I bought a laptop but my browser and my laptop screen keeps on blacking out and the people who sold me on Lenovo Concept Store Festival Mall & PC Express & Joneco didn’t fix the problem. Is it the laptop or an OS problem? Coz Im not getting a good resolution from their CS people
Hi @udinov, and welcome!
I hate to break it to you, but it does sounds like a hardware issue. To be safe check for errors. In the terminal, run:
journalctl --priority=warning..err
The --priority=
argument will limit the output to only be warnings and errors.
Also, please provide the full output of:
Tip:
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
For more information, please see:
Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C
. For example:
LC_ALL=C bluetoothctl
Do you have a monitor you could connect? That might help to see if it’s an issue with the laptop display (usually the cable which connects the display to the motherboard).
Assuming - the system is Lenovo - you should check lenovo.com/support
If you would like further interaction with members of this forum - please provide - info as requested as a bare minimum
inxi -Fxxxc0 | curl -F 'f:1=<-' ix.io
The response of the command will be a link - please provide it for reference - inside a codefence
Sample link
``` http://ix.io/blob ```
It is most likely a configuration issue - but no one can comment on such a broad question - completely impossible.
ehmmm… i dont know what and how to do what ur saying…
I think I gave pretty clear instructions, and you are the first person to not know, so I don’t think it’s the instructions. I’m not calling you stupid, but the fact is that I don’t think the tip is confusing. All I can possibly add is that those commands need to be run in a terminal emulator.
Ehh youre talking to a non technical person like someone who knows basic basic DUH
I typed the instructions for the non-technical people. So it’s not full os tech-jargon and pretty clear. So I repeat myself:
