Hello there,
I run Manjaro (KDE, Kernel 5.12), on a ThinkPad T14 (AMD).
After an update yesterday my internal Microphone doesn’t get recognized by the system (Systemsettings or any program). The speakers still work fine.
Since I am pretty new to linux, I am not sure what the problem exactly? (udev, pulseaudio, kernel)
Pulseaudio, kernel and some systemd stuff got update.
I tried to boot an older kernel without success.
If you need some further information let me know.
Would highly appreciate if someone could help me.
Thank you very much!
uname -r
5.12.9-1-MANJARO
ps ax | grep pulse
1748 ? S<sl 0:13 /usr/bin/pulseaudio --daemonize=no --log-target=journal
1945 ? Sl 0:00 /usr/lib/pulse/gsettings-helper
6515 pts/1 S+ 0:00 grep --color=auto --exclude-dir=.bzr --exclude-dir=CVS --exclude-dir=.git --exclude-dir=.hg --exclude-dir=.svn --exclude-dir=.idea --exclude-dir=.tox pulse
pacmd list-sources
1 source(s) available.
- index: 0
driver: <module-alsa-card.c>
flags: DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: RUNNING
suspend cause: (none)
priority: 1030
volume: front-left: 65536 / 100% / 0,00 dB, front-right: 65536 / 100% / 0,00 dB
balance 0,00
base volume: 65536 / 100% / 0,00 dB
volume steps: 65537
muted: no
current latency: 0,00 ms
max rewind: 6 KiB
sample spec: s16le 2ch 44100Hz
channel map: front-left,front-right
Stereo
used by: 1
linked by: 1
configured latency: 40,00 ms; range is 0,50 … 1999,82 ms
monitor_of: 0
card: 1 <alsa_card.pci-0000_07_00.6>
module: 8
properties:
device.description = “Monitor of Family 17h (Models 10h-1fh) HD Audio Controller Analog Stereo”
device.class = “monitor”
alsa.card = “1”
alsa.card_name = “HD-Audio Generic”
alsa.long_card_name = “HD-Audio Generic at 0xfd3c0000 irq 109”
alsa.driver_name = “snd_hda_intel”
device.bus_path = “pci-0000:07:00.6”
sysfs.path = “/devices/pci0000:00/0000:00:08.1/0000:07:00.6/sound/card1”
device.bus = “pci”
device.vendor.id = “1022”
device.vendor.name = “Advanced Micro Devices, Inc. [AMD]”
device.product.id = “15e3”
device.product.name = “Family 17h (Models 10h-1fh) HD Audio Controller”
device.string = “1”
module-udev-detect.discovered = “1”
device.icon_name = “audio-card-pci”
tail -n1000 /var/log/pacman.log | grep pulse
[2021-06-15T09:39:04+0200] [ALPM] removed lib32-libcanberra-pulse (0.30+2+gc0620e4-3)
[2021-06-15T09:39:04+0200] [ALPM] removed libcanberra-pulse (0.30+2+gc0620e4-3)
[2021-06-15T09:39:07+0200] [ALPM-SCRIPTLET] WARNING: Non-backwards compatible changes to ALSA require restarting of audio engines (e.g. pulseaudio or pipewire) using it.
[2021-06-15T09:39:54+0200] [ALPM] upgraded pulseaudio-alsa (1:1.2.2-2 → 1:1.2.5-2)
[2021-06-16T08:34:50+0200] [ALPM] upgraded systemd-libs (248.3-2 → 248.3-3)
[2021-06-16T08:34:51+0200] [ALPM] upgraded systemd (248.3-2 → 248.3-3)
[2021-06-16T08:34:52+0200] [ALPM] upgraded systemd-sysvcompat (248.3-2 → 248.3-3)
[2021-06-16T08:34:52+0200] [ALPM] running ‘20-systemd-sysusers.hook’…
[2021-06-16T08:34:52+0200] [ALPM] running ‘30-systemd-catalog.hook’…
[2021-06-16T08:34:52+0200] [ALPM] running ‘30-systemd-daemon-reload.hook’…
[2021-06-16T08:34:53+0200] [ALPM] running ‘30-systemd-hwdb.hook’…
[2021-06-16T08:34:53+0200] [ALPM] running ‘30-systemd-sysctl.hook’…
[2021-06-16T08:34:53+0200] [ALPM] running ‘30-systemd-tmpfiles.hook’…
[2021-06-16T08:34:53+0200] [ALPM] running ‘30-systemd-udev-reload.hook’…
[2021-06-16T08:34:53+0200] [ALPM] running ‘30-systemd-update.hook’…
[2021-06-16T12:50:47+0200] [ALPM] running ‘30-systemd-daemon-reload.hook’…
[2021-06-16T12:50:48+0200] [ALPM] running ‘30-systemd-udev-reload.hook’…
[2021-06-16T12:50:48+0200] [ALPM] running ‘30-systemd-update.hook’…
[2021-06-16T13:07:04+0200] [ALPM] running ‘30-systemd-update.hook’…
[2021-06-16T13:35:47+0200] [PACMAN] Running ‘pacman -S systemd’
[2021-06-16T13:36:27+0200] [PACMAN] Running ‘pacman -S systemd-248.3-2’
[2021-06-16T13:36:47+0200] [PACMAN] Running ‘pacman -S systemd-248.3-1’
[2021-06-16T13:36:50+0200] [PACMAN] Running ‘pacman -S systemd-248.3’
[2021-06-16T13:38:32+0200] [PACMAN] Running ‘pacman -S systemd-248.3-2’
[2021-06-16T13:38:38+0200] [PACMAN] Running ‘pacman -S systemd’
[2021-06-15T09:39:04+0200] [ALPM] upgraded util-linux-libs (2.36.2-1 → 2.37-3)
[2021-06-15T09:39:06+0200] [ALPM] upgraded util-linux (2.36.2-1 → 2.37-3)
[2021-06-15T09:39:11+0200] [ALPM] upgraded lib32-util-linux (2.36.2-1 → 2.37-1)
[2021-06-15T09:39:17+0200] [ALPM] upgraded linux510 (5.10.41-1 → 5.10.42-1)
[2021-06-15T09:39:23+0200] [ALPM] upgraded linux510-headers (5.10.41-1 → 5.10.42-1)
[2021-06-15T09:39:23+0200] [ALPM] upgraded linux510-virtualbox-host-modules (6.1.22-11 → 6.1.22-12)
[2021-06-15T09:39:36+0200] [ALPM] upgraded linux512 (5.12.8-1 → 5.12.9-1)
[2021-06-15T09:39:42+0200] [ALPM] upgraded linux512-headers (5.12.8-1 → 5.12.9-1)
[2021-06-15T09:39:42+0200] [ALPM] upgraded linux512-virtualbox-host-modules (6.1.22-12 → 6.1.22-13)
