Lagging Plasma / Disk sleep / Performance Issue
Hi there,
I am now using for about 2 - 3 years Manjaro (KDE) and I love it - I think it is a brilliant peace of work, until now the best distribution for my purposes - in the past, I used Suse, Mandriva, Kubuntu, Linuxmint, Debian, KDE Neon, MX Linux), MX Linux I am still using on slower machines where I want not to have any complications and where I want to avoid spending time in troubefixing aspects (for me, it seems to be very stable).
However, I experience now for about some months a strange behavior in Plasmashell - for some reason for some months now the system sporadically does not respond for a few seconds when I interact with Plasma (klauncher / start apps in Plasma) - the mouse pointer moves, also I can use the touchpad and the buttons in the touchpad, the applications (except those of plasmashell) run without interruptions and lagging, but I cannot start applications (e.g. via application launcher, kstarter, Alt + F2, etc.) - I sometimes have to wait more than 10 seconds until Plasma responds (e.g. the taskbar)…
The system load is moderate in each case, CPU < 10% (Intel i7, 10th Gen), RAM < 20% (16 GB RAM). It is noticeable that at the time of the lagging behavior plasmashell is shown with “Disk Sleep” in ksysguard in the CPU % column - that seems to be the key indicator for the problem - everytime plasmashell lags, disk sleep is the status of plasmashell. I did some googling over the last months, adjusted one or the other aspect (replace kio-git with kio and vice versa, turn on/off from swap drive, kernel upgrade/downgrade, etc.), also based on some topics here in manaro forum (e.g. KDE Plasma is laggy, Applications keep refreshing, Manjaro KDE critical bug: Plasmashell extreme CPU usage + IO write (also affecting lattedock, dolphin, krunner) - #24 by Nistau), but none of the aspects matched exactly my “problem”, and the measures seemed not to work for me.
Does anyone know why this disk-sleep occurs and how I can prevent it or if necessary how I can find out myself why this disk-sleep occurs?
$ inxi -Fazy
  Kernel: 5.11.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64
  root=UUID=f10fe1a4-9cde-4dbf-a28c-d05d6857cb50 rw quiet apparmor=1
  Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Convertible System: HP product: HP ENVY x360 Convertible 15-dr1xxx
  v: Type1ProductConfigId serial: <filter> Chassis: type: 31 serial: <filter>
  Mobo: HP model: 86B2 v: 85.20 serial: <filter> UEFI: Insyde v: F.09
  date: 08/06/2020
  ID-1: BAT0 charge: 32.3 Wh (63.7%) condition: 50.7/50.7 Wh (100.0%)
  volts: 15.5 min: 15.1 model: 333-AC-3E-A SA04055XL type: Li-ion
  serial: <filter> status: Discharging
  Device-1: hid-0018:04F3:2400.0002-battery model: ELAN2514:00 04F3:2400
  serial: N/A charge: N/A status: N/A
  Info: Quad Core model: Intel Core i7-10510U bits: 64 type: MT MCP
  arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: C (12)
  microcode: DE cache: L2: 8 MiB
  bogomips: 36812
  Speed: 800 MHz min/max: 400/4900 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
  4: 800 5: 800 6: 800 7: 800 8: 800
  Type: srbds mitigation: TSX disabled
  Device-1: Intel UHD Graphics vendor: Hewlett-Packard driver: i915 v: kernel
  bus-ID: 00:02.0 chip-ID: 8086:9b41 class-ID: 0300
  Device-2: NVIDIA GP108M [GeForce MX250] vendor: Hewlett-Packard
  driver: nvidia v: 460.73.01 alternate: nouveau,nvidia_drm bus-ID: 02:00.0
  chip-ID: 10de:1d13 class-ID: 0302
  Device-3: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD Camera
  type: USB driver: uvcvideo bus-ID: 1-4:4 chip-ID: 05c8:03d3 class-ID: 0e02
  Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
  loaded: modesetting,nvidia unloaded: intel,nouveau alternate: fbdev,nv,vesa
  display-ID: :0 screens: 1
  s-diag: 582mm (22.9")
  Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6")
  diag: 395mm (15.5")
  OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.0.3
  direct render: Yes
