bluetooth driver: btusb interfaces: 2
    rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0033 class-ID: e001
  Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 34.0 C mobo: N/A
  Processes: 347 Uptime: 2m wakeups: 307 Init: systemd v: 251
  default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
  Packages: 1471 pm: pacman pkgs: 1460 libs: 384 tools: pamac pm: flatpak
  pkgs: 0 pm: snap pkgs: 11 Shell: Zsh v: 5.9 running-in: yakuake inxi: 3.3.24
6.0.11-1 kernel/Wayland (not working)
$ inxi --admin --verbosity=7 --filter --no-host --width
  Kernel: 6.0.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.0-x86_64
    udev.log_priority=3
  ID-1: BAT0 charge: 43.5 Wh (71.5%) condition: 60.8/61.0 Wh (99.6%)
    volts: 17.1 min: 15.4 model: Sunwoda L19D4PH3 type: Li-poly serial: <filter>
    status: charging cycles: 25
  RAM: total: 15.35 GiB used: 3.03 GiB (19.7%)
    microcode: 0x424
  Speed (MHz): avg: 2287 high: 2500 min/max: 400/4700:3400 scaling:
    driver: intel_pstate governor: powersave cores: 1: 2500 2: 2500 3: 2500
    4: 2500 5: 875 6: 2500 7: 730 8: 2500 9: 2500 10: 2500 11: 2500 12: 2500
    13: 2500 14: 2500 15: 2500 16: 2500 bogomips: 79888
    f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni hfi ht hwp
    hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt
    ida intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx
    monitor movbe movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat
    pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
  Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
    filling, PBRSB-eIBRS: SW sequence
    direct render: Yes
  Sound API: ALSA v: k6.0.11-1-MANJARO running: yes
  Local Storage: total: 953.87 GiB used: 110.15 GiB (11.5%)
    lanes: 4 type: SSD serial: <filter> rev: CL1QGXA7 temp: 26.9 C scheme: GPT
    used: 110.11 GiB (17.4%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
  System Temperatures: cpu: 38.0 C mobo: N/A
  Processes: 324 Uptime: 2m wakeups: 141 Init: systemd v: 251
6.0.11-1 kernel/X11 (not working)
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
  ID-1: BAT0 charge: 45.6 Wh (75.0%) condition: 60.8/61.0 Wh (99.6%)
    volts: 17.4 min: 15.4 model: Sunwoda L19D4PH3 type: Li-poly serial: <filter>
  RAM: total: 15.35 GiB used: 2.06 GiB (13.4%)
    microcode: 0x424
  Speed (MHz): avg: 2114 high: 2500 min/max: 400/4700:3400 scaling:
    driver: intel_pstate governor: powersave cores: 1: 456 2: 2500 3: 653 4: 2500
    5: 2500 6: 2500 7: 400 8: 2500 9: 2327 10: 2500 11: 2500 12: 2500 13: 2500
  Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.5
    compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2880x1800 s-dpi: 192 s-size: 381x238mm (15.00x9.37")
    s-diag: 449mm (17.69")
  Monitor-1: eDP-1 model-id: CSO 0x140c built: 2021 res: 2880x1800 hz: 90
    dpi: 242 gamma: 1.2 size: 302x188mm (11.89x7.4") diag: 356mm (14")
    ratio: 16:10 modes: 2880x1800
    direct render: Yes
    lanes: 4 type: SSD serial: <filter> rev: CL1QGXA7 temp: 27.9 C scheme: GPT
  Processes: 310 Uptime: 5m wakeups: 571 Init: systemd v: 251
6.1.0-1 kernel/X11 (not working)
  Kernel: 6.1.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    udev.log_priority=3
  ID-1: BAT0 charge: 46.3 Wh (76.2%) condition: 60.8/61.0 Wh (99.6%)
  RAM: total: 15.35 GiB used: 2.84 GiB (18.5%)
    microcode: 0x424
  Speed (MHz): avg: 2500 min/max: 400/4700:3400 scaling: driver: intel_pstate
    governor: powersave cores: 1: 2500 2: 2500 3: 2500 4: 2500 5: 2500 6: 2500
    7: 2500 8: 2500 9: 2500 10: 2500 11: 2500 12: 2500 13: 2500 14: 2500
    direct render: Yes
  Sound API: ALSA v: k6.1.0-1-MANJARO running: yes
  IF: wlp0s20f3 state: down mac: <filter>
  WAN IP: No WAN IP found. Connected to web? SSL issues?
