Hello community,
libcanberra 0.30+2 update error because it breaks dependencies. why ? what was reason? after i upgrade all by software manager.
Hello community,
Hello,
Please always read announcements
u mean i should use pamac update
instead of pacman -Syyu?
should i uninstall libcanbera?
Either you use
pamac update
you remove the packages by
sudo pacman -Rdd lib32-libcanberra-pulse lib32-libcanberra-gstreamer libcanberra-pulse libcanberra-gstreamer
and then run
sudo pacman-mirrors -f && sudo pacman -Syyu
thanks both of you. your answers are useful
