LightDM - Pruning / purging multiple unecessary WM options
What is with ldm WM (Gnome) options? When I select the WM options menu in ldm, this is what I see: https://i.imgur.com/1bz956w.jpg
I understand, accept, and am happy to see these options at the bottom:
But that should be it. Next you can see:
I am uninterested in running Classic versions of Gnome.
What happens next is really strange:
It doesn’t specify which protocol, whether Xorg or Wayland.
How do I prune / delete / remove all of these redundant and non-descript options?
The options is presented as they are read from /usr/share/xsessions.
GDM is the default displaymanager for Gnome and wihen you use LightDM it is a deliberate choice.
You could try removing GDM
sudo pacman -R gdm
That said - this removal may affect the default Gnome Desktop locking mechanism.
Removing GDM may also involve other system reconfiguration such as removal of plymouth and reconfiguration of mkinitcpio and grub.
