gibbz
1
I cant seem to get the lastest update, there is some missing dependancies. How do I fix this issue?
:: Replace lib32-libcanberra-pulse with multilib/lib32-libcanberra? [Y/n]
:: Replace libcanberra-pulse with extra/libcanberra? [Y/n]
:: Replace qca with extra/qca-qt5? [Y/n]
resolving dependencies...
:: installing lib32-libcanberra (0.30+2+gc0620e4-4) breaks dependency 'lib32-libcanberra=0.30+2+gc0620e4-3' required by lib32-libcanberra-gstreamer
:: installing libcanberra (0.30+2+gc0620e4-4) breaks dependency 'libcanberra=0.30+2+gc0620e4-3' required by libcanberra-gstreamer
error installing repo packages
You might be blocked updating when using pacman due to some libcanberra packages. Simply remove those packages:
sudo pacman -Rdd lib32-libcanberra-pulse lib32-libcanberra-gstreamer libcanberra-pulse libcanberra-gstreamer
We recommend to use pamac anyway, which does this automatically:
pamac update
Reference:
Hi,
There was a discussion about this is the update thread. Using pamac update -a to update will sort out the dependency issues.
gibbz
4
Thanks! thats fixed the issue! Ill have to use pamac in the future
