Launch feedback on icons
i just installed Arch Mate in a VM and noticed that with the same custom icon pack,when clicking on a panel icon-Firefox for example-the icon/fox bounces out of the icon and fades away.
in my manjaro KDE i just get a spinning wheel.
i think it’s similar to this thread:
but the solution there did not fix it for me.
Enable bouncing and set the time for the animation in System Settings > Launch Feedback …
it is/was already on bouncing.
Disable it, apply, clean .cache, enable it, apply > test again.
what part of .cache should i clean?
rm -rf ~/.cache/*
all of it
i prefer not doing that,but thanks.
You could copy to a backup first, delete to see if issue fixed, and restore if not?
i see mixed opinions about deleting or messing with the .cache;
since it’s just a cosmetic feature(a bouncing icon :man_facepalming:)and nothing major,
I’ll leave it this way,unless i find an easy fix.
Just a quick reminder. Bouncy icons do not work on wayland (yet). Just in case you are running Plasma Wayland session.
i’m not :slight_smile:
Is like washing the t-shirt you are wearing … :+1:
apparently i have that bouncy icon;
it’s visible when i move the cursor away from the panel icon.
the panel icon on the other hand has a spinning wheel.
but that’s not the effect i was looking for;
i made a video of it,it’s probably a Mate feature,
i was wondering how’s it called and if there’s a way to import it?
https://streamable.com/jb5g78
yeah. That’s a MATE feature/effect. I don’t think it exists in Plasma.