  Device-1: Intel Comet Lake PCH-LP cAVS vendor: Hewlett-Packard
  driver: sof-audio-pci alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci
  bus-ID: 00:1f.3 chip-ID: 8086:02c8 class-ID: 0401
  Sound Server-1: ALSA v: k5.11.18-1-MANJARO running: yes
  Sound Server-2: JACK v: 1.9.18 running: no
  Sound Server-4: PipeWire v: 0.3.26 running: yes
  Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
  port: 4000 bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
  IF-ID-1: docker0 state: down mac: <filter>
  Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 1-10:3
  chip-ID: 8087:0026 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
  Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
  v: 3.0 port: 4060 bus-ID: 00:17.0 chip-ID: 8086.282a rev: class-ID: 0104
  Local Storage: total: 476.94 GiB used: 361.28 GiB (75.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA model: N/A size: 476.94 GiB
  block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2
  rotation: SSD serial: <filter> rev: ADHA0102 temp: 39.9 C scheme: GPT
  ID-1: / raw-size: 238.41 GiB size: 233.67 GiB (98.01%)
  used: 205.24 GiB (87.8%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
  ID-2: /boot/efi raw-size: 250 MiB size: 246.1 MiB (98.46%)
  used: 301 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5
^CSensors:
  System Temperatures: cpu: 41.0 C mobo: 36.0 C
  Processes: 348 Uptime: 6h 51m wakeups: 16088 Memory: 15.31 GiB
  used: 3.89 GiB (25.4%) Init: systemd v: 247 tool: systemctl Compilers:
  gcc: 10.2.0 clang: 11.1.0 Packages: 1593 pacman: 1588 lib: 432 flatpak: 0
  snap: 5 Shell: Bash v: 5.1.4 running-in: konsole inxi: 3.3.04
$ sudo dmesg -l emerg,alert,crit,err,warn
[    0.130475] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.467546] ACPI: Invalid passive threshold
[    0.749646] usb: port power management may be unreliable
[    1.237030] vboxdrv: loading out-of-tree module taints kernel.
[    1.267286] VBoxNetAdp: Successfully started.
[    1.269181] VBoxNetFlt: Successfully started.
[    1.484815] lis3lv02d: unknown sensor type 0x0
[    1.484819] hp_accel: probe of HPQ6007:00 failed with error -22
[    1.498725] nvidia: module license 'NVIDIA' taints kernel.
[    1.498728] Disabling lock debugging due to kernel taint
[    1.516918] wmi_bus wmi_bus-PNP0C14:01: WQ data block query control method not found
[    1.516923] wmi_bus wmi_bus-PNP0C14:01: WQ data block query control method not found
[    1.516925] wmi_bus wmi_bus-PNP0C14:01: WQ data block query control method not found
[    1.516927] wmi_bus wmi_bus-PNP0C14:01: WQ data block query control method not found
[    1.517202] acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:03)
[    1.517266] acpi PNP0C14:05: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:03)
[    1.517420] acpi PNP0C14:06: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:03)
[    1.517450] wmi_bus wmi_bus-PNP0C14:06: WQBJ data block query control method not found
[    1.646054] NVRM: loading NVIDIA UNIX x86_64 Kernel Module  460.73.01  Thu Apr  1 21:40:36 UTC 2021
[    1.803232] i2c_hid i2c-SYNA328C:00: supply vdd not found, using dummy regulator
[    1.803250] i2c_hid i2c-SYNA328C:00: supply vddl not found, using dummy regulator
[    1.826329] i2c_hid i2c-ELAN2514:00: supply vdd not found, using dummy regulator
[    1.826349] i2c_hid i2c-ELAN2514:00: supply vddl not found, using dummy regulator
[    1.933081] iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
[    1.978740] i2c_hid i2c-ELAN2514:00: i2c_hid_get_input: IRQ triggered but there's no data
[    2.125047] urandom_read: 1 callbacks suppressed
[    2.162282] [Firmware Bug]: ACPI(PXSX) defines _DOD but not _DOS
[    2.360173] thermal thermal_zone7: failed to read out thermal zone (-61)
[    2.688292] sof-audio-pci 0000:00:1f.3: warn: FW ABI is more recent than kernel
[    2.778625] sof-audio-pci 0000:00:1f.3: warn: FW ABI is more recent than kernel
[    2.799920] sof-audio-pci 0000:00:1f.3: warn: topology ABI is more recent than kernel