    lanes: 4 type: SSD serial: <filter> rev: CL1QGXA7 temp: 30.9 C scheme: GPT
  System Temperatures: cpu: 33.0 C mobo: N/A
  Processes: 318 Uptime: 0m wakeups: 61 Init: systemd v: 251 default: graphical
  tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1471
  pm: pacman pkgs: 1460 libs: 384 tools: pamac pm: flatpak pkgs: 0 pm: snap
Additional information:
I’m experiencing the same symptoms with the 6.1.0-1 and 6.0.11 kernels with and without X11 — the contents of the screen update every second or so when moving my mouse and update faster when I’m typing. I’m also noticing the issue on the SDDM login screen.
An external monitor connected to the computer seems to have a much higher refresh rate (I’m not noticing the issue with the external monitor).
The issue seems to be mostly the same on X11 — the display seems to have a low refresh rate and updates faster if I’m typing. When the X11 session first starts, however, I see what looks like static/noise for a few seconds.
Thank you for helping me!
try adding the following parameter by opening this file:
kate /etc/default/grub
and in this line: GRUB_CMDLINE_LINUX_DEFAULT inside the quotes add this parameter:
i915.enable_psr=0
dont remove anything from there!, just add it to existing parameters, save the file, update grub:
sudo update-grub
reboot and test
if you still have the issue, post logs:
journalctl -b0 -p4 --no-pager
I’m still experiencing the issue with i915.enable_psr=0 appended to GRUB_CMDLINE_LINUX_DEFAULT.
Logs
Booting with the 6.1.0-1 kernel (X11):
$ journalctl -b0 -p4 --no-pager
Dec 19 00:15:10 Saturn kernel: [Firmware Bug]: TSC ADJUST: CPU0: -2444760745 force to 0
Dec 19 00:15:10 Saturn kernel: [Firmware Bug]: TSC ADJUST differs within socket(s), fixing all errors
Dec 19 00:15:10 Saturn kernel:   #2  #3  #4  #5  #6  #7  #8
Dec 19 00:15:10 Saturn kernel:   #9 #10 #11 #12 #13 #14 #15
Dec 19 00:15:10 Saturn kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Dec 19 00:15:10 Saturn kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.TXHC.RHUB.SS01._UPC], AE_ALREADY_EXISTS (20220331/dswload2-326)
Dec 19 00:15:10 Saturn kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20220331/psobject-220)
Dec 19 00:15:10 Saturn kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.TXHC.RHUB.SS01._PLD], AE_ALREADY_EXISTS (20220331/dswload2-326)
Dec 19 00:15:10 Saturn kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.TXHC.RHUB.SS02._UPC], AE_ALREADY_EXISTS (20220331/dswload2-326)
Dec 19 00:15:10 Saturn kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.TXHC.RHUB.SS03._UPC], AE_ALREADY_EXISTS (20220331/dswload2-326)
Dec 19 00:15:10 Saturn kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.TXHC.RHUB.SS03._PLD], AE_ALREADY_EXISTS (20220331/dswload2-326)
Dec 19 00:15:10 Saturn kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.TXHC.RHUB.SS04._UPC], AE_ALREADY_EXISTS (20220331/dswload2-326)
Dec 19 00:15:10 Saturn kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS01._UPC], AE_ALREADY_EXISTS (20220331/dswload2-326)
Dec 19 00:15:10 Saturn kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS02._UPC], AE_ALREADY_EXISTS (20220331/dswload2-326)
Dec 19 00:15:10 Saturn kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS02._PLD], AE_ALREADY_EXISTS (20220331/dswload2-326)
Dec 19 00:15:10 Saturn kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS03._UPC], AE_ALREADY_EXISTS (20220331/dswload2-326)
Dec 19 00:15:10 Saturn kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS03._PLD], AE_ALREADY_EXISTS (20220331/dswload2-326)
Dec 19 00:15:10 Saturn kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS04._UPC], AE_ALREADY_EXISTS (20220331/dswload2-326)
Dec 19 00:15:10 Saturn kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS05._UPC], AE_ALREADY_EXISTS (20220331/dswload2-326)
Dec 19 00:15:10 Saturn kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS06._UPC], AE_ALREADY_EXISTS (20220331/dswload2-326)
Dec 19 00:15:10 Saturn kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS07._UPC], AE_ALREADY_EXISTS (20220331/dswload2-326)
