I have a Lenovo yoga pro mouse, which I am trying to connect to my laptop. It is connecting, since I can see the battery percentage and bluetoothctl also shows it as connected, however, when I move the mouse, the cursor doesn’t move as well. I ran libinput and when moving the mouse, nothing was happening. I found a post with a similar problem and they downgraded it. I did the same, but downgraded it from 6.18 to 6.12 (Since on my previous laptop it was working and it was on 6.12). It didn’t help. Any ideas on what I can do now?
In this post they checked with btmon whether you can see the events from the mouse. Did you do so? btmon is part of the package bluez-utils. Then, there is the note that from kernel 6.0 on the mouse worked - so they actually upgraded the kernel since they were on 5.* when it didn’t work. Please provide the output of inxi -zv8. Perhaps some package for Bluetooth support is missing. Did you install manjaro-bluetooth?
Kernel: 6.12.85-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
clocksource: hpet avail: acpi_pm
root=UUID=c0b7a99b-f9c9-49a0-9421-a744ae0f2d61 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.6.4 tk: Qt v: N/A info: frameworks v: 6.25.0
wm: kwin_wayland with: Docker vt: 1 dm: SDDM Distro: Manjaro
base: Arch Linux
Type: Laptop System: LENOVO product: 83LT v: Legion Pro 5 16ADR10
serial: <superuser required> Chassis: type: 10 v: Legion Pro 5 16ADR10
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
part-nu: LENOVO_MT_83LT_BU_idea_FM_Legion Pro 5 16ADR10
uuid: <superuser required> Firmware: UEFI vendor: LENOVO v: RLCN32WW
date: 11/25/2025
ID-1: BAT0 charge: 82.8 Wh (100%) condition: 82.8/80 Wh (103.6%)
volts: 17.71 min: 15.52 model: COSMX L24X4PC0 type: Li-poly serial: <filter>
charging: status: full cycles: 8
Device-1: apple_mfi_fastcharge_1-2 model: N/A serial: N/A charge: N/A
status: N/A
System RAM: total: 32 GiB available: 30.65 GiB used: 6.27 GiB (20.5%)
Device-1: Channel-A DIMM 0 type: DDR5 detail: synchronous unbuffered
(unregistered) size: 16 GiB speed: spec: 5600 MT/s actual: 5200 MT/s
volts: note: check curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
manufacturer: Cxmt part-no: CXMR4E816S6AS-CN1C serial: <filter>
Device-2: Channel-B DIMM 0 type: DDR5 detail: synchronous unbuffered
Info: model: AMD Ryzen 7 8745HX with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 4 gen: 4 level: v4 note: check built: 2022+ process: TSMC n5 (5nm)
family: 0x19 (25) model-id: 0x61 (97) stepping: 2 microcode: 0xA60120C
smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB
desc: 8x1024 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 1487 min/max: 400/5151 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1487 2: 1487 3: 1487
4: 1487 5: 1487 6: 1487 7: 1487 8: 1487 9: 1487 10: 1487 11: 1487 12: 1487
13: 1487 14: 1487 15: 1487 16: 1487 bogomips: 115024
apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
avx512ifma avx512vbmi avx512vl bmi1 bmi2 bpext cat_l3 cdp_l3 clflush
clflushopt clwb clzero cmov cmp_legacy constant_tsc cpb cppc cpuid cqm
cqm_llc cqm_mbm_local cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de
decodeassists erms extapic extd_apicid f16c flush_l1d flushbyasid fma fpu
fsgsbase fsrm fxsr fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs
invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb perfmon_v2 pfthreshold pge pku pni popcnt pse
pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
succor svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk
v_spec_ctrl vaes vgif vmcb_clean vme vmmcall vnmi vpclmulqdq wbnoinvd wdt
x2apic x2avic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not
affected
Device-1: NVIDIA GB206M [GeForce RTX 5060 Max-Q / Mobile] vendor: Lenovo
driver: N/A alternate: nouveau non-free: 550-580.xx+
status: current (as of 2025-11) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 8
link-max: gen: 5 speed: 32 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:2d59 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: Lenovo
driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1
empty: Writeback-1 bus-ID: 05:00.0 chip-ID: 1002:164e class-ID: 0300
temp: 56.0 C
Device-3: Luxvisions Innotech Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 30c9:00f8
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: Samsung ATNA60HS03-0 built: 2024 res:
mode: 2560x1600 hz: 165 scale: 125% (1.25) to: 2048x1280 dpi: 191 gamma: 1.2
chroma: red: x: 0.682 y: 0.318 green: x: 0.220 y: 0.725 blue: x: 0.141
y: 0.039 white: x: 0.314 y: 0.329 size: 340x220mm (13.39x8.66")
diag: 405mm (15.94") modes: 2560x1600, 1920x1200, 1920x1080, 1600x1200,
1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720, 1024x768, 800x600,
640x480
EDID-Warnings: 1: parse_edid: unknown tag 112 2: parse_edid: unknown tag
112
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 26.0.6-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon 610M (radeonsi
raphael_mendocino ACO DRM 3.61 6.12.85-1-MANJARO) device-ID: 1002:164e
