Hello,
as my Title says my lightdm does not start on boot.
I have installed manjaro i3 with open-source about three times and the blinking underscore greets me upon boot every time…
Then I do ctrl+alt+F2 log in and run sudo systemctl restart display-manager
and I can log in. I would like to skip this process.
I have tried:
reinstall some packages
and -
add
logind-check-graphical=truein the file/etc/lightdm/lightdm.conf
but it did not work.
I have commented thelogind-check-graphical=truein/etc/lightdm/lightdm.confsince lightdm did not recognize this option, thus it did not know this option.
Here are my graphical information:
[man@tower ~]$ inxi -Gx
Graphics: Device-1: NVIDIA GM107 [GeForce GTX 750 Ti] vendor: ASUSTeK driver: nouveau v: kernel bus-ID: 05:00.0
Display: x11 server: X.Org 1.20.13 driver: loaded: modesetting resolution: 2560x1440~60Hz
OpenGL: renderer: NV117 v: 4.3 Mesa 21.2.3 direct render: Yes
Here is the shortened versions of my lightdm.log:
[+0.00s] DEBUG: Logging to /var/log/lightdm/lightdm.log
[+0.00s] DEBUG: Starting Light Display Manager 1.30.0, UID=0 PID=850
[+0.00s] DEBUG: Loading configuration dirs from /usr/share/lightdm/lightdm.conf.d
[+0.00s] DEBUG: Loading configuration dirs from /usr/local/share/lightdm/lightdm.conf.d
[+0.00s] DEBUG: Loading configuration dirs from /etc/xdg/lightdm/lightdm.conf.d
[+0.00s] DEBUG: Loading configuration from /etc/lightdm/lightdm.conf
[+0.00s] DEBUG: Registered seat module local
[+0.00s] DEBUG: Registered seat module xremote
[+0.00s] DEBUG: Using D-Bus name org.freedesktop.DisplayManager
[+0.00s] DEBUG: _g_io_module_get_default: Found default implementation local (GLocalVfs) for ‘gio-vfs’
[+0.00s] DEBUG: Monitoring logind for seats
[+0.00s] DEBUG: New seat added from logind: seat0
[+0.00s] DEBUG: Seat seat0: Loading properties from config section Seat:*
[+0.00s] DEBUG: Seat seat0 has property CanMultiSession=no
[+0.00s] DEBUG: Seat seat0: Starting
[+0.00s] DEBUG: Seat seat0: Creating greeter session
[+0.00s] DEBUG: Seat seat0: Creating display server of type x
[+0.00s] DEBUG: Could not run plymouth --ping: Failed to execute child process “plymouth” (No such file or directory)
[+0.00s] DEBUG: Using VT 7
[+0.00s] DEBUG: Seat seat0: Starting local X display on VT 7
[+0.00s] DEBUG: XServer 0: Logging to /var/log/lightdm/x-0.log
[+0.00s] DEBUG: XServer 0: Writing X server authority to /run/lightdm/root/:0
[+0.00s] DEBUG: XServer 0: Launching X Server
[+0.00s] DEBUG: Launching process 855: /usr/bin/X :0 -seat seat0 -auth /run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
[+0.00s] DEBUG: XServer 0: Waiting for ready signal from X server :0
[+0.00s] DEBUG: Acquired bus name org.freedesktop.DisplayManager
[+0.00s] DEBUG: Registering seat with bus path /org/freedesktop/DisplayManager/Seat0
[+0.00s] DEBUG: Loading users from org.freedesktop.Accounts
[+0.01s] DEBUG: Process 855 exited with return value 1
[+0.01s] DEBUG: XServer 0: X server stopped
[+0.01s] DEBUG: Releasing VT 7
[+0.01s] DEBUG: XServer 0: Removing X server authority /run/lightdm/root/:0
[+0.01s] DEBUG: Seat seat0: Display server stopped
[+0.01s] DEBUG: Seat seat0: Stopping session
[+0.01s] DEBUG: Seat seat0: Session stopped
[+0.01s] DEBUG: Seat seat0: Stopping display server, no sessions require it
[+0.01s] DEBUG: Seat seat0: Stopping; greeter display server failed to start
[+0.01s] DEBUG: Seat seat0: Stopped
[+0.01s] DEBUG: Required seat has stopped
[+0.01s] DEBUG: Stopping display manager
[+0.01s] DEBUG: Display manager stopped
[+0.01s] DEBUG: Stopping daemon
[+0.01s] DEBUG: Exiting with return value 1
And my Xorg.0.log:
X.Org X Server 1.20.13
[ 3.069] Build Operating System: Linux Manjaro Linux
[ 3.069] Current Operating System: Linux tower 5.13.19-2-MANJARO #1 SMP PREEMPT Sun Sep 19 21:31:53 UTC 2021 x86_64
[ 3.069] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.13-x86_64 root=UUID=180791df-a50a-44c5-845a-6d252467d3f8 rw quiet udev.log_priority=3
[ 3.069] Build Date: 24 August 2021 10:21:29AM
[ 3.069]
[ 3.069] Current version of pixman: 0.40.0
[ 3.069] Before reporting problems, check http://wiki.x.org
[ 3.069] Markers: (--) probed, (**) from config file, (==) default setting,
[ 3.069] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Oct 23 16:20:12 2021
[ 3.069] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 3.069] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 3.069] (==) No Layout section. Using the first Screen section.
