Laptop won't boot
I can’t boot into my laptop
I can’t event boot Grub, but by booting on the grub of my old manjaro USB I was able to boot in my laptop manjaro with kernel 5.15 (didn’t tried yet 5.19)
Okay I just launch my ssd’s kernel 5.19.4 from my usb stick’s grub and it works well.
The problem is entirely with grub.
Hello,
Are you on the unstable branch ?
Indeed, thou mine stopped to boot just now, 10 hours ago it was just as usual.
Now my laptop tries to boot but end up going straight to the bios.
Well I just did
sudo pacman-mirrors --fasttrack 5 && sudo pacman -Syyuu
Which reverted from r322 to r261 and it’s working again as usual.
Yeah, Arch are aware of it and hopefully there will be a more general fix soon.
