Okay, more detail is needed. I’m using an i3-4130 processor with 8GB RAM so you should be a fair bit quicker…
I actually chose to have WPS for my main office suite… not that I do much, but it’s enough for me - writer documents look great, save to .docx and give no headaches and it works perfectly with my old spreadsheet too. I haven’t tested it myself, but I hear freeoffice is also pretty tasty.
WPS takes less than 2 seconds to appear and works well… wps-office 11.1.0.9719-1 [installed]
doing a quick search brings up freeoffice as a top answer also which is comparable (with minor differences - it really depends on your use case perhaps).
That’s not a solution, but a possible workaround if you’re in need. I’m not sure who uses Libre - some might even use the snap or appimages, but I wanted a break from those menus.
Ok, let’s play:
trizen office
Summary
6 extra/libreoffice-fresh-af 7.0.4-1
Afrikaans language pack for LibreOffice Fresh
5 extra/libreoffice-fresh 7.0.4-1
LibreOffice branch which contains new features and program enhancements
4 extra/libcdr 0.1.6-2
CorelDraw file format importer library for LibreOffice
3 extra/hplip 1:3.20.11-2 [installed]
Drivers for HP DeskJet, OfficeJet, Photosmart, Business Inkjet and some LaserJet
2 extra/goffice 0.10.48-1
A GLib/GTK+ set of document-centric objects and charting library
1 extra/freeoffice 2018.980-1
A complete, reliable, lightning-fast and Microsoft Office-compatible office suite with a word processor, spreadsheet, and presentation graphics software.
=>> Select packages to install
I love that entry ‘fresh-af’ means fresher than fresh, fresh as f@ck? Let’s go with number 5.
5
:: Pacman command: /usr/bin/sudo /usr/bin/pacman -S extra/libreoffice-fresh
[sudo] password for ben:
resolving dependencies…
Packages (30) clucene-2.3.3.4-11 libabw-0.1.3-2 libatomic_ops-7.6.10-2 libcdr-0.1.6-2 libcmis-0.5.2-6 libe-book-0.1.3-7 libepubgen-0.1.1-2 libetonyek-0.1.9-2 libexttextcat-3.4.5-2 libfreehand-0.1.2-3 libixion-0.16.1-5 liblangtag-0.6.3-2 libmspub-0.1.4-8 libmwaw-0.3.17-1 libnumbertext-1.0.6-1 libodfgen-0.1.7-2 liborcus-0.16.1-5 libpagemaker-0.0.4-2 libqxp-0.0.2-4 librevenge-0.0.4-3 libstaroffice-0.0.7-1 libvisio-0.1.7-3 libwpd-0.10.3-2 libwpg-0.3.3-2 libwps-0.4.12-1 libzmf-0.0.2-8 lpsolve-5.5.2.5-4 rasqal-1:0.9.33-4 redland-1:1.0.17-8 libreoffice-fresh-7.0.4-1
Total Download Size: 154.93 MiB
Total Installed Size: 668.13 MiB
Fairly hefty, but easy enough to clean up if I don’t like it, right?
Ok, installed - then launch writer from the menu and I must say it does look like a bit of a pig with freezing progress bars - I had to open conky to watch RAM, it looked like I’d run out it was so slow. Never worked like this before (I think I last had it about 3 months ago).
Theme looks okay, but looks like I’m running an intel atom here. Closing it and relaunching, it still took a good 14 seconds to paint paper on the screen in writer from my 860 EVO (which launches GIMP from cold in under 2 seconds).
Winner here - WPS (because it’s already installed).
Clean up: ❯ trizen -Rns libreoffice-fresh :: Pacman command: /usr/bin/sudo /usr/bin/pacman -Rns libreoffice-fresh
Sorry, no solution from me - I’m done here. I wonder if this is an issue with Java runtime - but I must admit I don’t care enough to work hard at this.
