Hello.
My laptop wakes up from suspended state if I keep power cable plugged-in after 15-40 min, it’s different every time. If I plug-off the power cable, it won’t wake up and after several hours eventually will shutdown.
Any ideas how to fix it? Do you need some hardware info?
Thanks
update: info from inxi
Kernel: 6.6.10-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=195bac60-114b-4799-9a62-2277a13dc0f4 rw quiet
cryptdevice=UUID=29976e95-b601-46ce-ad7e-4ff37cfeadc7:luks-29976e95-b601-46ce-ad7e-4ff37cfeadc7
root=/dev/mapper/luks-29976e95-b601-46ce-ad7e-4ff37cfeadc7
udev.log_priority=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: HP product: HP ProBook 455 G8 Notebook PC v: N/A
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 8864 v: KBC Version 41.2C.00 serial: <filter> UEFI: HP
v: T78 Ver. 01.14.00 date: 06/21/2023
ID-1: BAT0 charge: 34.7 Wh (96.4%) condition: 36.0/45.0 Wh (80.0%)
volts: 12.4 min: 11.4 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: not charging cycles: 128
Device-1: hidpp_battery_0 model: Logitech Anywhere MX serial: <filter>
charge: 10% rechargeable: yes status: discharging
System RAM: total: 32 GiB available: 30.67 GiB used: 4.52 GiB (14.8%)
Device-1: Bottom-Slot 1(left) type: DDR4 detail: synchronous unbuffered
(unregistered) size: 16 GiB speed: 3200 MT/s volts: curr: 1.2 min: 1.2
max: 1.2 width (bits): data: 64 total: 64 manufacturer: Samsung
part-no: M471A2K43DB1-CWE serial: <filter>
Device-2: Bottom-Slot 2(right) type: DDR4 detail: synchronous unbuffered
Info: model: AMD Ryzen 7 5800U with Radeon Graphics socket: FP6 bits: 64
type: MT MCP arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000D
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 1139 high: 2812 min/max: 400/4507 base/boost: 1900/4450
scaling: driver: amd-pstate-epp governor: powersave volts: 1.2 V
ext-clock: 100 MHz cores: 1: 1924 2: 400 3: 400 4: 2411 5: 400 6: 400
7: 1508 8: 2812 9: 400 10: 400 11: 400 12: 2266 13: 2277 14: 400 15: 1430
16: 400 bogomips: 60718
cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
vendor: Hewlett-Packard driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300
temp: 38.0 C
Device-2: Luxvisions Innotech HP HD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3 chip-ID: 30c9:0010
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.10 compositor: xfwm v: 4.18.0 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
gpu: amdgpu display-ID: :0.0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: AU Optronics 0xc48a built: 2019
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.3.3-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (radeonsi renoir
LLVM 16.0.6 DRM 3.54 6.6.10-1-MANJARO) device-ID: 1002:1638 memory: 500 MiB
unified: no
API: Vulkan v: 1.3.274 layers: N/A device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 23.3.3-manjaro1.1
device-ID: 1002:1638 surfaces: xcb,xlib
Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 05:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3
class-ID: 0403
API: ALSA v: k6.6.10-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.0 status: off tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active (root, process) with:
tools: pacat,pactl,pavucontrol
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: down mac: <filter>
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.0
chip-ID: 10ec:c822 class-ID: 0280
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:2 chip-ID: 0bda:b00c
Device-1: luks-29976e95-b601-46ce-ad7e-4ff37cfeadc7 maj-min: 254:0