Dec 19 00:15:10 Saturn kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS08._UPC], AE_ALREADY_EXISTS (20220331/dswload2-326)
Dec 19 00:15:10 Saturn kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS08._PLD], AE_ALREADY_EXISTS (20220331/dswload2-326)
Dec 19 00:15:10 Saturn kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS09._UPC], AE_ALREADY_EXISTS (20220331/dswload2-326)
Dec 19 00:15:10 Saturn kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS09._PLD], AE_ALREADY_EXISTS (20220331/dswload2-326)
Dec 19 00:15:10 Saturn kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS10._UPC], AE_ALREADY_EXISTS (20220331/dswload2-326)
Dec 19 00:15:10 Saturn kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS10._PLD], AE_ALREADY_EXISTS (20220331/dswload2-326)
Dec 19 00:15:10 Saturn kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS01._UPC], AE_ALREADY_EXISTS (20220331/dswload2-326)
Dec 19 00:15:10 Saturn kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS01._PLD], AE_ALREADY_EXISTS (20220331/dswload2-326)
Dec 19 00:15:10 Saturn kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS02._UPC], AE_ALREADY_EXISTS (20220331/dswload2-326)
Dec 19 00:15:10 Saturn kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS03._UPC], AE_ALREADY_EXISTS (20220331/dswload2-326)
Dec 19 00:15:10 Saturn kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS04._UPC], AE_ALREADY_EXISTS (20220331/dswload2-326)
Dec 19 00:15:10 Saturn kernel: pnp 00:03: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
Dec 19 00:15:10 Saturn kernel: hpet_acpi_add: no address or irqs in _CRS
Dec 19 00:15:10 Saturn kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
Dec 19 00:15:10 Saturn kernel: vboxdrv: loading out-of-tree module taints kernel.
Dec 19 00:15:10 Saturn kernel: VBoxNetAdp: Successfully started.
Dec 19 00:15:10 Saturn kernel: VBoxNetFlt: Successfully started.
Dec 19 00:15:12 Saturn kernel: resource sanity check: requesting [mem 0xfedc0000-0xfedcffff], which spans more than pnp 00:03 [mem 0xfedc0000-0xfedc7fff]
Dec 19 00:15:12 Saturn kernel: caller igen6_probe+0x19d/0x7e0 [igen6_edac] mapping multiple BARs
Dec 19 00:15:12 Saturn kernel: iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
Dec 19 00:15:13 Saturn kernel: i2c_hid_acpi i2c-ELAN901C:00: i2c_hid_get_input: IRQ triggered but there's no data
Dec 19 00:15:13 Saturn kernel: i2c i2c-11: Systems with more than 4 memory slots not supported yet, not instantiating SPD
Dec 19 00:15:13 Saturn kernel: mtd: partition "BIOS" extends beyond the end of device "0000:00:1f.5" -- size truncated to 0x800000
Dec 19 00:15:13 Saturn kernel: thermal thermal_zone8: failed to read out thermal zone (-61)
Dec 19 00:15:17 Saturn kernel: kauditd_printk_skb: 26 callbacks suppressed
Dec 19 00:15:17 Saturn kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: Parent card not yet available, widget card binding deferred
Dec 19 00:15:17 Saturn kernel: snd_hda_codec_realtek ehdaudio0D0: ASoC: sink widget AIF1TX overwritten
Dec 19 00:15:17 Saturn kernel: snd_hda_codec_realtek ehdaudio0D0: ASoC: source widget AIF1RX overwritten
Dec 19 00:15:17 Saturn kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi3 overwritten
Dec 19 00:15:17 Saturn kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi2 overwritten
Dec 19 00:15:17 Saturn kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi1 overwritten
Dec 19 00:15:17 Saturn kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Codec Output Pin1 overwritten
Dec 19 00:15:17 Saturn kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Codec Input Pin1 overwritten
Dec 19 00:15:17 Saturn kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Analog Codec Playback overwritten
Dec 19 00:15:17 Saturn kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Digital Codec Playback overwritten
Dec 19 00:15:17 Saturn kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Alt Analog Codec Playback overwritten
Dec 19 00:15:17 Saturn kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Analog Codec Capture overwritten
