lspci -v | grep -A7 -i audio shows:
Audio device: Intel Corporation Raptor Lake High Definition Audio Controller (rev 11) (prog-if 80)
Subsystem: Lenovo Device 3d32
Flags: bus master, fast devsel, latency 32, IRQ 244, IOMMU group 15
Memory at 6405230000 (64-bit, non-prefetchable) [size=16K]
Memory at 6405000000 (64-bit, non-prefetchable) [size=1M]
Capabilities: <access denied>
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel, snd_soc_avs, snd_sof_pci_intel_tgl
Audio device: NVIDIA Corporation Device 22bb (rev a1)
Subsystem: Lenovo Device 3d34
Physical Slot: 1
Flags: bus master, fast devsel, latency 0, IRQ 17, IOMMU group 16
Memory at 89080000 (32-bit, non-prefetchable) [size=16K]
and
lspci -k | grep -A2 -i audio shows:
and hostnamectl shows:
Icon name: computer-laptop
Chassis: laptop đź’»
Machine ID: f735b7f8f3ec41a7947555c784d2244a
Boot ID: 3d143981296e4355a9b0b67ab70e7097
Kernel: Linux 6.9.5-1-MANJARO
Architecture: x86-64
Hardware Vendor: Lenovo
Hardware Model: Legion 9 16IRX9
Firmware Version: NXCN13WW
Firmware Date: Mon 2024-03-11
Firmware Age: 4month 1d
and inxi -Fxz shows:
Kernel: 6.9.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
Desktop: KDE Plasma v: 6.0.5 Distro: Manjaro base: Arch Linux
Type: Laptop System: LENOVO product: 83G0 v: Legion 9 16IRX9
serial: <superuser required>
Mobo: LENOVO model: LNVNB161216 v: SDK0T76461 WIN
serial: <superuser required> UEFI: LENOVO v: NXCN13WW date: 03/11/2024
ID-1: BAT0 charge: 77.8 Wh (77.1%) condition: 100.9/99.9 Wh (101.0%)
volts: 16.6 min: 15.6 model: Sunwoda L22D4PC3 status: not charging
Info: 24-core (8-mt/16-st) model: Intel Core i9-14900HX bits: 64
type: MST AMCP arch: Raptor Lake rev: 1 cache: L1: 2.1 MiB L2: 32 MiB
L3: 36 MiB
Speed (MHz): avg: 798 high: 845 min/max: 800/5600:5800:4100 cores: 1: 800
2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 718
12: 800 13: 800 14: 800 15: 800 16: 800 17: 800 18: 800 19: 800 20: 800
21: 800 22: 800 23: 800 24: 800 25: 800 26: 800 27: 800 28: 800 29: 845
30: 800 31: 800 32: 800 bogomips: 154880
Device-1: Intel Raptor Lake-S UHD Graphics vendor: Lenovo driver: i915
v: kernel arch: Gen-13 bus-ID: 0000:00:02.0
Device-2: NVIDIA GN21-X11 vendor: Lenovo driver: nvidia v: 550.90.07
arch: Lovelace bus-ID: 0000:01:00.0
Device-3: Luxvisions Innotech Integrated Camera driver: uvcvideo type: USB
bus-ID: 1-12:6
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0 driver: X:
loaded: modesetting,nvidia dri: iris gpu: i915 resolution: 3200x2000~165Hz
API: EGL v: 1.5 drivers: iris,kms_swrast,nvidia,swrast platforms:
active: gbm,x11,surfaceless,device inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.1.1-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RPL-S)
API: Vulkan v: 1.3.279 drivers: nvidia surfaces: xcb,xlib devices: 1
Device-1: Intel Raptor Lake High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 0000:00:1f.3
Device-2: NVIDIA vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 0000:01:00.1
API: ALSA v: k6.9.5-1-MANJARO status: kernel-api
Server-1: PipeWire v: 1.0.7 status: active
Device-1: Intel Raptor Lake-S PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 0000:00:14.3
IF: wlp0s20f3 state: down mac: <filter>
Device-2: Realtek Killer E3000 2.5GbE vendor: Lenovo driver: r8169
v: kernel port: 3000 bus-ID: 0000:a1:00.0
IF: enp161s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB
bus-ID: 1-14:8
Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
driver: vmd v: 0.6 bus-ID: 0000:00:0e.0
Device-1: md126 type: mdraid level: raid-0 status: active size: 1.86 TiB
Info: report: N/A blocks: 2000404480 chunk-size: 128k
Components: Online: 0: nvme1n1 1: nvme0n1
Device-2: md127 type: mdraid level: N/A status: inactive size: N/A
Info: report: N/A blocks: 4784 chunk-size: N/A
Components: Online: N/A Spare: 0: nvme1n1 1: nvme0n1
Local Storage: total: raw: 1.86 TiB usable: -4784 used: 72.15 GiB
ID-1: /dev/nvme0n1 vendor: KIOXIA model: N/A size: 953.87 GiB temp: 33.9 C
ID-2: /dev/nvme1n1 vendor: KIOXIA model: N/A size: 953.87 GiB temp: 33.9 C
ID-1: / size: 294.23 GiB used: 15.32 GiB (5.2%) fs: ext4 dev: /dev/md126p8
ID-2: /boot/efi size: 256 MiB used: 38.4 MiB (15.0%) fs: vfat
dev: /dev/md126p1
System Temperatures: cpu: 39.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 32 GiB note: est. available: 31.05 GiB used: 5.51 GiB (17.8%)
Processes: 490 Uptime: 27m Init: systemd
Packages: 1319 Compilers: gcc: 14.1.1 Shell: Zsh v: 5.9 inxi: 3.3.35
I have activated kernels ranging from version 6.1 to 6.9. The software appears to be functioning correctly, however, the speaker is not producing any sound.
Thank you.