type: LUKS dm: dm-0 size: 200 GiB
Components:
p-1: nvme0n1p4 maj-min: 259:4 size: 200 GiB
Local Storage: total: 476.94 GiB used: 81.52 GiB (17.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLQ512HALU-000H1
lanes: 4 tech: SSD serial: <filter> fw-rev: HPS4NFXV temp: 32.9 C
scheme: GPT
ID-1: / raw-size: 200 GiB size: 195.8 GiB (97.90%) used: 81.46 GiB (41.6%)
fs: ext4 block-size: 4096 B dev: /dev/dm-0 maj-min: 254:0
mapped: luks-29976e95-b601-46ce-ad7e-4ff37cfeadc7 label: N/A
uuid: 195bac60-114b-4799-9a62-2277a13dc0f4
used: 64.5 MiB (67.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: N/A uuid: 5C61-D941
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: N/A label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 276.33 GiB fs: ntfs label: N/A
uuid: 2684F02484EFF3E9
ID-3: /dev/nvme0n1p5 maj-min: 259:5 size: 509 MiB fs: ntfs label: N/A
uuid: D83808AA38088A28
Device-1: 1-3:2 info: Realtek Bluetooth Radio type: bluetooth driver: btusb
interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 500mA chip-ID: 0bda:b00c class-ID: e001 serial: <filter>
Device-2: 1-4:3 info: Elan Micro ELAN:ARM-M4 type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 100mA chip-ID: 04f3:0c5e class-ID: 0000
Device-1: 3-2:2 info: Logitech Unifying Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
chip-ID: 046d:c52b class-ID: 0300
Device-2: 3-4:3 info: Luxvisions Innotech HP HD Camera type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 30c9:0010 class-ID: 0e02
System Temperatures: cpu: 48.8 C mobo: N/A gpu: amdgpu temp: 41.0 C
Fan Speeds (rpm): N/A
Processes: 443 Uptime: 3m wakeups: 0 Init: systemd v: 255 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: pm: pacman
pkgs: 1205 libs: 364 tools: pamac,yay Shell: Sudo (sudo) v: 1.9.15p5
default: Bash v: 5.2.21 running-in: tilda inxi: 3.3.31
I was able to catch wake up event.
Here is journalctl
At 22:15:32 it goes into suspend mode
At 22:35:48 it wakes up
Apr 30 22:15:32 simon systemd-sleep[1837081]: Performing sleep operation 'suspend'...
Apr 30 22:15:32 simon kernel: PM: suspend entry (s2idle)
Apr 30 22:35:48 simon kernel: Filesystems sync: 0.039 seconds
Apr 30 22:35:48 simon kernel: Freezing user space processes
Apr 30 22:35:48 simon kernel: Freezing user space processes completed (elapsed 0.003 seconds)
Apr 30 22:35:48 simon kernel: OOM killer disabled.
Apr 30 22:35:48 simon kernel: Freezing remaining freezable tasks
Apr 30 22:35:48 simon kernel: Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
Apr 30 22:35:48 simon kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Apr 30 22:35:48 simon kernel: ACPI: EC: interrupt blocked
Apr 30 22:35:48 simon kernel: ACPI: EC: interrupt unblocked
Apr 30 22:35:48 simon kernel: [drm] PCIE GART of 1024M enabled.
Apr 30 22:35:48 simon kernel: [drm] PTB located at 0x000000F41FC00000
Apr 30 22:35:48 simon kernel: amdgpu 0000:05:00.0: amdgpu: SMU is resuming...
Apr 30 22:35:48 simon kernel: amdgpu 0000:05:00.0: amdgpu: dpm has been disabled
Apr 30 22:35:48 simon kernel: nvme nvme0: Shutdown timeout set to 8 seconds
Apr 30 22:35:48 simon kernel: amdgpu 0000:05:00.0: amdgpu: SMU is resumed successfully!
Apr 30 22:35:48 simon kernel: nvme nvme0: 12/0/0 default/read/poll queues
Apr 30 22:35:48 simon kernel: usb 1-3: reset full-speed USB device number 3 using xhci_hcd
Apr 30 22:35:48 simon kernel: [drm] VCN decode and encode initialized successfully(under DPG Mode).
Apr 30 22:35:48 simon kernel: [drm] JPEG decode initialized successfully.