[    2.815861] sof-audio-pci 0000:00:1f.3: ASoC: Parent card not yet available, widget card binding deferred
[    2.874055] snd_hda_codec_realtek ehdaudio0D0: ASoC: sink widget AIF1TX overwritten
[    2.874066] snd_hda_codec_realtek ehdaudio0D0: ASoC: source widget AIF1RX overwritten
[    2.874265] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi3 overwritten
[    2.874273] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi2 overwritten
[    2.874279] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi1 overwritten
[    2.874285] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Codec Output Pin1 overwritten
[    2.874290] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Codec Input Pin1 overwritten
[    2.874298] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Analog Codec Playback overwritten
[    2.874306] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Digital Codec Playback overwritten
[    2.874313] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Alt Analog Codec Playback overwritten
[    2.874321] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Analog Codec Capture overwritten
[    2.874328] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Digital Codec Capture overwritten
[    2.874335] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Alt Analog Codec Capture overwritten
[    3.623823] hp_wmi: query 0x4c returned error 0x6
[    4.336830] ACPI Warning: \_SB.PCI0.RP05.PXSX._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20201113/nsarguments-61)
[    6.302349] kauditd_printk_skb: 57 callbacks suppressed
[    9.192325] CIFS: VFS: Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
[    9.192353] CIFS: VFS: Error connecting to socket. Aborting operation.
[    9.192356] CIFS: VFS: cifs_mount failed w/return code = -101
[    9.300702] CIFS: VFS: Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
[   12.053551] CIFS: VFS: bogus file nlink value 0
[   12.058051] CIFS: VFS: bogus file nlink value 0
[   12.062324] CIFS: VFS: bogus file nlink value 0
[   12.065407] CIFS: VFS: bogus file nlink value 0
[   12.070833] CIFS: VFS: bogus file nlink value 0
[   12.076577] CIFS: VFS: bogus file nlink value 0
[   12.084724] CIFS: VFS: bogus file nlink value 0
[   12.089997] CIFS: VFS: bogus file nlink value 0
[   12.094255] CIFS: VFS: bogus file nlink value 0
[   12.098621] CIFS: VFS: bogus file nlink value 0
[   13.011271] kauditd_printk_skb: 145 callbacks suppressed
[   98.866761] cifs_all_info_to_fattr: 94 callbacks suppressed
[   98.866770] CIFS: VFS: bogus file nlink value 0
[   98.871076] CIFS: VFS: bogus file nlink value 0
[   98.875452] CIFS: VFS: bogus file nlink value 0
[   98.878540] CIFS: VFS: bogus file nlink value 0
[   98.882895] CIFS: VFS: bogus file nlink value 0
[   98.887206] CIFS: VFS: bogus file nlink value 0
[   98.891346] CIFS: VFS: bogus file nlink value 0
[   98.895096] CIFS: VFS: bogus file nlink value 0
[   98.898830] CIFS: VFS: bogus file nlink value 0
[   98.903145] CIFS: VFS: bogus file nlink value 0
[ 9179.165224] iwlwifi 0000:00:14.3: TB bug workaround: copied 1016 bytes from 0x2fffffc08 to 0x3ffa5e000
[14146.650131] Freezing of tasks failed after 20.005 seconds (2 tasks refusing to freeze, wq_busy=0):
[14167.500742] Freezing of tasks failed after 20.009 seconds (2 tasks refusing to freeze, wq_busy=0):
[14501.228373] CIFS: VFS: \\192.168.178.1 has not responded in 180 seconds. Reconnecting...
[14789.883676] Freezing of tasks failed after 20.006 seconds (1 tasks refusing to freeze, wq_busy=0):
[14809.924033] Freezing of tasks failed after 20.009 seconds (1 tasks refusing to freeze, wq_busy=0):
[18460.019351] hid-sensor-hub 001F:8087:0AC2.0003: hid_field_extract() called with n (192) > 32! (kworker/7:0)
The CIFS aspect I can exclude as the cause of the behaviour, as I unmounted the drive right now and the laggy behavior still occurs - and the laggy behavior occurs also when the respective device is successfully mounted.
