I have setup my Laptop so, that it will never go to sleep, when it is connected to power. This is fine so far. But sometimes i have to disconnect it from power and use it over standard battery. In this case, the monitor seems to shut off after a while. But i cant it bring back online. I have tried to press some keys on the keyboard, press the power button, functions keys and more, but the monitor will not come back. Keyboard keys are illuminated.
Any idea what’s going on, or where i can have a look?
Kernel: 5.15.28-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=8ac9a376-24de-45e0-866b-20343fa36fee rw quiet splash
udev.log_priority=3 acpi_osi=! "acpi_osi=Windows 2018"
Desktop: GNOME v: 41.4 tk: GTK v: 3.24.33 wm: gnome-shell dm: GDM v: 41.3
Type: Laptop System: Micro-Star product: GP72 7RD v: REV:1.0
Mobo: Micro-Star model: MS-1799 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E1799IMS.324 date: 03/23/2018
ID-1: BAT1 charge: 33.5 Wh (98.0%) condition: 34.2/42.4 Wh (80.6%)
volts: 12.2 min: 10.8 model: MSI BIF0_9 type: Li-ion serial: N/A status: N/A
RAM: total: 15.55 GiB used: 2.43 GiB (15.6%)
RAM Report:
Info: model: Intel Core i5-7300HQ bits: 64 type: MCP arch: Kaby Lake
family: 6 model-id: 0x9E (158) stepping: 9 microcode: 0xEC
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 1285 high: 1366 min/max: 800/3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 1281 2: 1366 3: 1296
4: 1200 bogomips: 20004
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
STIBP: disabled, RSB filling
Device-1: Intel HD Graphics 630 vendor: Micro-Star MSI driver: i915
v: kernel ports: active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:591b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Micro-Star MSI
driver: nvidia v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
chip-ID: 10de:1c8d class-ID: 0302
Display: x11 server: X.Org v: 1.21.1.3 compositor: gnome-shell driver: X:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa gpu: i915
display-ID: :1 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1735 built: 2014 res: 1920x1080
hz: 60 dpi: 128 gamma: 1.2 size: 382x215mm (15.04x8.46") diag: 438mm (17.3")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2) v: 4.6 Mesa 21.3.7
direct render: Yes
Device-1: Intel CM238 HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a171 class-ID: 0403
Sound Server-1: ALSA v: k5.15.28-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.48 running: yes
Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0
chip-ID: 8086:24fb class-ID: 0280
Device-2: Qualcomm Atheros Killer E2500 Gigabit Ethernet
vendor: Micro-Star MSI driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 1969:e0b1 class-ID: 0200
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-10:3 chip-ID: 8087:0aa7 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 1.94 TiB used: 1.21 TiB (62.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: RBUSNS8180S3128GI1
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 60B9 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 QVO 2TB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 1B6Q scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GUD0N rev: 1.00
dev-links: cdrom
ID-1: / raw-size: 48.83 GiB size: 47.76 GiB (97.81%) used: 44.19 GiB (92.5%)
fs: ext4 dev: /dev/sdb3 maj-min: 8:19 label: N/A
uuid: 8ac9a376-24de-45e0-866b-20343fa36fee
ID-2: /boot/efi raw-size: 300 MiB size: 296 MiB (98.67%)
used: 50.9 MiB (17.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: SYSTEM
uuid: 2271-30CB
ID-3: /mnt/2E44E50D44E4D89B raw-size: 1.58 TiB size: 1.58 TiB (100.00%)
used: 964.35 GiB (59.6%) fs: ntfs dev: /dev/sdb2 maj-min: 8:18 label: Volume
uuid: 2E44E50D44E4D89B
ID-4: /mnt/AE5871BE5871863D raw-size: 117.94 GiB
size: 117.94 GiB (100.00%) used: 96.76 GiB (82.0%) fs: ntfs dev: /dev/sda3
maj-min: 8:3 label: Windows uuid: AE5871BE5871863D
ID-1: /dev/sda2 maj-min: 8:2 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sda4 maj-min: 8:4 size: 900 MiB fs: ntfs label: WinRE tools
uuid: DC5672D25672ACC0
ID-3: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-7:6 info: MSI steel series rgb keyboard type: HID
driver: gt683r_led,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s power: 2mA
chip-ID: 1770:ff00 class-ID: 0300 serial: <filter>
Device-2: 1-10:3 info: Intel Wireless-AC 3168 Bluetooth type: Bluetooth
Device-3: 1-12:4 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 49.0 C pch: 54.0 C mobo: 27.8 C
Processes: 230 Uptime: 6h 39m wakeups: 3 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1703
pacman: 1697 lib: 479 flatpak: 6 Shell: Ba
sh v: 5.1.16
running-in: gnome-terminal inxi: 3.3.14
