ikiki
20 February 2024 07:53
1
hello again,
so i was using my internet just as usual and then suddenly my wifi got disconnected and connected again and started showing limited connectivity issue since then and i still haven’t found any solution yet
and also when i checked the /etc/NetworkManager/conf.d/20-connectivity.conf then i found that there was no 20-connectivity.conf file
ikiki
20 February 2024 07:59
2
Kernel: 6.7.0-0-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.7-x86_64
root=UUID=79b15d75-4d5b-4c66-b539-7b3f139ae945 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 info: frameworks
v: 5.113.0 wm: kwin_x11 with: krunner vt: 2 dm: SDDM Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: HP product: HP Pavilion Laptop 13-an0xxx
v: Type1ProductConfigId serial: Chassis: type: 10
serial:
Mobo: HP model: 84C5 v: 15.32 serial:
part-nu: 5SE72PA#ACJ uuid: UEFI: Insyde v: F.09
date: 11/26/2019
ID-1: BAT0 charge: 20.2 Wh (100.0%) condition: 20.2/20.2 Wh (100.0%)
volts: 8.5 min: 7.6 model: HP Primary type: Li-ion serial: N/A status: full
Info: model: Intel Core i5-8265U bits: 64 type: MT MCP arch: Whiskey Lake
gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x8E (142) stepping: 0xB (11) microcode: 0xF4
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 400 min/max: 400/3900 scaling: driver: intel_pstate
governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
8: 400 bogomips: 28808
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Hewlett-Packard
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:3ea0
class-ID: 0300
Device-2: Chicony HP Wide Vision HD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 04f2:b627
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.10 with: Xwayland v: 23.2.3
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: BOE Display 0x07a7 built: 2018 res: 1920x1080
hz: 60 dpi: 166 gamma: 1.2 size: 294x165mm (11.57x6.5") diag: 337mm (13.3")
ratio: 16:9 modes: 1920x1080
device: 1 drv: swrast surfaceless: drv: iris x11: drv: iris
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.3.3-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 620 (WHL GT2)
device-ID: 8086:3ea0 memory: 7.47 GiB unified: yes
API: Vulkan v: 1.3.274 layers: N/A device: 0 type: integrated-gpu
name: Intel UHD Graphics 620 (WHL GT2) driver: mesa intel
v: 23.3.3-manjaro1.1 device-ID: 8086:3ea0 surfaces: xcb,xlib
Device-1: Intel Cannon Point-LP High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0403
API: ALSA v: k6.7.0-0-MANJARO status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:9df0 class-ID: 0280
IF: wlo1 state: up mac:
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:4
Local Storage: total: 238.47 GiB used: 19.15 GiB (8.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: N/A
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 tech: SSD serial: fw-rev: ADHA0101 temp: 37.9 C
scheme: GPT
ID-1: / raw-size: 78.12 GiB size: 76.35 GiB (97.73%) used: 19.07 GiB (25.0%)
fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 81.7 MiB (31.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 51.0 C pch: 44.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 8 GiB available: 7.65 GiB used: 1.83 GiB (23.9%)
Processes: 224 Power: uptime: 2m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 0 hibernate: platform
avail: shutdown,reboot,suspend,test_resume image: 3.05 GiB daemons: upowerd,
org_kde_powerdevil, power-profiles-daemon Init: systemd v: 255
Packages: pm: pacman pkgs: 1347 libs: 365 tools: pamac Compilers:
clang: 16.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.21
running-in: konsole inxi: 3.3.32
and this is what i got when using infxi -Fazy command
it is in /usr/lib/NetworkManager/conf.d
- perhaps ping.manjaro.org did not answer.
In any case ping.manjaro.org is misconfigured - it redirects to https which signals a captive portal.
I will inform the team.
You can override by copying the orginal to /etc where you looked.
I have my own service for Network Manager to deduce whether it is online (http://ping.nix.dk ).
ikiki
20 February 2024 08:08
4
when i pinged googles ip (8.8.8.8) it did respond
and, do i just have to copy the original conf.d file to the one i mentioned above ?
Hi @ikiki ,
But the default file for the check is as @linux-aarhus said, in /usr/lib/NetworkManager/conf.d/20-connectivity.conf
$ cat /usr/lib/NetworkManager/conf.d/20-connectivity.conf
[connectivity]
uri=http://ping.manjaro.org/check_network_status.txt
So it could simply be that the http://ping.manjaro.org/check_network_status.txt
URL is not responding. It happens.
Same.
Edit:
Indeed, it seems. It timed out here:
https://i.imgur.com/kpM69Ij.png
ikiki
20 February 2024 08:11
6
but it’s just not that since not just the ping.manjaro.org isn’t responding but my internet isn’t working either
But you can ping an IP?
ping 1.1.1.1
And can you ping a domain name?
ping manjaro.org
If not, please provide the output of:
cat /etc/resolv.conf
…and:
nslookup ping.manjaro.org
Please.
then you have other issues - connectivity check is only a check - it changes the icon - but not the connection - please see …
ikiki
20 February 2024 08:25
10
it says temporary failure in name resolution
ikiki
20 February 2024 08:26
11
says, no such file or directory
it is scaring the shit out of me now
It’s a DNS issue.
Did you change any DNS settings recently?
ikiki
20 February 2024 08:28
13
yes i did
but then i had changed it back to default right after that
how can i change it back to default ?just to be sure
Please provide the output of:
sudo systemctl status NetworkManager.service
Edit:
Without knowing what you changed, there’s no way to know…
ikiki
20 February 2024 08:34
15
NetworkManager.service - Network Manager
Loaded: loaded (/usr/lib/systemd/system/NetworkManager.service; enabled; preset: disabled)
Active: active (running) since Tue 2024-02-20 19:19:23 IST; 12min ago
Docs: man:NetworkManager(8)
Main PID: 395 (NetworkManager)
Tasks: 4 (limit: 9363)
Memory: 28.1M (peak: 30.1M)
CPU: 309ms
CGroup: /system.slice/NetworkManager.service
└─395 /usr/bin/NetworkManager --no-daemon
Feb 20 19:19:29 manjaro NetworkManager[395]: [1708436969.2690] policy: set ‘vivo T2 5G’ (>
Feb 20 19:19:33 manjaro NetworkManager[395]: [1708436973.2879] agent-manager: agent[a7507>
Feb 20 19:19:33 manjaro NetworkManager[395]: [1708436973.4826] device (3C:19:5E:21:71:B2)>
Feb 20 19:22:29 manjaro NetworkManager[395]: [1708437149.6913] manager: (3C:19:5E:21:71:B>
Feb 20 19:22:29 manjaro NetworkManager[395]: [1708437149.6917] device (3C:19:5E:21:71:B2)>
Feb 20 19:22:29 manjaro NetworkManager[395]: [1708437149.6937] device (3C:19:5E:21:71:B2)>
Try the following:
pamac reinstall openresolv --overwrite='/etc/*'
Note:
The --overwrite
argument can be dangerous, so don’t use it nilly-willy.
Afterwards, provide the output of:
…again, please.
ikiki
20 February 2024 08:45
18
i guess since internet isnt working so i cant even download anything…
ikiki
20 February 2024 08:46
19
i am gonna search for some solution on how to use the internet through my mobile with cable