$ grep -e (EE) -e WW -e Dri -e DRI -nC1 /var/log/Xorg.0.log
14-     (++) from command line, (!!) notice, (II) informational,
15:     (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
16-[     2.841] (==) Log file: "/var/log/Xorg.0.log", Time: Thu May 13 02:46:32 2021
29-[     2.845] (==) Max clients allowed: 256, resource mask: 0x1fffff
30:[     2.846] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/misc".
31-[     2.846]         Entry deleted from font path.
32-[     2.846]         (Run 'mkfontdir' on "/usr/share/fonts/misc").
33:[     2.847] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
34-[     2.847]         Entry deleted from font path.
35-[     2.847]         (Run 'mkfontdir' on "/usr/share/fonts/TTF").
36:[     2.847] (WW) The directory "/usr/share/fonts/OTF" does not exist.
37-[     2.847]         Entry deleted from font path.
38:[     2.847] (WW) The directory "/usr/share/fonts/Type1" does not exist.
39-[     2.847]         Entry deleted from font path.
40:[     2.847] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
41-[     2.847]         Entry deleted from font path.
42:[     2.847] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
43-[     2.847]         Entry deleted from font path.
50-[     2.847]         X.Org ANSI C Emulation: 0.4
51:[     2.847]         X.Org Video Driver: 24.1
52-[     2.847]         X.Org XInput driver : 24.1
62-[     3.372] (--) PCI: (2@0:0:0) 10de:1d13:103c:86b2 rev 161, Mem @ 0xb3000000/16777216, 0xa0000000/268435456, 0xb0000000/33554432, I/O @ 0x00003000/128
63:[     3.372] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
64-[     3.372] (II) LoadModule: "glx"
86-[     3.385]         compiled for 1.20.11, module version = 1.20.11
87:[     3.385]         Module class: X.Org Video Driver
88:[     3.385]         ABI class: X.Org Video Driver, version 24.1
89-[     3.385] (II) LoadModule: "intel"
92-[     3.388]         compiled for 1.20.10, module version = 2.99.917
93:[     3.388]         Module class: X.Org Video Driver
94:[     3.388]         ABI class: X.Org Video Driver, version 24.1
95-[     3.388] (II) LoadModule: "nvidia"
98-[     3.391]         compiled for 1.6.99.901, module version = 1.0.0
99:[     3.391]         Module class: X.Org Video Driver
100-[     3.392] (II) LoadModule: "nouveau"
103-[     3.393]        compiled for 1.20.10, module version = 1.0.17
104:[     3.393]        Module class: X.Org Video Driver
105:[     3.393]        ABI class: X.Org Video Driver, version 24.1
106-[     3.393] (II) LoadModule: "nv"
107:[     3.394] (WW) Warning, couldn't open module nv
108:[     3.394] (EE) Failed to load module "nv" (module does not exist, 0)
109-[     3.394] (II) LoadModule: "fbdev"
110:[     3.394] (WW) Warning, couldn't open module fbdev
111:[     3.394] (EE) Failed to load module "fbdev" (module does not exist, 0)
112-[     3.394] (II) LoadModule: "vesa"
113:[     3.394] (WW) Warning, couldn't open module vesa
114:[     3.394] (EE) Failed to load module "vesa" (module does not exist, 0)
115:[     3.394] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
116:[     3.394] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
117-    i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
120-    GM45, 4 Series, G45/G43, Q45/Q43, G41, B43
121:[     3.395] (II) intel: Driver for Intel(R) HD Graphics
122:[     3.395] (II) intel: Driver for Intel(R) Iris(TM) Graphics
123:[     3.395] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics
124:[     3.395] (II) NVIDIA dlloader X Driver  460.73.01  Thu Apr  1 21:37:53 UTC 2021
125:[     3.395] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
126-[     3.395] (II) NOUVEAU driver
337-[     5.318] (II) NVIDIA(G0): Virtual screen size determined to be 640 x 480
338:[     5.318] (WW) NVIDIA(G0): Unable to get display device for DPI computation.
