I have a Lenovo Yoga 500-14ISK. The touchscreen works in Windows but isn’t showing up in Manjaro via lsusb, lspci, or inxi. Please help. I am familiar with Linux and bash, but I haven’t messed around with low level configuration and files before.
Welcome to Manjaro!
- Please read this:
How to provide good information
and press the three dots … below your post and press the
to give us more information so we can see what’s really going on.
Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
- An
inxi --admin --verbosity=7 --filter --no-host --widthwould be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
Please post the output of the following commands:
sudo timeout 3 libinput debug-events
ls /sys/bus/{acpi,i2c,hid}/devices/
@Fabby The output to inxi --admin --verbosity=7 --filter --no-host --width is:
Kernel: 5.13.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=627b3b47-b880-4200-8cf4-2d279a3a7786 rw quiet splash apparmor=1
security=apparmor resume=UUID=2a228369-5b99-4713-9ae0-6efe56039559
udev.log_priority=3
Desktop: GNOME 40.4 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
Type: Laptop System: LENOVO product: 80R5 v: Lenovo Yoga 500-14ISK
serial: <filter> Chassis: type: 10 v: Lenovo Yoga 500-14ISK serial: <filter>
Mobo: LENOVO model: Lenovo Yoga 500-14ISK v: SDK0J40679 WIN serial: <filter>
UEFI: LENOVO v: D3CN39WW date: 06/26/2018
ID-1: BAT0 charge: 30.2 Wh (62.5%) condition: 48.3/52.5 Wh (92.0%)
volts: 11.7 min: 11.4 model: LGC L15L3PB0 type: Li-poly serial: <filter>
status: Discharging
RAM: total: 3.64 GiB used: 2.62 GiB (71.9%)
Info: Dual Core model: Intel Core i5-6200U bits: 64 type: MT MCP
arch: Skylake family: 6 model-id: 4E (78) stepping: 3 microcode: EA cache:
L2: 3 MiB bogomips: 19204
Speed: 680 MHz min/max: 400/2300 MHz Core speeds (MHz): 1: 680 2: 647 3: 748
4: 638
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Lenovo driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: NVIDIA GK208BM [GeForce 920M] vendor: Lenovo driver: nouveau
v: kernel bus-ID: 01:00.0 chip-ID: 10de:1299 class-ID: 0302
Display: wayland server: X.org 1.20.13 compositor: gnome-shell driver:
loaded: nouveau note: n/a (using device driver) - try sudo/root
display-ID: 0 resolution: <missing: xdpyinfo>
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 21.2.1
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d70 class-ID: 0403
Device-2: NVIDIA GK208 HDMI/DP Audio driver: snd_hda_intel v: kernel
bus-ID: 01:00.1 chip-ID: 10de:0e0f class-ID: 0403
Sound Server-1: ALSA v: k5.13.12-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: yes
Device-1: Intel Dual Band Wireless-AC 3165 Plus Bluetooth driver: iwlwifi
v: kernel port: d000 bus-ID: 02:00.0 chip-ID: 8086:3166 class-ID: 0280
vendor: Lenovo driver: r8169 v: kernel port: c000 bus-ID: 03:00.0
bus-ID: 1-8:3 chip-ID: 8087:0a2a class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 476.94 GiB used: 21.68 GiB (4.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Intel model: SSDSC2KW512G8
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 004C scheme: GPT
ID-1: / raw-size: 369.46 GiB size: 362.59 GiB (98.14%)
used: 21.33 GiB (5.9%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 627b3b47-b880-4200-8cf4-2d279a3a7786
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 25.6 MiB (5.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 2ABA-9241
ID-1: swap-1 type: partition size: 5.87 GiB used: 334 MiB (5.6%)
priority: -2 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 2a228369-5b99-4713-9ae0-6efe56039559
ID-1: /dev/sda4 maj-min: 8:4 size: 101.12 GiB fs: ntfs label: N/A
uuid: 3414C4D714C49D6C
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-8:3 info: Intel Bluetooth wireless interface type: Bluetooth
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 39.0 C mobo: 39.0 C gpu: nouveau temp: 41.0 C
Processes: 256 Uptime: 42m wakeups: 8 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 Packages: 1257 pacman: 1252 lib: 305 flatpak: 5
Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.06
@pobrn The output to sudo timeout 3 libinput debug-events is:
-event2 DEVICE_ADDED Power Button seat0 default group1 cap:k
-event7 DEVICE_ADDED Video Bus seat0 default group2 cap:k
-event8 DEVICE_ADDED Video Bus seat0 default group2 cap:k
-event0 DEVICE_ADDED Lid Switch seat0 default group3 cap:S
-event1 DEVICE_ADDED Sleep Button seat0 default group4 cap:k
-event4 DEVICE_ADDED Ideapad extra buttons seat0 default group5 cap:k
-event3 DEVICE_ADDED AT Translated Set 2 keyboard seat0 default group6 cap:k
