I started a thread last week here:
It closed automatically after 2 days. I wasn’t finished. I am back with more to discuss.
I attempted to remove gdm. I don’t think it was installed to begin with. Although I could be mistaken because if I understand correctly, I can’t find gdm in the repo since pacman and yay don’t autocomplete to a specific stand alone gdm
package. All I see is libgdm
$ sudo pacman -R libgdm
checking dependencies...
:: removing libgdm breaks dependency 'libgdm' required by gnome-shell-maia
Not sure if removing that is what is necessary or if that is what @linux-aarhus was referring to in his reply in my other thread.
This was what I was working with originally:
There are .desktop
files for sessions in /usr/share/xsessions/
. Rather than deleting and removing some of them, I just created a backup directory and moved all the ones I didn’t like into them like so:
$ cd bax2k23Aug21
$ pwd
/usr/share/xsessions/bax2k23Aug21
$ ls -la
total 44
drwxr-xr-x 2 root root 4096 Aug 21 04:51 .
drwxr-xr-x 3 root root 4096 Aug 29 16:46 ..
-rw-r--r-- 1 root root 984 Aug 10 18:08 e16-gnome2-session.desktop
-rw-r--r-- 1 root root 211 Aug 10 18:08 e16-gnome3-session.desktop
-rw-r--r-- 1 root root 969 Aug 10 18:08 e16-kde-session.desktop
-rw-r--r-- 1 root root 8139 Apr 28 20:21 gnome-classic.desktop
-rw-r--r-- 1 root root 7617 Apr 28 20:21 gnome-classic-xorg.desktop
-rw-r--r-- 1 root root 7830 Apr 9 19:56 gnome.desktop
Therefore, here is what the contents of the parent /usr/share/xsessions
directory looks like now:
$ pwd
$ ls -la
total 28
drwxr-xr-x 362 root root 12288 Aug 29 16:46 ..
drwxr-xr-x 2 root root 4096 Aug 21 04:51 bax2k23Aug21
-rw-r--r-- 1 root root 7915 Apr 9 19:56 gnome-xorg.desktop
The impact now is that some of the options I am trying to get rid of are gone. See here:
So that’s progress I guess. But there are some that are still not necessary.
ldm now presents:
How do I prune these further so that I only see:
How do I get rid of all those “Classic” options as well as the non-descript “GNOME”?
Where else on a Linux system with ldm as the greeter might configurations be stored for me to change to achieve the desired end result?
