I have the same issue. It’s not mouse or smth like that, I turn off the mouse.
I noticed that it wakes up when it charges (I have laptop), f.e. if I suspend it and plug power cable off, it wont wake up and eventually will shutdown after couple of hours.
But if I keep my power cable in, it can wake up after 15 min or 20 min of being suspended, every time it’s different.
Any ideas how to fix it? Do you need some hardware info with inxi?
Thanks
Ben
2 February 2024 00:03
2
Not sure about this, but possibly it’s waking up to hibernate…
systemd-analyze cat-config systemd/sleep.conf
https://wiki.archlinux.org/title/Power_management#Suspend_and_hibernate
Is hibernate enabled?
Mine sleeps all night -
[Sleep]
#AllowSuspend=yes
#AllowHibernation=yes
#AllowSuspendThenHibernate=yes
#AllowHybridSleep=yes
#SuspendState=mem standby freeze
#HibernateMode=platform shutdown
#HibernateDelaySec=
#SuspendEstimationSec=60min
You really shouldn’t revive another members old thread - please create a new topic with a link to the old thread.
It is what is referred to as necro bumping and should really be avoided as everyone in thread get’s notified - possibly annoying.
Aragorn
Closed
2 February 2024 17:11
6
Starting duplicate threads is antisocial and against the forum rules. You already have a thread about this issue.
Hello.
My laptop wakes up from suspended state if I keep power cable plugged-in after 15-40 min, it’s different every time. If I plug-off the power cable, it won’t wake up and after several hours eventually will shutdown.
Any ideas how to fix it? Do you need some hardware info?
Thanks
update: info from inxi
Kernel: 6.6.10-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root…