-event6 DEVICE_ADDED ETPS/2 Elantech Touchpad seat0 default group7 cap:pg size 98x61mm tap(dl off) left scroll-nat scroll-2fg-edge click-buttonareas-clickfinger dwt-on
-event16 DEVICE_ADDED SPA8000B (AVRCP) seat0 default group8 cap:k
The output to ls /sys/bus/{acpi,i2c,hid}/devices/ is:
/sys/bus/acpi/devices/:
ACPI0003:00 device:25 device:4c IDEA0100:00 INT3472:06 LNXTHERM:00
ACPI000C:00 device:26 device:4d IMPJ0003:00 INT3472:07 LNXTHERM:01
device:00 device:27 device:4e INT0000:00 INT3F0D:00 LNXVIDEO:00
device:01 device:28 device:4f INT0800:00 LNXCPU:00 LNXVIDEO:01
device:02 device:29 device:50 INT0E0C:00 LNXCPU:01 MSFT0101:00
device:03 device:2a device:51 INT3394:00 LNXCPU:02 PNP0000:00
device:04 device:2b device:52 INT339B:00 LNXCPU:03 PNP0100:00
device:05 device:2c device:53 INT33A1:00 LNXCPU:04 PNP0103:00
device:06 device:2d device:54 INT33A2:00 LNXCPU:05 PNP0A08:00
device:07 device:2e device:55 INT33A3:00 LNXCPU:06 PNP0B00:00
device:08 device:2f device:56 INT33D1:00 LNXCPU:07 PNP0C02:00
device:09 device:30 device:57 INT33D3:00 LNXPOWER:00 PNP0C02:01
device:0a device:31 device:58 INT33D6:00 LNXPOWER:01 PNP0C02:02
device:0b device:32 device:59 INT33E1:00 LNXPOWER:02 PNP0C02:03
device:0c device:33 device:5a INT3420:00 LNXPOWER:03 PNP0C02:04
device:0d device:34 device:5b INT3420:01 LNXPOWER:04 PNP0C02:05
device:0e device:35 device:5c INT343D:00 LNXPOWER:05 PNP0C04:00
device:0f device:36 device:5d INT343E:00 LNXPOWER:06 PNP0C09:00
device:10 device:37 device:5e INT3440:00 LNXPOWER:07 PNP0C0A:00
device:11 device:38 device:5f INT3441:00 LNXPOWER:08 PNP0C0D:00
device:12 device:39 device:60 INT3443:00 LNXPOWER:09 PNP0C0E:00
device:13 device:3a device:61 INT3444:00 LNXPOWER:0a PNP0C0F:00
device:14 device:3b device:62 INT3445:00 LNXPOWER:0b PNP0C0F:01
device:15 device:3c device:63 INT3446:00 LNXPOWER:0c PNP0C0F:02
device:16 device:3d device:64 INT3447:00 LNXPOWER:0d PNP0C0F:03
device:17 device:3e device:65 INT3448:00 LNXPOWER:0e PNP0C0F:04
device:18 device:3f device:66 INT3449:00 LNXPOWER:0f PNP0C0F:05
device:19 device:40 device:67 INT344A:00 LNXPOWER:10 PNP0C0F:06
device:1a device:41 device:68 INT344B:00 LNXPOWER:11 PNP0C0F:07
device:1b device:42 device:69 INT3471:00 LNXPOWER:12 PNP0C14:00
device:1c device:43 device:6a INT3471:01 LNXPOWER:13 PNP0C14:01
device:1d device:44 device:6b INT3471:02 LNXPOWER:14 PNP0C14:02
device:1e device:45 device:6c INT3471:03 LNXPOWER:15 VPC2004:00
device:1f device:46 device:6d INT3472:00 LNXPOWER:16 XXXX0000:00
device:20 device:47 device:6e INT3472:01 LNXPOWER:17 XXXX0000:01
device:21 device:48 device:6f INT3472:02 LNXPWRBN:00 ZIC0201:00
device:22 device:49 device:70 INT3472:03 LNXSYBUS:00
device:23 device:4a ETD0633:00 INT3472:04 LNXSYBUS:01
device:24 device:4b FPNT_DIS:00 INT3472:05 LNXSYSTM:00
/sys/bus/hid/devices/:
0018:0416:C300.0001
/sys/bus/i2c/devices/:
1-0052 i2c-10 i2c-13 i2c-16 i2c-3 i2c-6 i2c-9
i2c-0 i2c-11 i2c-14 i2c-17 i2c-4 i2c-7 i2c-INT33D1:00
i2c-1 i2c-12 i2c-15 i2c-2 i2c-5 i2c-8
In the future, when providing code/output, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text so that the output looks like this:
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.instead of like this:
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.`
(as that makes both our lives much easier)
No need to do anything right now as I’m a moderator here on this site and have fixed it for you already. However, in the future I might not see your post so review my edits by pushing the orange pencil above the post I just fixed.
We won’t charge you more
if you make longer posts that combine all required information into one.
Do you have a compelling reason to be on 5.13 Stable?
That seems rather old: have you tried updating your UEFI firmware yet???
Could you also run
head /sys/bus/acpi/devices/*/modalias
hey sorry im new to markdown formatting. yes im sorry for not providing adequate information but i had no idea how to use inxi and whenever i previously tried using it, i ended up with way too much information about my computer i couldnt make heads or tales of. my UEFI firmare, which i presume means my BIOS version, hasn’t been updated by Lenovo since 2016. this laptop was launched in 2014-16 if my memory serves me right. as for 5.13 stable, I have absolutely no idea. I just installed manjaro, ran sudo pacman -Syu, and started using the laptop. i don’t know what kernel headers etc are, i don’t know how to change kernel versions. all i know is that uname -r shows the kernel version.
UPDATE: I spent half an hour trying to use it in Windows, the hardware is malfunctioning never mind. thanks regardless, fabby and pobrn
Topic closed as the hardware was malfunctioning (Windows had the same issues)