339-[     5.318] (==) NVIDIA(G0): DPI set to (75, 75); computed from built-in default
347-[     5.416] (==) modeset(0): DPMS enabled
348:[     5.417] (II) modeset(0): [DRI2] Setup complete
349:[     5.417] (II) modeset(0): [DRI2]   DRI driver: iris
350:[     5.417] (II) modeset(0): [DRI2]   VDPAU driver: va_gl
351-[     5.417] (II) NVIDIA: Using 24576.00 MB of virtual memory for indirect memory
368-[     5.447] (II) Module "dri2" already built-in
369:[     5.447] (II) NVIDIA(G0): [DRI2] Setup complete
370:[     5.447] (II) NVIDIA(G0): [DRI2]   VDPAU driver: nvidia
371-[     5.447] (II) Initializing extension Generic Event Extension
390-[     5.449] (II) Initializing extension Present
391:[     5.449] (II) Initializing extension DRI3
392-[     5.450] (II) Initializing extension X-Resource
398-[     5.457] (II) AIGLX: Loaded and initialized iris
399:[     5.457] (II) GLX: Initialized DRI2 GL provider for screen 0
400-[     5.457] (II) Initializing extension XFree86-VidModeExtension
401-[     5.457] (II) Initializing extension XFree86-DGA
402:[     5.457] (II) Initializing extension XFree86-DRI
403:[     5.457] (II) Initializing extension DRI2
404-[     5.457] (II) Initializing extension NV-GLX
415-[     5.513]        compiled for 1.20.11, module version = 1.0.1
416:[     5.513]        Module class: X.Org XInput Driver
417-[     5.513]        ABI class: X.Org XInput driver, version 24.1
515-[     5.942] (II) mouse1  - not using input device '/dev/input/mouse1'.
516:[     5.942] (EE) libinput: SYNA328C:00 06CB:CD4F Touchpad: Failed to create a device for /dev/input/mouse1
517:[     5.942] (EE) PreInit returned 2 for "SYNA328C:00 06CB:CD4F Touchpad"
518-[     5.942] (II) UnloadModule: "libinput"
747-[     6.835] (II) mouse4  - not using input device '/dev/input/mouse4'.
748:[     6.835] (EE) libinput: SynPS/2 Synaptics TouchPad: Failed to create a device for /dev/input/mouse4
749:[     6.835] (EE) PreInit returned 2 for "SynPS/2 Synaptics TouchPad"
750-[     6.835] (II) UnloadModule: "libinput"
780-[     8.191] (II) modeset(0): Modeline "1920x1080"x0.0   94.00  1920 2028 2076 2100  1080 1090 1100 1118 -hsync -vsync (44.8 kHz e)
781:[  9048.207] (EE) event7  - SYNA328C:00 06CB:CD4F Touchpad: client bug: event processing lagging behind by 17ms, your system is too slow
782-[ 14126.268] (II) event13 - Video Bus: device removed
1107-[ 15415.608] (II) event23 - HP Wide Vision HD Camera: HP Wi: device is a keyboard
1108:[ 15862.999] (EE) event7  - SYNA328C:00 06CB:CD4F Touchpad: kernel bug: Touch jump detected and discarded.
1109-See https://wayland.freedesktop.org/libinput/doc/1.17.2/touchpad-jumping-cursors.html for details
1110:[ 16291.311] (EE) event7  - SYNA328C:00 06CB:CD4F Touchpad: kernel bug: Touch jump detected and discarded.
1111-See https://wayland.freedesktop.org/libinput/doc/1.17.2/touchpad-jumping-cursors.html for details
1112:[ 16315.110] (EE) event7  - SYNA328C:00 06CB:CD4F Touchpad: kernel bug: Touch jump detected and discarded.
1113-See https://wayland.freedesktop.org/libinput/doc/1.17.2/touchpad-jumping-cursors.html for details
1114:[ 16620.064] (EE) event7  - SYNA328C:00 06CB:CD4F Touchpad: kernel bug: Touch jump detected and discarded.
1115-See https://wayland.freedesktop.org/libinput/doc/1.17.2/touchpad-jumping-cursors.html for details
1116:[ 16786.671] (EE) event7  - SYNA328C:00 06CB:CD4F Touchpad: kernel bug: Touch jump detected and discarded.
1117-See https://wayland.freedesktop.org/libinput/doc/1.17.2/touchpad-jumping-cursors.html for details
1118:[ 16786.671] (EE) event7  - SYNA328C:00 06CB:CD4F Touchpad: WARNING: log rate limit exceeded (5 msgs per 2h). Discarding future messages.
