Light display manager failed to start
So I already made this post on the Manjaro subreddit, but anyway the thing is I recently installed an amd driver on my computer and when I booted it up it didn’t display anything other than a message saying that the light display manager had failed to start.
Also I used tty to try and reinstall the video drivers and it didn’t work, only showing a message saying that the video-modesetting config file is invalid.
Any help would be appreciated!
Hi :wave:
This is a little bit meager information. I don’t think anybody here has a glass ball.
Please provide more information:
  1. cat /var/log/Xorg.0.log and cat /var/log/Xorg.1.log
  2. Files in /etc/X11/xorg.conf.d/
  3. journalctl -b -0 --no-pager
Thanks
How exactly do I use these commands that you sent.
I navigated to the the folder and typed the journal command and got spammed by logs
Ok so you are new to linux… now slowly:
  1. Use if possible a install disk and boot it
  2. open a terminal and type manjaro-chroot -a and type 1
  3. then copy paste the commands line by line there
  4. Open a browser and paste the links here
I’ll make it it easy for you:
cat /var/log/Xorg.0.log | curl --upload - https://aptget.xyz/Xorg.0.log
cat /var/log/Xorg.1.log  | curl --upload - https://aptget.xyz/Xorg.1.log
for x in $(ls /etc/X11/xorg.conf.d/); do curl --upload /etc/X11/xorg.conf.d/$x https://aptget.xyz/$x; done
journalctl -b -0 --no-pager  | curl --upload - https://aptget.xyz/boot.0.log
Good success :wink:
Ok I will try to boot into a live usb tomorrow, because i don’t have any usb or discs available right now.
Also do I need to boot in a live media or can I do it in tty?
Here are the links (for some reason the xorg.conf.d could not be uploaded)
h ttp://aptget.xyz/Mjzki/Xorg.0.log
h ttp://aptget.xyz/sYaRP/Xorg.1.log
h ttp://aptget.xyz/7JPI8/boot.0.log
Also just remove the spaces in http i did this because the forum did not let me send links
Yeah, removed " at the end… now it works.
This file is empty… try to use -1 instead of -0 for the previous boot.
Ok here you go
h ttp://aptget.xyz/8jnSL/00-keyboard.conf
h ttp://aptget.xyz/zvDCp/90-mhwd.conf
h ttp://aptget.xyz/gWksr/boot.0.log
I think that the boot log is empty because the journalctl is not being recognized as a command
Any new information about the situation?
Please also this output:
mhwd -l && mhwd -li
h ttp://imgur.com/gallery/9zkI0Sr
Here you go
As i thought… remove video-modesetting and video-vesa and reinstall video-linux.
mhwd -r video-modesetting
mhwd -r video-vesa
mhwd -i -f video-linux
You can’t use all of that stuff without a proper configuration. video-linux is enough. it contains all free drivers.
Ok I did all of the commands, should I reboot now?
Ok It worked! Thank you!
Also is there something more to do or is that it?
Just don’t install them again… inform yourself what a specific driver does before installing. On Linux you have to think before doing unlike on windows :wink:
Ok I will be more careful next time I install drivers, I mean i don’t even know why I did that in the first place.
Anyway is there a way I can pay for your help? (I know that the forum is free, I just would like to compensate for the help).
Thank you for your offer and I am really flattered that you appreciate my help, but the money would be better invested in Manjaro development and and the free services it offers.
:blush:
Ok! It’s only fair to give back to the developers that provide this awesome operating system, and it’s community :slightly_smiling_face:
