Olá comunidade Manjaro!
Venho tentando entrar em minha conta do LoL já faz algum tempo, porém toda vez que entro com meus dados no launcher ele congela naquele retângulo preto (que geralmente fica no lugar da logo do League of Legends).
Abaixo estão as infos do sistema e hardware:
inxi -Fazzy
Kernel: 5.10.32-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=4237b0b2-3f6a-4eef-9520-9f16bd2e9731 rw quiet
resume=UUID=750784bc-47f5-4650-a8c1-a94cc8e35d47 udev.log_priority=3
Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 2 dm: SDDM
Type: Laptop System: Hewlett-Packard product: HP Pavilion 15 Notebook PC
v: 0883100000305B10000620100 serial: Chassis: type: 10
serial:
Mobo: Hewlett-Packard model: 1982 v: 01.16 serial: UEFI: Insyde
v: F.39 date: 03/24/2017
Info: Quad Core model: AMD A8-5550M APU with Radeon HD Graphics bits: 64
type: MCP arch: Piledriver family: 15 (21) model-id: 13 (19) stepping: 1
microcode: 6001119 cache: L2: 2 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 16767
Speed: 1326 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz):
1: 1326 2: 1285 3: 1228 4: 1363
Type: spectre_v2
mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Device-1: AMD Richland [Radeon HD 8550G] vendor: Hewlett-Packard
driver: radeon v: kernel bus-ID: 00:01.0 chip-ID: 1002:990d class-ID: 0300
Device-2: Suyin HP Truevision HD type: USB driver: uvcvideo bus-ID: 2-4:2
chip-ID: 064e:e266 class-ID: 0e02 serial:
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: ati,radeon unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP res: 1366x768 hz: 60 dpi: 101 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: AMD ARUBA (DRM 2.50.0 / 5.10.32-1-MANJARO LLVM 11.1.0)
v: 4.3 Mesa 21.0.3 compat-v: 3.1 direct render: Yes
Device-1: AMD Trinity HDMI Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:01.1 chip-ID: 1002:9902
class-ID: 0403
Device-2: AMD FCH Azalia vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
Sound Server-1: ALSA v: k5.10.32-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.26 running: yes
Device-1: Realtek RTL8188EE Wireless Network Adapter vendor: Hewlett-Packard
driver: rtl8188ee v: kernel port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8179
class-ID: 0280
IF: wlo1 state: up mac:
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel port: 2000 bus-ID: 05:00.0 chip-ID: 10ec:8136
class-ID: 0200
IF: eno1 state: down mac:
Local Storage: total: 698.64 GiB used: 99.1 GiB (14.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABD075
size: 698.64 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
rotation: 5400 rpm serial: rev: 1C scheme: GPT
ID-1: / raw-size: 689.54 GiB size: 677.72 GiB (98.29%)
used: 99.1 GiB (14.6%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 47.2 C mobo: N/A gpu: radeon temp: 47.0 C
Processes: 186 Uptime: 26m wakeups: 1 Memory: 6.98 GiB
used: 1.55 GiB (22.2%) Init: systemd v: 247 tool: systemctl Compilers:
gcc: 10.2.0 Packages: pacman: 1629 lib: 473 flatpak: 0 Shell: Bash v: 5.1.0
running-in: konsole inxi: 3.3.04
E aqui o log do Wine quando tento lançar o League of Legends:
lutris-wrapper: League of Legends
Running /home/salinger/.local/share/lutris/runners/wine/lutris-lol-5.5-2-x86_64/bin/wine /home/salinger/Games/league-of-legends/drive_c/Riot Games/League of Legends/LeagueClient.exe --locale=en_US
Initial process has started with pid 3597
Start monitoring process.
000000.001| OKAY| Running from cwd ‘C:\Riot Games\League of Legends’.
000000.001| ALWAYS| Application Version:11.9.372.2066 - CL:3722066 - Build Date:Apr 23 2021 - Build Time:10:27:45
000000.002| OKAY| Initial working directory: “C:\Riot Games\League of Legends”
000000.003| OKAY| Current process: “C:\Riot Games\League of Legends\LeagueClient.exe”
000000.003| OKAY| Command line arguments:
–locale=en_US
000000.007| OKAY| Enabling Data API Dradis collection with endpoint: https://ekg.riotgames.com/messages
000000.023| ALWAYS| The following message is prepared to be sent to dradis:
Event Name: riot__rclient__event
common.os_platform: Windows
common.application_name: LeagueClient
common.application_version: 11.9.372.2066
common.cef_version: 74.1.19+gb62bacf+chromium-74.0.3729.157
common.installation_id: aJ2g0w==
common.locale: en_US
common.os_version_major: 10
common.machine_id: 9rNUPvANnU2QovFlgNAnLw==
common.os_edition: Ultimate N, x86
common.os_version_minor:
common.region: BR
common.session_id: 413402ed-edc9-1849-a24d-7dbdfd76cdee
event_name: startup
crash_reporter: crashpad
000000.023| ALWAYS| Queued Dradis event to be sent.
000000.023| ALWAYS| Direct Launch enabled for league_of_legends.live in environment ‘live’ for app path ‘C:\Riot Games\League of Legends\LeagueClient.exe’ and install dir ‘C:\Riot Games\League of Legends’
000000.024| ALWAYS| Found associated Riot Client install (c:/Riot Games/Riot Client/RiotClientServices.exe)
000000.154| OKAY| Launched Riot Client with process 57
000000.154| ALWAYS| Riot Client started. Exiting with the expectation of being restarted (ExitForDirectLaunch).
000005.887| OKAY| EventCollector: 0 events remaining after thread join
000005.887| OKAY| Shut down EventCollector in 863 milliseconds
Initial process has exited (return code: 0)
Caso precisem que seja feito algum teste extra ou algum outro passo é só me falar que faço e posto os resultados aqui.