1119:[ 18121.609] (EE) event7  - SYNA328C:00 06CB:CD4F Touchpad: client bug: event processing lagging behind by 21ms, your system is too slow
1120:[ 18123.024] (EE) event7  - SYNA328C:00 06CB:CD4F Touchpad: client bug: event processing lagging behind by 17ms, your system is too slow
1121:[ 23291.625] (EE) event7  - SYNA328C:00 06CB:CD4F Touchpad: client bug: event processing lagging behind by 17ms, your system is too slow
1122:[ 23308.874] (EE) event7  - SYNA328C:00 06CB:CD4F Touchpad: client bug: event processing lagging behind by 18ms, your system is too slow
1123:[ 23373.460] (EE) event7  - SYNA328C:00 06CB:CD4F Touchpad: kernel bug: Touch jump detected and discarded.
1124-See https://wayland.freedesktop.org/libinput/doc/1.17.2/touchpad-jumping-cursors.html for details
1125:[ 23481.992] (EE) event7  - SYNA328C:00 06CB:CD4F Touchpad: kernel bug: Touch jump detected and discarded.
1126-See https://wayland.freedesktop.org/libinput/doc/1.17.2/touchpad-jumping-cursors.html for details
1127:[ 23855.811] (EE) event7  - SYNA328C:00 06CB:CD4F Touchpad: kernel bug: Touch jump detected and discarded.
1128-See https://wayland.freedesktop.org/libinput/doc/1.17.2/touchpad-jumping-cursors.html for details
1129:[ 23931.390] (EE) event7  - SYNA328C:00 06CB:CD4F Touchpad: kernel bug: Touch jump detected and discarded.
1130-See https://wayland.freedesktop.org/libinput/doc/1.17.2/touchpad-jumping-cursors.html for details
1131:[ 23989.706] (EE) event7  - SYNA328C:00 06CB:CD4F Touchpad: kernel bug: Touch jump detected and discarded.
1132-See https://wayland.freedesktop.org/libinput/doc/1.17.2/touchpad-jumping-cursors.html for details
1133:[ 23989.707] (EE) event7  - SYNA328C:00 06CB:CD4F Touchpad: WARNING: log rate limit exceeded (5 msgs per 2h). Discarding future messages.
1134-[ 24098.568] (II) modeset(0): EDID vendor "AUO", prod id 8429
1141-[ 24168.374] (II) modeset(0): Modeline "1920x1080"x0.0   94.00  1920 2028 2076 2100  1080 1090 1100 1118 -hsync -vsync (44.8 kHz e)
1142:[ 24927.468] (EE) event7  - SYNA328C:00 06CB:CD4F Touchpad: client bug: event processing lagging behind by 12ms, your system is too slow
I googled around regarding “Touchpad: client bug: event processing lagging behind by 12ms, your system is too slow” - imho that seems not to be the problem, however, I don’t know what to do even if that is the problem - any advice on that?
$ printenv
SHELL=/bin/bash
SESSION_MANAGER=local/xxxxLaptop:@/tmp/.ICE-unix/1489,unix/xxxxLaptop:/tmp/.ICE-unix/1489
WINDOWID=96468999
COLORTERM=truecolor
XDG_SESSION_PATH=/org/freedesktop/DisplayManager/Session0
HISTCONTROL=ignoredups
HISTSIZE=
LANGUAGE=
LC_ADDRESS=de_DE.UTF-8
DOTNET_ROOT=/usr/share/dotnet
LC_NAME=de_DE.UTF-8
GRADLE_HOME=/usr/share/java/gradle
HISTTIMEFORMAT=[%F %T]
SHELL_SESSION_ID=93b7c314c032402fa5bef9c516723bf1
DESKTOP_SESSION=plasma
LC_MONETARY=de_DE.UTF-8
GTK_RC_FILES=/etc/gtk/gtkrc:/home/xxxx/.gtkrc:/home/xxxx/.config/gtkrc
XCURSOR_SIZE=24
EDITOR=/usr/bin/nano
GTK_MODULES=canberra-gtk-module
XDG_SEAT=seat0
PWD=/home/xxxx
XDG_SESSION_DESKTOP=KDE
LOGNAME=xxxx
XDG_SESSION_TYPE=x11
XAUTHORITY=/home/xxxx/.Xauthority
MOTD_SHOWN=pam
GTK2_RC_FILES=/etc/gtk-2.0/gtkrc:/home/xxxx/.gtkrc-2.0:/home/xxxx/.config/gtkrc-2.0
HOME=/home/xxxx
LC_PAPER=de_DE.UTF-8
LANG=en_US.UTF-8
HISTFILE=/home/xxxx/.bashhistory
LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=01;05;37;41:mi=01;05;37;41:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.Z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.jpg=01;35:*.jpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.axv=01;35:*.anx=01;35:*.ogv=01;35:*.ogx=01;35:*.pdf=00;32:*.ps=00;32:*.txt=00;32:*.patch=00;32:*.diff=00;32:*.log=00;32:*.tex=00;32:*.doc=00;32:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.axa=00;36:*.oga=00;36:*.spx=00;36:*.xspf=00;36:
XDG_CURRENT_DESKTOP=KDE
KONSOLE_DBUS_SERVICE=:1.199
KONSOLE_DBUS_SESSION=/Sessions/1
PROFILEHOME=
ORACLE_HOME=/usr
XDG_SEAT_PATH=/org/freedesktop/DisplayManager/Seat0
KONSOLE_VERSION=210400
DOTNET_BUNDLE_EXTRACT_BASE_DIR=/home/xxxx/.cache/dotnet_bundle_extract
KDE_SESSION_UID=1000
XDG_SESSION_CLASS=user
TERM=xterm-256color
LC_IDENTIFICATION=de_DE.UTF-8
USER=xxxx
COLORFGBG=15;0
KDE_SESSION_VERSION=5
PAM_KWALLET5_LOGIN=/run/user/1000/kwallet5.socket
DISPLAY=:0
SHLVL=1
LC_TELEPHONE=de_DE.UTF-8
SPARK_HOME=/opt/apache-spark
LC_MEASUREMENT=de_DE.UTF-8
XDG_VTNR=1
XDG_SESSION_ID=1
QT_LINUX_ACCESSIBILITY_ALWAYS_ON=1
XDG_RUNTIME_DIR=/run/user/1000
LC_TIME=de_DE.UTF-8
TNS_ADMIN=/etc/tnsnames.ora
QT_AUTO_SCREEN_SCALE_FACTOR=0
XCURSOR_THEME=breeze_cursors
GTK3_MODULES=xapp-gtk3-module
XDG_DATA_DIRS=/home/xxxx/.local/share/flatpak/exports/share:/var/lib/flatpak/exports/share:/usr/local/share:/usr/share:/var/lib/snapd/desktop
KDE_FULL_SESSION=true
BROWSER=/usr/bin/firefox
PATH=/home/xxxx/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/bin:/home/xxxx/.dotnet/tools:/usr/lib/jvm/default/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl:/var/lib/snapd/snap/bin
HISTFILESIZE=
DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/1000/bus
KDE_APPLICATIONS_AS_SCOPE=1
MAIL=/var/spool/mail/xxxx
LC_NUMERIC=de_DE.UTF-8
KONSOLE_DBUS_WINDOW=/Windows/1
Please let me know if some other information about my system / the configuration might be helpful to find out what causes the problem.
Many thanks in advance for your help!
Kind regards,
D.
Update
It might be that I found now the cause for the problem:
All the time today when I saw plasmashell in “disk sleep”, there was also gvfs-udisks2-volume-monitor in “disk sleep” - when I killed gvfs-udisks2-volume-monitor, the “disk sleep” problem for plasmashell does not occur anymore… That is only a first indication, I will provide an update when I am sure that the problem with plasmashell in “disk sleep” does not occur anymore…
What is gvfs-udisks2-volume-monitor? Not absolutely sure, but considering the dependencies it seems to be dispensable for my purposes… I will try to remove it - when everything still works than I might get rid of that problem… Update follows…
Update 2:
Hey there,
I hereby confirm that the “problem” is solved by deinstalling gvfs - until now I experienced no downsides of the deinstallation.
Kind regards,
D.
I’ve had a similar problem pop up randomly lately, disabling swap etc didn’t help for me either but more apps were affected than plasmashell. I’ll see if your workaround does it for me as well :slight_smile:
Edit: whelp, no difference
Hello,
Had the same issue here.
Instead of de-installation, I renamed the service “/usr/lib/systemd/user/gvfs-udisks2-volume-monitor.service.bk”.
It’s not pretty but I had no issue yet
