Hey folks so I recently updated my kernel to 5.12 and while it all seemed fine, my in-built mic suddenly stopped working when I tried to join a meeting, it just won’t detect it and the weird thing was when I tried to test it, it instead plays my laptop’s audio, system sounds, media/music if played etc instead when I tested it on google meet/discord. Basically plays my internal audio from the mic from the looks of it(?).
I tried testing by restarting pulseaudio, etc and it still didn’t work, tried adding a loadmodules line in my pulse conf and that did not work either.
Would appreciate all the help,
Thanks!
Here’s my output for inxi -Fzxxxa
System: Kernel: 5.12.9-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64 root=UUID=2f20948b-f9f8-4464-ad3f-ec780763f84e rw quiet apparmor=1
security=apparmor resume=UUID=7f178eb3-6815-4d3c-a7bc-6970e749da5f udev.log_priority=3 amdgpu.runpm=0
acpi_backlight=vendor
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Machine: Type: Laptop System: Dell product: G5 5505 v: 1.4.4 serial: <filter> Chassis: type: 10 v: 1.4.4 serial: <filter>
Mobo: Dell model: 0F9F1J v: A00 serial: <filter> UEFI: Dell v: 1.4.4 date: 09/30/2020
Battery: ID-1: BAT0 charge: 19.6 Wh (43.9%) condition: 44.6/51.0 Wh (87.4%) volts: 12.0 min: 11.4
model: SMP-ATL4.49 DELL PN1VN06 type: Li-poly serial: <filter> status: Charging
CPU: Info: 6-Core model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64 type: MT MCP arch: Zen 2 family: 17 (23)
model-id: 60 (96) stepping: 1 microcode: 8600102 cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 71890
Speed: 1397 MHz min/max: 1400/3000 MHz boost: enabled Core speeds (MHz): 1: 1397 2: 1538 3: 1397 4: 1397 5: 1489
6: 1397 7: 1401 8: 1571 9: 1397 10: 1397 11: 1397 12: 1397
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] vendor: Dell
driver: amdgpu v: kernel bus-ID: 03:00.0 chip-ID: 1002:731f class-ID: 0380
Device-2: Advanced Micro Devices [AMD/ATI] Renoir vendor: Dell driver: amdgpu v: kernel bus-ID: 07:00.0
chip-ID: 1002:1636 class-ID: 0300
Device-3: Sunplus Innovation Integrated_Webcam_HD type: USB driver: uvcvideo bus-ID: 3-2:2 chip-ID: 1bcf:2b99
class-ID: 0e02
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: amdgpu,ati unloaded: modesetting,radeon
alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 120 dpi: 142 size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.12.9-1-MANJARO LLVM 12.0.0) v: 4.6 Mesa 21.1.2 direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 HDMI Audio vendor: Dell driver: snd_hda_intel v: kernel
bus-ID: 03:00.1 chip-ID: 1002:ab38 class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 07:00.1
chip-ID: 1002:1637 class-ID: 0403
Device-3: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Dell
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x bus-ID: 07:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-4: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Dell driver: snd_hda_intel v: kernel
bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.12.9-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.30 running: no
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Dell driver: r8169 v: kernel port: 2000
bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: down mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 vendor: Rivet Networks driver: iwlwifi v: kernel port: 2000 bus-ID: 06:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlp6s0 state: up mac: <filter>
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-3.1:4 chip-ID: 8087:0029 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running rfk-block: hardware: no software: yes
address: see --recommends
Drives: Local Storage: total: 476.94 GiB used: 15.3 GiB (3.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: IM2P33F3 NVMe 512GB size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter> rev: 92009161 scheme: GPT
Partition: ID-1: / raw-size: 200.1 GiB size: 195.9 GiB (97.90%) used: 15.28 GiB (7.8%) fs: ext4 dev: /dev/nvme0n1p6
maj-min: 259:6
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 25.2 MiB (26.3%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1
Swap: Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p5 maj-min: 259:5
Sensors: System Temperatures: cpu: 79.9 C mobo: 43.0 C
Fan Speeds (RPM): cpu: 0
GPU: device: amdgpu temp: 59.0 C device: amdgpu temp: 58.0 C mem: 58.0 C fan: 65488 watts: 10.00
Info: Processes: 323 Uptime: N/A wakeups: 126 Memory: 7.21 GiB used: 1.1 GiB (15.3%) Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.0 Packages: pacman: 1269 lib: 340 flatpak: 0 Shell: Bash v: 5.1.8
running-in: konsole inxi: 3.3.04