Apr 30 22:35:48 simon kernel: amdgpu 0000:05:00.0: amdgpu: ring gfx uses VM inv eng 0 on hub 0
Apr 30 22:35:48 simon kernel: amdgpu 0000:05:00.0: amdgpu: ring gfx_low uses VM inv eng 1 on hub 0
Apr 30 22:35:48 simon kernel: amdgpu 0000:05:00.0: amdgpu: ring gfx_high uses VM inv eng 4 on hub 0
Apr 30 22:35:48 simon kernel: amdgpu 0000:05:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 5 on hub 0
Apr 30 22:35:48 simon kernel: amdgpu 0000:05:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 6 on hub 0
Apr 30 22:35:48 simon kernel: amdgpu 0000:05:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 7 on hub 0
Apr 30 22:35:48 simon kernel: amdgpu 0000:05:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 8 on hub 0
Apr 30 22:35:48 simon kernel: amdgpu 0000:05:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 9 on hub 0
Apr 30 22:35:48 simon kernel: amdgpu 0000:05:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 10 on hub 0
Apr 30 22:35:48 simon kernel: amdgpu 0000:05:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 11 on hub 0
Apr 30 22:35:48 simon kernel: amdgpu 0000:05:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 12 on hub 0
Apr 30 22:35:48 simon kernel: amdgpu 0000:05:00.0: amdgpu: ring kiq_0.2.1.0 uses VM inv eng 13 on hub 0
Apr 30 22:35:48 simon kernel: amdgpu 0000:05:00.0: amdgpu: ring sdma0 uses VM inv eng 0 on hub 8
Apr 30 22:35:48 simon kernel: amdgpu 0000:05:00.0: amdgpu: ring vcn_dec uses VM inv eng 1 on hub 8
Apr 30 22:35:48 simon kernel: amdgpu 0000:05:00.0: amdgpu: ring vcn_enc0 uses VM inv eng 4 on hub 8
Apr 30 22:35:48 simon kernel: amdgpu 0000:05:00.0: amdgpu: ring vcn_enc1 uses VM inv eng 5 on hub 8
Apr 30 22:35:48 simon kernel: amdgpu 0000:05:00.0: amdgpu: ring jpeg_dec uses VM inv eng 6 on hub 8
Apr 30 22:35:48 simon kernel: OOM killer enabled.
Apr 30 22:35:48 simon bluetoothd[953]: Endpoint unregistered: sender=:1.54 path=/MediaEndpoint/A2DPSource/ldac_hq
Apr 30 22:35:48 simon pulseaudio[1532]: org.bluez.BatteryProviderManager1.UnregisterBatteryProvider() Failed: org.freedesktop.DBus.Error.UnknownObject:Method "UnregisterBatteryProvider">
Apr 30 22:35:48 simon bluetoothd[953]: Endpoint unregistered: sender=:1.54 path=/MediaEndpoint/A2DPSource/ldac_sq
Apr 30 22:35:48 simon bluetoothd[953]: Endpoint unregistered: sender=:1.54 path=/MediaEndpoint/A2DPSource/ldac_mq
Apr 30 22:35:48 simon bluetoothd[953]: Endpoint unregistered: sender=:1.54 path=/MediaEndpoint/A2DPSink/aptx_hd
Apr 30 22:35:48 simon bluetoothd[953]: Endpoint unregistered: sender=:1.54 path=/MediaEndpoint/A2DPSource/aptx_hd
Apr 30 22:35:48 simon bluetoothd[953]: Endpoint unregistered: sender=:1.54 path=/MediaEndpoint/A2DPSink/sbc
Apr 30 22:35:48 simon bluetoothd[953]: Endpoint unregistered: sender=:1.54 path=/MediaEndpoint/A2DPSource/sbc
Apr 30 22:35:48 simon bluetoothd[953]: Endpoint unregistered: sender=:1.54 path=/MediaEndpoint/A2DPSink/sbc_xq_453
Apr 30 22:35:48 simon bluetoothd[953]: Endpoint unregistered: sender=:1.54 path=/MediaEndpoint/A2DPSource/sbc_xq_453
Apr 30 22:35:48 simon bluetoothd[953]: Endpoint unregistered: sender=:1.54 path=/MediaEndpoint/A2DPSink/sbc_xq_512
Apr 30 22:35:48 simon bluetoothd[953]: Endpoint unregistered: sender=:1.54 path=/MediaEndpoint/A2DPSource/sbc_xq_512
Apr 30 22:35:48 simon bluetoothd[953]: Endpoint unregistered: sender=:1.54 path=/MediaEndpoint/A2DPSink/sbc_xq_552
Apr 30 22:35:48 simon bluetoothd[953]: Endpoint unregistered: sender=:1.54 path=/MediaEndpoint/A2DPSource/sbc_xq_552
Apr 30 22:35:48 simon bluetoothd[953]: Endpoint unregistered: sender=:1.54 path=/MediaEndpoint/A2DPSink/faststream
Apr 30 22:35:48 simon bluetoothd[953]: Endpoint unregistered: sender=:1.54 path=/MediaEndpoint/A2DPSource/faststream
Apr 30 22:35:48 simon bluetoothd[953]: Battery Provider Manager destroyed
Apr 30 22:35:48 simon kernel: Restarting tasks ...
