Laptop limits CPU frequency upto 0.7GHz
Hi,
I have a Dell laptop which I run on AC Power without the battery. I have a good charger too but from the past few days it shows me a prompt that it might be faulty (Even though it’s perfectly fine) and limits the CPU frequency close to 0.7GHz. I’ve read that it might be a bios limiter but I couldn’t find any manjaro specific solutions. I don’t know if ubuntu solutions work for this( being new to Linux). I can’t even get and try a new charger as my country is in lockdown.
Help would be appreciated.
Edit: I checked in the bios-menu it shows my adapter type as unknown( It worked fine untill yesterday even though it’s aftermarket) and I can’t get a new one at the moment. Any workaround for this that will work on manjaro.
Here is the inxi output
  Kernel: 5.10.34-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  root=UUID=4f503d32-9bd6-4460-9f6a-700d25dc8d14 rw quiet splash apparmor=1
  security=apparmor udev.log_priority=3 intel_pstate=disable
  processor.ignore_ppc=1
  Desktop: GNOME 3.38.4 tk: GTK 3.24.29 wm: gnome-shell dm: GDM 40.0
  Type: Laptop System: Dell product: Vostro 14-3468 v: N/A serial: <filter>
  Chassis: type: 9 serial: <filter>
  Mobo: Dell model: 01CM9N v: A01 serial: <filter> UEFI: Dell v: 2.5.0
  date: 04/19/2018
  RAM: total: 3.71 GiB used: 1.85 GiB (49.9%)
  Info: Dual Core model: Intel Core i3-7100U bits: 64 type: MT MCP
  arch: Amber/Kaby Lake note: check family: 6 model-id: 8E (142) stepping: 9
  microcode: DE cache: L2: 3 MiB bogomips: 19200
  Speed: 568 MHz min/max: N/A Core speeds (MHz): 1: 568 2: 428 3: 610 4: 703
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
  avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
  hwp_epp hwp_notify ibpb ibrs intel_pt invpcid invpcid_single lahf_lm lm mca
  mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
  pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
  rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
  ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme
  vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Type: l1tf
  Device-1: Intel HD Graphics 620 vendor: Dell driver: i915 v: kernel
  bus-ID: 00:02.0 chip-ID: 8086:5916 class-ID: 0300
  Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
  bus-ID: 1-5:3 chip-ID: 0c45:6a05 class-ID: 0e02
  Display: wayland server: X.org 1.20.11 compositor: gnome-shell driver:
  loaded: i915 note: n/a (using device driver) - try sudo/root display-ID: 0
  OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.0.3
  direct render: Yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
  v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71
  class-ID: 0403
  Sound Server-1: ALSA v: k5.10.34-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.26 running: no
  Device-1: Intel Wireless 3165 driver: iwlwifi v: kernel port: f040
  bus-ID: 01:00.0 chip-ID: 8086:3165 class-ID: 0280
  vendor: Dell driver: r8169 v: kernel port: e000 bus-ID: 02:00.0
  bus-ID: 1-8:5 chip-ID: 8087:0a2a class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
  Local Storage: total: 931.51 GiB used: 9.13 GiB (1.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
  rotation: 5400 rpm serial: <filter> rev: SDM2 scheme: GPT
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVD+-RW GU90N rev: A1C1
  dev-links: cdrom
  ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%) used: 9.13 GiB (1.0%)
  fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
  uuid: 4f503d32-9bd6-4460-9f6a-700d25dc8d14
  used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
  uuid: 76AB-FC1E
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
  Device-1: 1-4:2 info: Validity Sensors VFS Fingerprint sensor
  type: <vendor specific> driver: N/A interfaces: 1 rev: 1.1 speed: 12 Mb/s
  power: 100mA chip-ID: 138a:0010 class-ID: ff00 serial: <filter>
  Device-2: 1-5:3 info: Microdia Integrated_Webcam_HD type: Video
  Device-3: 1-6:4 info: Realtek RTS5129 Card Reader Controller
  interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
  Device-4: 1-8:5 info: Intel Bluetooth wireless interface type: Bluetooth
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 44.0 C mobo: 41.0 C
  Fan Speeds (RPM): cpu: 0
  Processes: 199 Uptime: 5m wakeups: 1 Init: systemd v: 247 tool: systemctl
  Compilers: gcc: 10.2.0 Packages: pacman: 1164 lib: 301 flatpak: 0 Shell: Zsh
  v: 5.8 running-in: gnome-terminal inxi: 3.3.04
Hi @UnHyperVenom, and welcome!
While I do not know if I’ll be able to help you, I can point you to this so long: How to provide good information
Good luck and I hope someone can help!
can you return
inxi -Fza
sudo cpupower frequency-info
see this Kernel 5.8.x my system seems to be only running at it’s minimum clock of 800mhz - #12 by stephane
@stephane I have added the inxi output to the above post
Here is the cpupower frequency-info output
  no or unknown cpufreq driver is active on this CPU
  CPUs which run at the same hardware frequency: Not Available
  CPUs which need to have their frequency coordinated by software: Not Available
  maximum transition latency:  Cannot determine or is not supported.