Dec 19 00:15:17 Saturn kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Digital Codec Capture overwritten
Dec 19 00:15:17 Saturn kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Alt Analog Codec Capture overwritten
Dec 19 00:15:17 Saturn kernel: skl_hda_dsp_generic skl_hda_dsp_generic: hda_dsp_hdmi_build_controls: no PCM in topology for HDMI converter 3
Dec 19 00:15:17 Saturn systemd[941]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Dec 19 00:15:17 Saturn bluetoothd[941]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
Dec 19 00:15:17 Saturn bluetoothd[941]: src/plugin.c:plugin_init() Failed to init vcp plugin
Dec 19 00:15:17 Saturn bluetoothd[941]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
Dec 19 00:15:17 Saturn bluetoothd[941]: src/plugin.c:plugin_init() Failed to init mcp plugin
Dec 19 00:15:17 Saturn bluetoothd[941]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
Dec 19 00:15:17 Saturn bluetoothd[941]: src/plugin.c:plugin_init() Failed to init bap plugin
Dec 19 00:15:19 Saturn sddm-greeter[957]: QObject: Cannot create children for a parent that is in a different thread.
                                          (Parent is QGuiApplication(0x7fffc9234ef0), parent's thread is QThread(0x558389ce1620), current thread is QThread(0x558389e3c2d0)
Dec 19 00:15:19 Saturn sddm-greeter[957]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Dec 19 00:15:19 Saturn kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
Dec 19 00:15:19 Saturn kernel: Bluetooth: hci0: HCI_REQ-0xfc1e
Dec 19 00:15:19 Saturn bluetoothd[941]: Failed to set mode: Failed (0x03)
Dec 19 00:15:19 Saturn sddm-greeter[957]: Failed to find a Kirigami platform plugin
Dec 19 00:15:19 Saturn sddm-greeter[957]: file:///usr/share/sddm/themes/breeze/components/VirtualKeyboard.qml:12:1: Type InputPanel unavailable
Dec 19 00:15:19 Saturn sddm-greeter[957]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
Dec 19 00:15:19 Saturn sddm-greeter[957]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Dec 19 00:15:19 Saturn sddm-greeter[957]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.19'
Dec 19 00:15:37 Saturn kernel: kauditd_printk_skb: 10 callbacks suppressed
Dec 19 00:15:37 Saturn pipewire[1027]: mod.rt: Can't find xdg-portal: (null)
Dec 19 00:15:37 Saturn pipewire[1027]: mod.rt: found session bus but no portal
Dec 19 00:15:37 Saturn wireplumber[1028]: Failed to set scheduler settings: Operation not permitted
Dec 19 00:15:37 Saturn ksplashqml[1062]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
Dec 19 00:15:37 Saturn ksplashqml[1062]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:81:29: Unable to assign int to QEasingCurve
Dec 19 00:15:38 Saturn ksmserver[1130]: Qt: Session management error: networkIdsList argument is NULL
Dec 19 00:15:38 Saturn kwin_x11[1133]: kwin_xkbcommon: XKB: /home/username/.XCompose:6:31: a sequence already exists which is a prefix of this sequence; overriding
Dec 19 00:15:38 Saturn kwin_x11[1133]: kwin_xkbcommon: XKB: /home/username/.XCompose:20:31: a sequence already exists which is a prefix of this sequence; overriding
Dec 19 00:15:38 Saturn kwin_x11[1133]: kwin_xkbcommon: XKB: /home/username/.XCompose:24:31: this compose sequence already exists; overriding
Dec 19 00:15:38 Saturn kwin_x11[1133]: kwin_xkbcommon: XKB: /home/username/.XCompose:25:33: this compose sequence already exists; overriding
Dec 19 00:15:38 Saturn kwin_x11[1133]: kwin_xkbcommon: XKB: /home/username/.XCompose:35:31: a sequence already exists which is a prefix of this sequence; overriding
Dec 19 00:15:38 Saturn kwin_x11[1133]: kwin_xkbcommon: XKB: /home/username/.XCompose:58:33: this compose sequence is a prefix of another; skipping line
Dec 19 00:15:38 Saturn kwin_x11[1133]: kwin_xkbcommon: XKB: /home/username/.XCompose:59:33: this compose sequence is a prefix of another; skipping line
Dec 19 00:15:38 Saturn kwin_x11[1133]: kwin_xkbcommon: XKB: /home/username/.XCompose:61:33: this compose sequence is a prefix of another; skipping line
