My laptop’s (Lenovo Legion Y520) screen backlight brightness adjustment doesn’t work with kernel 5.9.10-1. It’s fixed at 100% all the time. Slider moves but brightness doesn’t change.
Tried echo 500 > /sys/devices/pci0000:00/0000:00:02.0/drm/card1/card1-eDP-1/intel_backlight/brightness
but it only makes the brightness slider change.Not the actual brightness.
No issues with LTS kernel or 5.8. But I game on this machine and having fsync makes a difference for me. So LTS kernel is not something I prefer. 5.8 is fine and I use it at the moment but it’s EOL now and I don’t want to spend a lot of time on it.
While I was looking around I found that on LTS and 5.8 max_brightness value is set to 7500 and brightness works as expected. But only in 5.9 max_brightness is 1023 and it doesn’t work.
I’m not sure if it’s the right place to open this thread but I wanted to report this issue somehow. And if there is a solution other then waiting for a kernel update, I would be appreciated if you let me know.
My inxi -Fxxz
output:
System: Kernel: 5.9.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: GNOME 3.38.1 tk: GTK 3.24.23
wm: gnome-shell dm: GDM Distro: Manjaro Linux
Machine: Type: Laptop System: LENOVO product: 80WK v: Lenovo Y520-15IKBN serial: <filter> Chassis: type: 10
Mobo: LENOVO model: LNVNB161216 v: SDK0J40688 WIN serial: <filter> UEFI: LENOVO v: 4KCN45WW date: 01/11/2019
Battery: ID-1: BAT0 charge: 38.7 Wh condition: 38.7/45.0 Wh (86%) volts: 12.8/11.5 model: SMP L16M3P24 serial: <filter>
status: Full
CPU: Info: Quad Core model: Intel Core i7-7700HQ bits: 64 type: MT MCP arch: Kaby Lake rev: 9 L2 cache: 6144 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 44817
Speed: 2800 MHz min/max: 800/2800 MHz Core speeds (MHz): 1: 2800 2: 2800 3: 2800 4: 2800 5: 2800 6: 2800 7: 2800
8: 2800
Graphics: Device-1: Intel HD Graphics 630 vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:591b
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: Lenovo driver: nvidia v: 455.45.01 bus ID: 01:00.0
chip ID: 10de:1c8c
Device-3: Acer EasyCamera type: USB driver: uvcvideo bus ID: 1-6:4 chip ID: 5986:06b0
Display: x11 server: X.org 1.20.9 compositor: gnome-shell driver: modesetting,nvidia
alternate: fbdev,intel,nouveau,nv,vesa resolution: <xdpyinfo missing>
OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2) v: 4.6 Mesa 20.2.2 direct render: Yes
Audio: Device-1: Intel CM238 HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:a171
Sound Server: ALSA v: k5.9.10-1-MANJARO
Network: Device-1: Intel Dual Band Wireless-AC 3165 Plus Bluetooth driver: iwlwifi v: kernel port: 4000 bus ID: 03:00.0
chip ID: 8086:3166
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169 v: kernel port: 3000
bus ID: 04:00.0 chip ID: 10ec:8168
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives: Local Storage: total: 2.05 TiB used: 1.42 TiB (69.4%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLW256HEHP-000L2 size: 238.47 GiB speed: 31.6 Gb/s lanes: 4
serial: <filter>
ID-2: /dev/sda vendor: Seagate model: ST2000LM007-1R8174 size: 1.82 TiB speed: 6.0 Gb/s serial: <filter>
Partition: ID-1: / size: 116.18 GiB used: 84.07 GiB (72.4%) fs: ext4 dev: /dev/nvme0n1p7
Swap: ID-1: swap-1 type: partition size: 2.00 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p6
Sensors: System Temperatures: cpu: 40.0 C mobo: N/A
Info: Processes: 256 Uptime: 26m Memory: 15.53 GiB used: 1.87 GiB (12.0%) Init: systemd v: 246 Compilers: gcc: 10.2.0
alt: 9 clang: 11.0.0 Packages: 1753 pacman: 1719 flatpak: 31 snap: 3 Shell: Bash v: 5.0.18
running in: gnome-terminal inxi: 3.1.08