memory: 500 MiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.341 layers: 8 device: 0 type: integrated-gpu name: AMD
Radeon 610M (RADV RAPHAEL_MENDOCINO) driver: mesa radv v: 26.0.6-arch1.1
device-ID: 1002:164e surfaces: N/A
Device-1: NVIDIA GB206 High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 8 link-max: gen: 5 speed: 32 GT/s
lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:22eb class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Audio Coprocessor vendor: Lenovo
driver: snd_rpl_pci_acp6x v: kernel alternate: snd_pci_acp3x,
snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: Lenovo
bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.12.85-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.6.4 status: active with: 1: pipewire-pulse
Device-1: MEDIATEK MT7925 802.11be 160MHz 2x2 PCIe Wireless Network Adapter
[Filogic 360] vendor: Lenovo driver: mt7925e v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 14c3:7925 class-ID: 0280
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 2000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: down mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
Device-1: Foxconn / Hon Hai Wireless_Device driver: btusb v: 0.8 type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2.3:3
chip-ID: 0489:e111 class-ID: e001 serial: <filter>
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 5.4
lmp-v: 13 status: discoverable: no pairing: no class-ID: 6c010c
Local Storage: total: 953.87 GiB used: 359.55 GiB (37.7%)
model: MZAL81T0HFLB-00BL2 size: 953.87 GiB block-size: physical: 512 B
fw-rev: 5L1QKXF7 temp: 45.9 C scheme: GPT
ID-1: / raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
used: 359.52 GiB (37.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: c0b7a99b-f9c9-49a0-9421-a744ae0f2d61
used: 32.7 MiB (10.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: N/A uuid: 8070-76C3
ID-3: /home raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
ID-4: /var/cache raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
ID-5: /var/log raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 1-1:2 info: Apple iPhone 5/5C/5S/6/SE/7/8/X/XR
type: still imaging driver: N/A interfaces: 1 rev: 2.0
chip-ID: 05ac:12a8 class-ID: 0601 serial: <filter>
Hub-4: 3-2:2 info: Genesys Logic Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 05e3:0610
Device-1: 3-2.3:3 info: Foxconn / Hon Hai Wireless_Device type: bluetooth
mode: 2.0 power: 100mA chip-ID: 0489:e111 class-ID: e001 serial: <filter>
Device-2: 3-2.4:4 info: Integrated Express ITE Device(8258)
type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
chip-ID: 048d:c195 class-ID: 0300
Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-6: 4-2:2 info: Genesys Logic GL3523 Hub ports: 2 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0620
Hub-7: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Device-1: 5-1:2 info: Luxvisions Innotech Integrated Camera type: video
driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 30c9:00f8 class-ID: fe01
serial: <filter>
System Temperatures: cpu: 64.1 C mobo: 53.0 C gpu: amdgpu temp: 57.0 C
Fan Speeds (rpm): N/A
Packages: 1491 pm: pacman pkgs: 1482 libs: 401 tools: pamac,yay pm: flatpak
pkgs: 9
1: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
2: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
3: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
4: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
5: https://mirror.fcix.net/manjaro/stable/$repo/$arch
6: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
7: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
8: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 424
1: cpu: 36.3% command: pamac-manager pid: 2698 mem: 1233.1 MiB (3.9%)
2: cpu: 13.0% command: qemu-system-x86_64 pid: 2056 mem: 1058.7 MiB (3.3%)
3: cpu: 10.0% command: kwin_wayland pid: 1260 mem: 247.3 MiB (0.7%)
4: cpu: 6.0% command: [napi/phy0-8194] pid: 613 mem: 0.00 MiB (0.0%)
5: cpu: 4.6% command: konsole pid: 7450 mem: 171.7 MiB (0.5%)
Memory top: 5 of 424
1: mem: 1233.1 MiB (3.9%) command: pamac-manager pid: 2698 cpu: 36.3%
2: mem: 1058.7 MiB (3.3%) command: qemu-system-x86_64 pid: 2056 cpu: 13.0%
3: mem: 542.9 MiB (1.7%) command: plasmashell pid: 1501 cpu: 2.7%
4: mem: 466.5 MiB (1.4%) command: vivaldi-bin pid: 7151 cpu: 3.9%
5: mem: 283.2 MiB (0.9%) command: baloorunner pid: 12720 cpu: 1.1%
Processes: 424 Power: uptime: 4m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.16 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 260 default: graphical
tool: systemctl
Compilers: gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.40
Also ran btmon and got this error:
HCI Event: Authenticated Payload Timeout Expired (0x57)
I have manjaro-bluetooth installed
Fixed it. Since I’m on a new laptop was still in the process of setting up some drivers. Apparently the mouse was sending movement info on the first channel and not the second. I was connecting to the second. Moved to first and it all worked. Still thanks for the help @jofi