Apr 30 22:35:48 simon kernel: Bluetooth: hci0: RTL: examining hci_ver=0a hci_rev=000c lmp_ver=0a lmp_subver=8822
Apr 30 22:35:48 simon kernel: done.
Apr 30 22:35:48 simon kernel: random: crng reseeded on system resumption
Apr 30 22:35:48 simon kernel: Bluetooth: hci0: RTL: rom_version status=0 version=3
Apr 30 22:35:48 simon kernel: Bluetooth: hci0: RTL: loading rtl_bt/rtl8822cu_fw.bin
Apr 30 22:35:48 simon kernel: Bluetooth: hci0: RTL: loading rtl_bt/rtl8822cu_config.bin
Apr 30 22:35:48 simon kernel: Bluetooth: hci0: RTL: cfg_sz 6, total sz 35990
Apr 30 22:35:48 simon systemd-sleep[1837081]: System returned from sleep operation 'suspend'.
Apr 30 22:35:48 simon kernel: PM: suspend exit
Apr 30 22:35:48 simon systemd[1425]: Stopped target Bluetooth.
Apr 30 22:35:48 simon systemd[1]: Stopped target Bluetooth Support.
Apr 30 22:35:48 simon systemd[1425]: Reached target Bluetooth.
Apr 30 22:35:49 simon systemd[1]: systemd-suspend.service: Deactivated successfully.
Apr 30 22:35:49 simon systemd[1]: Finished System Suspend.
Apr 30 22:35:49 simon systemd[1]: Stopped target Sleep.
Apr 30 22:35:49 simon systemd[1]: Reached target Suspend.
Apr 30 22:35:49 simon systemd-logind[956]: Operation 'suspend' finished.
Apr 30 22:35:49 simon systemd[1]: Stopped target Suspend.
Apr 30 22:35:49 simon ModemManager[1007]: <msg> [sleep-monitor-systemd] system is resuming
Apr 30 22:35:49 simon NetworkManager[949]: <info> [1714505749.1511] manager: sleep: wake requested (sleeping: yes enabled: yes)
Apr 30 22:35:49 simon NetworkManager[949]: <info> [1714505749.1512] device (enp1s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Apr 30 22:35:49 simon kernel: Generic FE-GE Realtek PHY r8169-0-100:00: attached PHY driver (mii_bus:phy_addr=r8169-0-100:00, irq=MAC)
Apr 30 22:35:49 simon kernel: Bluetooth: hci0: RTL: fw version 0x0cc6d2e3
Apr 30 22:35:49 simon kernel: Bluetooth: hci0: AOSP extensions version v1.00
Apr 30 22:35:49 simon kernel: Bluetooth: hci0: AOSP quality report is supported
Apr 30 22:35:49 simon bluetoothd[953]: src/adapter.c:reset_adv_monitors_complete() Failed to reset Adv Monitors: Failed (0x03)
Apr 30 22:35:49 simon bluetoothd[953]: Battery Provider Manager created
Apr 30 22:35:49 simon bluetoothd[953]: Failed to clear UUIDs: Failed (0x03)
Apr 30 22:35:49 simon bluetoothd[953]: Failed to add UUID: Failed (0x03)
Apr 30 22:35:49 simon kernel: Bluetooth: MGMT ver 1.22