Dec 19 00:15:38 Saturn kwin_x11[1133]: kwin_xkbcommon: XKB: /home/username/.XCompose:94:37: this compose sequence already exists; overriding
Dec 19 00:15:38 Saturn kwin_x11[1133]: kwin_xkbcommon: XKB: /home/username/.XCompose:95:37: this compose sequence already exists; overriding
Dec 19 00:15:38 Saturn kwin_x11[1133]: kwin_xkbcommon: XKB: /home/username/.XCompose:98:37: this compose sequence already exists; overriding
Dec 19 00:15:38 Saturn kwin_x11[1133]: kwin_xkbcommon: XKB: /home/username/.XCompose:100:37: this compose sequence already exists; overriding
Dec 19 00:15:38 Saturn kwin_x11[1133]: kwin_xkbcommon: XKB: /home/username/.XCompose:101:37: this compose sequence already exists; overriding
Dec 19 00:15:38 Saturn kwin_x11[1133]: kwin_xkbcommon: XKB: /home/username/.XCompose:104:35: this compose sequence already exists; overriding
Dec 19 00:15:38 Saturn kwin_x11[1133]: kwin_xkbcommon: XKB: /home/username/.XCompose:105:35: this compose sequence already exists; overriding
Dec 19 00:15:38 Saturn kwin_x11[1133]: kwin_xkbcommon: XKB: /home/username/.XCompose:120:35: this compose sequence already exists; overriding
Dec 19 00:15:38 Saturn kwin_x11[1133]: kwin_xkbcommon: XKB: /home/username/.XCompose:121:35: this compose sequence already exists; overriding
Dec 19 00:15:38 Saturn kwin_x11[1133]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Dec 19 00:15:38 Saturn kwin_x11[1133]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Dec 19 00:15:38 Saturn ksmserver[1130]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.18'
Dec 19 00:15:38 Saturn plasmashell[1228]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Dec 19 00:15:38 Saturn plasmashell[1228]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Dec 19 00:15:38 Saturn org_kde_powerdevil[1287]: QDBusConnection: name 'org.kde.ActivityManager' had owner '' but we thought it was ':1.22'
Dec 19 00:15:38 Saturn org_kde_powerdevil[1287]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Dec 19 00:15:38 Saturn org_kde_powerdevil[1287]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Dec 19 00:15:38 Saturn plasmashell[1228]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Dec 19 00:15:38 Saturn plasmashell[1228]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml: QML Containment (parent or ancestor of Wallpaper): grabToImage: item's window is not visible
Dec 19 00:15:38 Saturn plasmashell[1228]: libpng warning: iCCP: known incorrect sRGB profile
Dec 19 00:15:39 Saturn plasmashell[1228]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:534:9: QML Label: Binding loop detected for property "height"
Dec 19 00:15:39 Saturn plasmashell[1228]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:499:13: QML Label: Binding loop detected for property "height"
Dec 19 00:15:39 Saturn DiscoverNotifier[1418]: packagekitqt.transaction: Unknown Transaction property: "Sender" QVariant(QString, ":1.53")
Dec 19 00:15:39 Saturn plasmashell[1228]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
Dec 19 00:15:39 Saturn plasmashell[1228]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:556:5: QML Label: Binding loop detected for property "height"
Dec 19 00:15:39 Saturn plasmashell[1228]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Dec 19 00:15:39 Saturn plasmashell[1228]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
Dec 19 00:15:39 Saturn plasmashell[1228]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Dec 19 00:15:39 Saturn plasmashell[1228]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Dec 19 00:15:40 Saturn plasmashell[1228]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Dec 19 00:15:40 Saturn bluetoothd[941]: Failed to set mode: Failed (0x03)
Dec 19 00:15:40 Saturn kded5[1132]: kf.bluezqt: PendingCall Error: "Failed"
Dec 19 00:15:40 Saturn plasmashell[1228]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Dec 19 00:15:41 Saturn plasmashell[1228]: file:///usr/share/plasma/plasmoids/org.kde.plasma.printmanager/contents/ui/PrinterItem.qml:23:32: QML Action: Accessible must be attached to an Item
