Strange message from: pip list -o | grep -i libtorrent
/usr/lib/python3.10/site-packages/pkg_resources/__init__.py:116: PkgResourcesDeprecationWarning: 2.0.5-build-libtorrent-rasterbar-src-libtorrent-rasterbar-2.0.5-bindings-python is an invalid version and will not be supported in a future release
warnings.warn(
libtorrent 2.0.5-build-libtorrent-rasterbar-src-libtorrent-rasterbar-2.0.5-bindings-python 2.0.5 wheel
libtorrent-rasterbar 1:2.0.5-1 was upgraded from extra repository as qbittorrent dependancy at last major upgrade.
105 β class PEP440Warning(RuntimeWarning):
106 β """
107 β Used when there is an issue with a version or specifier not complying with
108 β PEP 440.
109 β """
110 β
111 β
112 β def parse_version(v):
113 β try:
114 β return packaging.version.Version(v)
115 β except packaging.version.InvalidVersion:
116 β warnings.warn(
117 β f"{v} is an invalid version and will not be supported in "
118 β "a future release",
119 β PkgResourcesDeprecationWarning,
120 β )
121 β return packaging.version.LegacyVersion(v)
I have a similar issue with qbittorrent (libtorrent python package) python-pipenv installed from pamac. Running pipenv always give me the same error as the author say. I have no test installing pipenv from pip.
I have no idea how to shut down the warning. (Maybe overwritting libtorrent version for 2.0.5 instead of 2.0.5-build-libtorrent-rasterbar-src-libtorrent-rasterbar-2.0.5-bindings-python, but I am not sure if qbittorrent will be working)
$ pipenv check
warnings.warn(
Anyways I am triggered why pipenv shot the warning. Are pipenv and (libtorrent) qbittorrent related in a obscure way?
Shall we report this issue to the arch manteiner or upstream (qbitorrent - libtorrent dependency)?
I noticed libtorrent official version is: 2.0.5
and not $ pip list | grep libtorrent 2.0.5-build-libtorrent-rasterbar-src-libtorrent-rasterbar-2.0.5-bindings-python
I guess this caused the warning, so I think I should report to the arch packager, but they donβt accept other OS, only Archlinux which is inconvenient
$ pamac info qbittorrent
Version : 4.4.0-2
Description : An advanced BitTorrent client programmed in C++, based on Qt toolkit and libtorrent-rasterbar
URL : https://www.qbittorrent.org
Licenses : custom GPL
Repository : community
Installed Size : 9.7 MB
Groups : --
Depends On : libtorrent-rasterbar qt6-base qt6-svg hicolor-icon-theme
Optional Dependencies : python: needed for torrent search tab [Installed]
Required By : --
Optional For : --
Provides : --
Replaces : --
Conflicts With : --
Packager : Antonio Rojas <arojas@archlinux.org>
Build Date : Mon 10 Jan 2022 12:09:21 PM -05
Install Date : Sun 23 Jan 2022 05:52:16 PM -05
Install Reason : Explicitly installed
Validated By : Signature
Backup files : --
The solution for me was to remove the package and all its dependencies with pacman -Rs (since it was a package that I donβt use and it doesnβt interfere with anything else, it was the best idea I had)
Iβve manually updated the Python package, sudo pip install -U libtorrent, but it didnβt help that much as pipenv was still giving the same error, perhaps had the libtorrent version name was updated as expected (2.0.5).
warnings.warn(
So, after looking to the libtorrent-rasterbar dependencies with, pacman -Sii libtorrent-rasterbar | grep 'Required By', I notice none of the programs there are installed in my system, as @Jectluci did, I removed the libtorrent-rasterbar package too.