Not Available
  available cpufreq governors: Not Available
  Unable to determine current policy
  current CPU frequency: Unable to call hardware
  current CPU frequency:  Unable to call to kernel
  boost state support:
    Supported: no
    Active: no
lscpu shows the frequency as
CPU MHz: 399.999
Edit:I checked in the bios-menu it shows my adapter type as unknown( It worked fine untill yesterday even though it’s aftermarket) and I can’t get a new one at the moment. Any workaround for this that will work on manjaro
Thanks for trying to help.
what is the adapter you’re talking about? Is it the power supply? If so then maybe it is dying? Can you try another one? Can you try to plug the battery and charge it fully?
@omano By adapter I meant the AC power supply. My laptop’s battery is already dead and I am running it only on the power supply and as I said I cannot get a new charger at least for the next few weeks that’s why I am looking for another way to disable the limiter.
I know the power supply is fine as it worked well untill a few days ago and it doesn’t even excessively heat the laptop components. It’s just the Dell laptop suddenly doesn’t detect it and limits cpu frequency
I googled and found that it is a widespread issue on Dell laptops, officially to ‘protect’ the batery when used with non official Dell power supply (some would say to force you to buy Dell products), I also found that you can try to add a GRUB parameter to bypass the BIOS limitation.
To try it at your own risk, if you want, you can edit the boot command line directly from GRUB menu (press E on the Manjaro line in GRUB menu, and add it to the end of the boot parameters line), and boot with this temporarily added parameter.
If it works, then add it to your regular grub file /etc/default/grub, EXAMPLE with MY OWN GRUB line (yours will be different so don’t copy/paste mine blindly, modify YOURS accordingly):
Before:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash apparmor=1 security=apparmor udev.log_priority=3 sysrq_always_enabled=1 nowatchdog"
After:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash apparmor=1 security=apparmor udev.log_priority=3 sysrq_always_enabled=1 nowatchdog processor.ignore_ppc=1"
See the added processor.ignore_ppc=1 at the end of the line (it is all ONE LINE it is not multiple lines).
After your GRUB file is modified, don’t forget to update GRUB with command sudo update-grub
PS: make sure it doesn’t create problem with over heating or something like that, maybe there is a legit reason your BIOS is limiting CPU.
@omano Thanks for replying
I tried modifying the GRUB file and rebooted but it didn’t do anthing my laptop still lags a lot, youtube can’t even play 720p, it could easily do 1080p before( I have a 100 mbps connection) and lscpu gives me frequencies in the 400-600 Mhz range.
I read many forums stating about the intel cpu scaling drivers and also this:
But I am a new user and don’t have much technical knowledge so I can’t figure much out.
You did exactly what I explained in details?
Show you modification to GRUB.
Are you sure you updated GRUB?
@omano
I didn’t understand how to do the above mentioned part but I did add the processor.ignore_ppc=1 line to the GRUB file.
'GRUB_CMDLINE_LINUX_DEFAULT="quiet splash apparmor=1 security=apparmor udev.log_priority=3 processor.ignore_ppc=1"
Yes I did update GRUB using sudo update-grub
Here’s the sudo cpupower -c all frequency-info output too if it’s helpful
  driver: intel_pstate
  CPUs which run at the same hardware frequency: 0
  CPUs which need to have their frequency coordinated by software: 0
  hardware limits: 400 MHz - 2.40 GHz
  available cpufreq governors: performance powersave
  current policy: frequency should be within 1.10 GHz and 2.40 GHz.
                  The governor "performance" may decide which speed to use
                  within this range.
  current CPU frequency: 2.38 GHz (asserted by call to kernel)
    Supported: no
    Active: no
analyzing CPU 1:
  CPUs which run at the same hardware frequency: 1
  CPUs which need to have their frequency coordinated by software: 1
                  within this range.
  current CPU frequency: 2.35 GHz (asserted by call to kernel)
    Supported: no
    Active: no
analyzing CPU 2:
  CPUs which run at the same hardware frequency: 2
  CPUs which need to have their frequency coordinated by software: 2
                  within this range.
  current CPU frequency: 2.40 GHz (asserted by call to kernel)
    Supported: no
    Active: no
analyzing CPU 3:
  CPUs which run at the same hardware frequency: 3
  CPUs which need to have their frequency coordinated by software: 3
                  within this range.
    Supported: no
    Active: no
Thank you all for trying to help I found the solution for this here:
This works well but now my CPU is constantly at Max clock speed if you can help please do.
Thanks anyways for your time and help everyone.
Edit: I tried tweaking TLP settings and now everything works normally