Dec 19 00:15:41 Saturn plasmashell[1228]: file:///usr/share/plasma/plasmoids/org.kde.plasma.printmanager/contents/ui/PrinterItem.qml:22:5: Unable to assign [undefined] to bool
Dec 19 00:15:41 Saturn plasmashell[1228]: file:///usr/lib/qt/qml/org/kde/plasma/workspace/calendar/InfiniteList.qml:43:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Dec 19 00:15:41 Saturn plasmashell[1228]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Dec 19 00:15:41 Saturn plasmashell[1228]: file:///usr/lib/qt/qml/org/kde/plasma/workspace/calendar/MonthView.qml:381: TypeError: Cannot read property 'cellHeight' of null
Dec 19 00:15:42 Saturn plasmashell[1228]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Dec 19 00:15:43 Saturn plasmashell[1228]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Dec 19 00:15:44 Saturn kernel: kauditd_printk_skb: 14 callbacks suppressed
Dec 19 00:15:44 Saturn plasmashell[1228]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Dec 19 00:15:49 Saturn plasmashell[1228]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Dec 19 00:15:56 Saturn plasmashell[1228]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ExpandedRepresentation.qml:162: TypeError: Cannot read property 'text' of null
Dec 19 00:15:56 Saturn plasmashell[1228]: trying to show an empty dialog
Dec 19 00:15:56 Saturn plasmashell[1228]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Dec 19 00:16:04 Saturn plasmashell[1228]: file:///usr/share/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/ConnectionItem.qml:45:32: QML Action: Accessible must be attached to an Item
Dec 19 00:16:04 Saturn plasmashell[1228]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55bbc26e8700) QQmlContext(0x55bbc1fab280) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Dec 19 00:16:04 Saturn plasmashell[1228]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Dec 19 00:16:04 Saturn plasmashell[1228]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Dec 19 00:16:04 Saturn DiscoverNotifier[1418]: packagekitqt.offline: Cannot process "org.freedesktop.PackageKit" as "org.freedesktop.PackageKit.Offline"
Dec 19 00:16:05 Saturn DiscoverNotifier[1418]: packagekitqt.transaction: Unknown Transaction property: "Sender" QVariant(QString, ":1.53")
Dec 19 00:16:07 Saturn plasmashell[1228]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Dec 19 00:16:08 Saturn krunner[2000]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Dec 19 00:16:08 Saturn krunner[2000]: file:///usr/lib/qt/qml/org/kde/plasma/components.3/ToolTip.qml:57:9: QML Label: Binding loop detected for property "verticalAlignment"
Dec 19 00:16:08 Saturn xdg-desktop-portal-kde[1288]: xdp-kde-settings: Namespace  "org.gnome.desktop.a11y.interface"  is not supported
Dec 19 00:16:08 Saturn kgx[2063]: Using GtkSettings:gtk-application-prefer-dark-theme with libadwaita is unsupported. Please use AdwStyleManager:color-scheme instead.
Dec 19 00:16:08 Saturn xdg-desktop-por[1097]: A backend call failed: No such method 'CreateMonitor' in interface 'org.freedesktop.impl.portal.Inhibit' at object path '/org/freedesktop/portal/desktop' (signature 'ooss')
Dec 19 00:16:08 Saturn xdg-desktop-por[1097]: Failed to close session implementation: GDBus.Error:org.freedesktop.DBus.Error.UnknownObject: No such object path '/org/freedesktop/portal/desktop/session/1_69/gtk805978344'
Dec 19 00:16:09 Saturn kwin_x11[1133]: kwin_core: XCB error: 152 (BadDamage), sequence: 12834, resource id: 16777668, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Dec 19 00:16:16 Saturn kwin_x11[1133]: kwin_core: XCB error: 152 (BadDamage), sequence: 14503, resource id: 16778149, major code: 143 (DAMAGE), minor code: 3 (Subtract)
this seems like a hardware malfunction. check all connections by unplugging RAM, GPU and plug it in again. before plug in check if there is dirt or dust inside. a thermal issue is also possible and it’s possible that the hardware is already broken.
you already stated that using different operating systems cause the same issue. this is a strong indication that it isn’t software related.
