Hey just wanted to inform you guys that the latest batch of updates due to fail due to a conflict
could not satisfy dependencies:
- installing pacman (6.0.2-18) breaks dependency 'pacman-contrib' required by pacui
- if possible, remove pacui and retry
… another variant:
looking up the dependencies of pacui - it does not seem to require pacman-contrib
so removing pacman-contrib would also appear to work
If I try to install pacman-contribs I run into this issue
Preparing...
Resolving dependencies...
Checking inter-conflicts...
Failed to prepare transaction:
- unable to satisfy dependency 'pacman' required by pacman-contrib
- removing pacman breaks dependency 'libalpm.so=13-64' required by libpamac
- removing pacman breaks dependency 'pacman>5' required by yay
Yeah seems like I had to remove pacui and bmenu and would remove packages that relied on it to resolve the issue at least so far, I am downloading the updates now
If you had looked at the Stable Updates thread, then you would have seen that there was no need to remove anything. pacman-contrib is a spin-off from the pacman package, and thus the dependencies have changed. All you needed to do was…
sudo pacman -Syu pacman-contrib
That would have updated your system and installed pacman-contrib all in one go.
While you’re at it, also tend to your .pacnew files, because there’s quite a few with this update. And you should merge them, not blindly copy them over, because then you won’t be able to log in anymore.
Same here when the red Update icon appeared and I ran it. Seems like this is a total system re-install, because when I did this as recommended:
It took a long time, and I’ve captured the Terminal log of it if anyone’s interested. Now I’m going to reboot and hope this PC’s still alive. Hope this gets fixed at some point so the GUI can handle it w/o the CLI method.
Its a regular system update, the only extra being it pointing at that package (so update system while installing X). Not ‘whole system reinstall’ or anything all that different from any update.
Thanks cscs. It took a long time, with many (most) of my apps reinstalling along with a lot of apparently system stuff. Anyway, I came back here mostly to thank everyone and report that the system seems to have rebooted normally, the red update Panel icon went away all by itself too. Me: happy.
Also just to add I hardly read the announcements on the forum that said I was just reporting the issue to help get it resolved and not cause this issue for future users upgrading as users will now have to manually intervene especially new users who might not know about this or the fix you have to manually do or I will have to do for some family members/clients
pacman-contrib was not installed on my system but as recommended by the error message I removed pacui and also its’ dependency bmenu which worked out for me then.