[ 3.069] (==) No screen section available. Using defaults.
[ 3.069] (**) |-->Screen "Default Screen Section" (0)
[ 3.069] (**) | |-->Monitor "<default monitor>"
[ 3.070] (==) No monitor specified for screen "Default Screen Section".
[ 3.070] (==) Automatically adding devices
[ 3.070] (==) Automatically enabling devices
[ 3.070] (==) Automatically adding GPU devices
[ 3.070] (==) Automatically binding GPU devices
[ 3.070] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 3.070] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 3.070] Entry deleted from font path.
[ 3.070] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 3.070] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 3.070] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF,
/usr/share/fonts/OTF
[ 3.070] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 3.070] (II) The server relies on udev to provide the list of input devices.
[ 3.070] (II) Module ABI versions:
[ 3.070] X.Org ANSI C Emulation: 0.4
[ 3.070] X.Org Video Driver: 24.1
[ 3.070] X.Org XInput driver : 24.1
[ 3.070] X.Org Server Extension : 10.0
[ 3.070] (++) using VT number 7
[ 3.070] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 3.071] (--) PCI:*(5@0:0:0) 10de:1380:1043:84bb rev 162, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[ 3.071] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 3.071] (II) LoadModule: "glx"
[ 3.071] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 3.072] (II) Module glx: vendor="X.Org Foundation"
[ 3.072] compiled for 1.20.13, module version = 1.0.0
[ 3.072] ABI class: X.Org Server Extension, version 10.0
[ 3.073] (==) Matched nouveau as autoconfigured driver 0
[ 3.073] (==) Matched nv as autoconfigured driver 1
[ 3.073] (==) Matched modesetting as autoconfigured driver 2
[ 3.073] (==) Matched fbdev as autoconfigured driver 3
[ 3.073] (==) Matched vesa as autoconfigured driver 4
[ 3.073] (==) Assigned the driver to the xf86ConfigLayout
[ 3.073] (II) LoadModule: "nouveau"
[ 3.073] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[ 3.073] (II) Module nouveau: vendor="X.Org Foundation"
[ 3.073] compiled for 1.20.10, module version = 1.0.17
[ 3.073] Module class: X.Org Video Driver
[ 3.073] ABI class: X.Org Video Driver, version 24.1
[ 3.073] (II) LoadModule: "nv"
[ 3.073] (WW) Warning, couldn't open module nv
[ 3.073] (EE) Failed to load module "nv" (module does not exist, 0)
[ 3.073] (II) LoadModule: "modesetting"
[ 3.073] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 3.073] (II) Module modesetting: vendor="X.Org Foundation"
[ 3.073] compiled for 1.20.13, module version = 1.20.13
[ 3.073] (II) LoadModule: "fbdev"
[ 3.073] (WW) Warning, couldn't open module fbdev
[ 3.073] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 3.073] (II) LoadModule: "vesa"
[ 3.074] (WW) Warning, couldn't open module vesa
[ 3.074] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 3.074] (II) NOUVEAU driver
[ 3.074] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 3.074] (EE) [drm] Failed to open DRM device for pci:0000:05:00.0: -19
[ 3.074] (EE) open /dev/dri/card0: No such file or directory
[ 3.074] (WW) Falling back to old probe method for modesetting
[ 3.074] (EE) Screen 0 deleted because of no matching config section.
[ 3.074] (II) UnloadModule: "modesetting"
[ 3.074] (EE) Device(s) detected, but none match those in the config file.
[ 3.074] (EE)
Fatal server error:
[ 3.074] (EE) no screens found(EE)
[ 3.074] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 3.074] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 3.074] (EE)
[ 3.074] (EE) Server terminated with error (1). Closing log file.