See: Intel graphics - ArchWiki if it helps.
Create and edit /etc/modprobe.d/i915.conf to add the option options i915 enable_guc=3
Do not forget to run sudo mkinitcpio -P
Try to do X11 configuration
It seems to work fine with Windows 11 and Linux 5.15. I’m hesitant to open up my laptop and remove components, but I might try that if nothing else works.
I’ve tried setting options i915 enable_guc=3 (and confirmed that it was set via dmesg). I’m still experiencing the issue.
I’ll try configuring Xorg.
Edit (configuring Xorg): I tried setting AccelMethod to uxa and blt (after removing options i915 enable_guc=3). With uxa, startx fails. I experience the same error with blt as with no AccelMethod set.
Note that, while less severe, I am also experiencing display refresh issues while using a TTY — when I press and hold a key, the display only updates briefly after I first push the key down, then again when I lift the key.
You didn’t tell us this ! You told using a different OS (ubuntu) causes the same issues.
If your’e not precise and lead us to wrong conclusions this thread will last forever.
that parameter should helped, at least according to archwiki for your lenovo slim 7…
post output from:
head /etc/default/grub
Sorry! I’ll try to be more precise! Again, thank you so much for the help!
Here’s what I think my options are:
  1. This might be a bug in the kernel – it happens in two different distros with similar kernel versions. If so, I could try doing a git bisect and reporting the issue to kernel maintainers. (However, I would like to avoid custom-building a kernel, if possible).
  2. Try adjusting driver options further — I’ve only briefly looked at the (linked above) intel graphics section of the Arch wiki. This might be helpful if default options for some of the drivers changed between versions of the kernel.
I think I’ll continue with option 2 because I am not looking forward to doing a git bisect.
Is there anything else I should try?
Thank you for the help so far!
Could you post a link to the Archwiki for my computer, please? I’m seeing wikis for similar computers (e.g. the Lenovo Yoga Slim 7 (AMD)), but not the exact same model.
$ head /etc/default/grub
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet udev.log_priority=3"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
I removed i915.enable_psr=0 before setting enable_guc=3. I’ll re-try with both i915.enable_psr=0 and enable_guc=3 and post the results. Edit: I’m experiencing the issue when both changes are made (both at the same time).
wanted to check if the psr=0 parameter was properly set…
there is no specific archwiki entry for your machine because the only know issue is what you have, and is fixed with the psr parameter:
https://wiki.archlinux.org/title/Laptop/Lenovo
scroll down and there you find it:
To verify, this is how I’m setting enable_psr=0:
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_CMDLINE_LINUX_DEFAULT="quiet udev.log_priority=3 i915.enable_psr=0"
looks good, so add these 3 parameters:
intel_idle.max_cstate=1 i915.enable_dc=0 ahci.mobile_lpm_policy=1
save grub, update it, reboot and test…
dont remove the psr parameter yet
On Alder Lake it seems to be recommend using modesetting driver instead of the i915 directly.
File: /etc/X11/xorg.conf.d/20-intel.conf
Section "Device"
  Identifier "Intel Graphics"
  Driver "modesetting"
  BusID  "PCI:0:2:0" #bus-ID: 00:02.0
EndSection
Otherwise try step by step disabling some features, for example:
i915.enable_dc=0
i915.enable_fpc=0
i915.enable_psr=0
i915.enable_ips=0
Then you should know which function is causing that behavior.
More information… type modinfo 915 in a terminal.
It works!!! Thank you very much!
I would like power management, so I’m going to try removing those options one by one.
What exactly? Was it a problem with the cpu cstates? Now it is locked to C0/1 …
